Question about Car Audio & Video
Where do you fill up the transmission oil in a 1990 ford laser
  • 112 Answers
You pour the transmission fluid down the transmission dipstick tube with a funnel
Posted on Dec 10, 2009
MI have a 2000 ford mustang and need to check or fill the transmission fluid where do I find this? It is a manual transmission.
naughtyon904, Most manual transmissions have a drain plug (on the botttom) and a fill plug (on the side ) of the transmissions. You need to raise the vehicle with ramps and visually check the transmission. Find the fill plug and remove it. With your finger check the level of the oil. It should be at the top of the fill hole. Also, check with your local dealer to find out exactly what is in the transmission as it is usually gear oil and not transmission fluid that is used. They can tell you the exact weight of the oil to be used and if there are any additives. Good luck with this.
May 29, 2011 | 2000 Ford Mustang
Hi im trying to find where i put transmission oil in my 1990 toyota camry with an inline four
If you are talking about an Automatic Transmission, you pull out the Transmission dip stick and add the transmission fluid though that hole. The capacity for the 1990 Camry is 2.6 Quarts. THEN you have the differential section of the transmissioin. That takes 1.7 Quarts. The differential section has a plug at the bottom of the transmission to drain it and another plug on the side of the transaxle case to fill it. You fill it until it overflows out of the side hole. That is 1.7 Quarts. Both parts of the transmission take Dexron II transmission fluid. It is not the same as Dexron IV and is not backwards compatible. I use Royal Purple Max ATF for both parts of this transmission.
Apr 14, 2011 | 1990 Toyota Camry
Where is filler plug for 1990 camry manual shift transmission 4 cyl
Heres a picture to show you where to find the fill on your trany, if you look under the car on the driverside, remove the front under cover to see, on the side of trany which will be facing you is the plug fill, and oil should be level with the bottom of the fill hole a little oil should run out, that means its full.hope this helps ,good luck.2745d77.gif
Oct 04, 2010 | 1990 Toyota Camry
How many quarts of transmission fluid goes in a 2000 ford explorer /
Hello there
abar_a.gif?v=72006
2000 FORD TRUCKS EXPLORER 5.0L 8-cyl Engine Code P
FILTERS
AMSOIL Ea Oil Filter.........EAO11
Wix Oil Filter.........51372
AMSOIL Ea Air Filter.........EAA122
Wix Air Filter.........46253
Wix Fuel Filter.......33595
Wix Trans Filter.....58955 [1]
[1] 4R70W
CAPACITIES
Engine, with filter..........5.0 quarts[1]
Cooling System, Initial Fill..........15.0 quarts
Automatic Transmission, Others Initial Fill..........3.9 quarts[2]
Automatic Transmission, 4R70W Initial Fill..........5.0 quarts[2]
Automatic Transmission, Total Fill
4R70W..........14.0 quarts
2wd ..........10.0 quarts
4wd ..........10.0 quarts
Manual Transmission, ..........5.5 pints
Differential, Rear..........5.7 pints[3]
Differential, Dana 35 Front..........3.6 pints[4]
Transfer Case,Full-Time 4WD..........2.7 pints
1. When refilling, remove dipstick to provide adequate venting and allow oil to flow into crankcase.
2. With ENG at operating temperature, shift through all gears. Check fluid level in PARK and add fluid as needed.
3. Fill to no more than 1/4 to 9/16" below fill plug hole.
4. Fill no higher than 9.5 mm or 3/8" below fill plug.
Aug 07, 2010 | 2006 Ford Explorer
New clutch it's already install but still shift noising
Make sure there is enough transmission oil in the gearbox, without oil the synchro's cannot work so gearchanges will be slow and cumbersome. If filling the gearbox oil dosent help maybe you have gearbox damage - have the gearbox checked out.
Jan 25, 2010 | 1990 Toyota 4Runner
Trying to find out how much oil the Triton V-10 takes when I do my oil change? I cant seem to find it or anyone who knows
It should be listed in the owners manual, but because of different oil cooler setups you may have to do the change yourself and add oil until the correct level is established..... for the first oil change.
Most likely 7 liters,but start with 5,run the engine to fill the oil filter,let it sit for 5 mins and recheck and fill to full.
Note the amount needed for next time.
Nov 08, 2009 | 2000 Ford F250 Super Duty Crew Cabs
1990 honda crx si, 1.6 transmission
No dipstick...you verify by havin car first on level ground then.Then when on stable ground remove the 17mm filler plug on upper passenger side of transmission.if fliud flows out of filler plug than level is fine.if does not flow out whenplug removed.RECOMMEND STRONGLY using a honda brand manual transmission fluid in this transmission..it does wonders for shifting or gearing issues.
Aug 01, 2009 | 1990 Honda CRX
1990 6 cyl F150 transmission fluid change.
If it's manuel you just need the oil, there is a fill hole and a drain hole on the side of the transmission. If it's an automatic, there is an transmission filter that need to be changed if it's been there long enough.
The cheaper way to change the transmission fluid is to have a transmission shop flush it out with a transmission flush system that connects to the high pressure side transmission line and it replaces the old oil with new one and check the transmission line pressure too. This re places 15 liters of fluid. The more expensive is if you just drop the transmission pan and change the oil and filter you only replace about 3 liters in total and if you don't mind the mess you can do it your self for around $50.00 for the filter, gasket and Transmission oil.
Good luck and keep me posted.
Keep me posted and good luck, be glad to help.
Jun 01, 2009 | 1990 Ford F150
Checking transmiission fluid on 1990 ford f-150
look about half way up the drivers side of the transmission there will be a large 'bolt' head its a fill plug loosen it, its only about a half inch long take it out and if fluid runs out or you can take a finger and touch fluid inside the transmission you are good
Apr 30, 2009 | 2004 Ford F150
Car Audio & Video Logo
93 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
