Question about Nokia 6220 classic Smartphone
How do i change the faceplate on my nokia 6220 classic? I have purchased a new one and have tools but cannot work out how to remove the old one.
I forgot my lock code for nokia 6220 imei 352922/02354155/9
Please try to enter *#7328748263373738# from standby screen and your lock code will change to default 12345. Or contact the service center to looking your lock code from flash tool
Feb 23, 2011 | Nokia 6220 classic Smartphone
Nokia 6220c-2 some key not working
less than one year old it is covered by manufacturers warranty as long as there is no water damage, with extended warranty if you go by service provider store they should give you a new one on site.
Nov 12, 2010 | Nokia 6220 classic Smartphone
Flash my nokia 6220 classic
To format nokia 6220 mobile please follow the below steps.
Please download the software called as ‘Psiloc System Tools’.
You can download the system tool software from below website
http://gallery.mobile9.com/f/1047847/
Install it in your phone memory.DONOT install in your memory card because we will be removing the memory card.
Remove the memory card
Open the installed software.
Go to ‘TOOLS’
You will find the option called as ‘format phone’,select it.
It will ask for confirmation, confirm it and it will format your phone.
It will restart while formatting and this process takes several minutes.
Once the mobile is started your mobile is formatted.
NOTE: Formatting will delete all your content from your phone memory.
Thank you
Aug 12, 2010 | Nokia 6220 classic Smartphone
My star button is broken on nokia 6220 classic so i cant unlock my phone, is there another way?
change the button if u have no button direct on jumping two sides on swich button
May 10, 2010 | Nokia 6220 classic Smartphone
6220 classic keypad fault
I have the same prblem And Also change the Ic But Now the Whole KeyPad is not Working ???? plz
Mar 02, 2010 | Nokia 6220 classic Smartphone
Cracked screen on nokia 6220 classic
minta unlock key buat IMEI 352922021139844
May 15, 2009 | Nokia Cell Phones
Nokia 6220 Classic DEAD (black screen)
bogdan744 i have this same problem if you find some instruction to make my nokia work again pls halp mi send me email on shmeko_magionicaro@hotmail.com pls send me anything to make my mobile work again :(
Mar 01, 2009 | Nokia 6220 classic Smartphone
Need to replace faceplate for nokia 5300
Start by removing battery. Then remove the camera plastic panel. After that you will need to loosen the screws holding the faceplate in on the top. You will require a special tool for this but it can be purchased from most places that sell DIY faceplate kits.After careful prying the faceplate should come loose. Keep in mind that the screen over the LCD screen is taped on and will need to be removed separately.
Oct 24, 2008 | Cell Phones
Nokia 6220 classic master reset
dude..... just return the set to its owner and be a nice person for a change !!!
Aug 18, 2008 | Nokia 6220 classic Smartphone
Nokia 6220 classic Smartphone Logo
128 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
