Question about Danby 5.5 cu. ft. / 156 liter Chest Freezer Millenium DCF550W
Green light I just defrosted my freezer and plugged it back in.  the green light isn't lit on the front. I can't remember if it was lit before but it worked great, it was just frosty, so I unplugged it to thaw. i think it is working again but what is the green light for anyway?
  • 2 more comments
  • Girlfriday13 Jan 20, 2008
    I have the same problem. The green light is no longer working and our freezer has stopped being cold a couple of times, with no apparent reason.
  • scotty47 Mar 04, 2008
    We had the same freezer model which stopped working after two months..compressor problem. Lost the contents of the freezer Freezer was replaced and just this week Mar 03/2008 it appears it has stopped working again with again lost of contents. Has anyone else had problems with this freezer? Scotty
  • Anonymous Nov 24, 2008
    Just got one Nov 22 its now the 24th and the light is out already. Am i going to loose $200 dallers in food now.
  • Anonymous Mar 17, 2014
    Red power light and green light are working but then go out including power light. I have to unplug the freezer and then plug it back in for it to start working again
    Problem Solver:
  • 11 Answers
Could be a possible short in the electrical
Posted on Jan 25, 2008
Does the green light come on after freezer is turned back on?
if you turn the freezer off for some time then on again the red light has to come on as an indicator for high temperature it goes off by itself when the freezer attains the required temperature according to the thermostat settings ,that is the lower the settings the faster the red light goes off. the orange light indicates super cooling and the green light indicates power supply.if you turn the two lights off and the freezer still works without the green light on that means that the bulb for the green light is faulty and you don,t need to worry
Jan 23, 2013 | Freezers
5 foot chest freezer by HOLIDAY, green light on bottom front not lit,less than one year old
I have the same issue, the green light on the bottom is not lit. Looked in manual and do not see anything about that. Freezer is working otherwise, everything frozen like it should be.
Apr 11, 2012 | Freezers
I have this majic chef freezer about 7 cubic ft. 3 years old turned it off to defrost and when turning it back on it won't get cold?? Compresser is hot so I believe it is working and lights on in front...
I'd let it dry out totally then try it again, some of the electronics may have gotten wet when you defrosted it. Give it a week somewhere warm and dry like a garage. If you didn't attack built up ice in the freezer with a knife while defrosting it it should work after it dries out. Most people end up killing freezers by accidently poking holes in the evap coil while trying to remove built up ice.
Aug 14, 2011 | Magic Chef Chest Freezer MCCF5WBX
Green light does not come on for settings 0 to 4
the ice cream is the clue,if it goes hard then the temp is too low (ice cream best kept at -18C)
either the defrost is not working or interior temp sensor duff.
Mar 26, 2010 | Engel Freezer 22 Qt. Fridge/Freezer
I don't know what the lights mean on my Beko chest freezer. Have just found it defrosted and want to make sure the defrost is off. It is switched on at the mains. What lights should be on? I've lost the...
two reds and green are the auto max freeze on indecators the reds go off one at a time when unit drops to safe temp mode.also means unit needs defrosting manually when too much ice is present.
Feb 03, 2010 | Freezers
BLINKING dE(DEFROST) LIGHT ON OUTSIDE DOOR PANEL OF GE TFX27FH.
look for the manual its usually underneath...remove the grille and look inside. sometimes its taped up
i can help you troubleshoot if you find!
Oct 08, 2009 | Freezers
Red light on not green ...has to be green to freeze up again
Try to unplug it for about 5 minutes, and then plug it back in
Apr 17, 2009 | Freezers
G.E. 20.3 CU FT UPRIGHT FREEZER
Check condenser fan to see if it's working. It's the fan next to compressor
Nov 20, 2017 | GE 20.3 cu. ft. / 575 liter Upright...
Defrost light stays on
Try advancing the defrost timer manually.
Jan 16, 2008 | Freezers
Danby 5.5 cu. ft. / 156 liter Chest Freezer Millenium DCF550W Logo
1,593 people viewed this question
Top Danby Freezers Experts
Dennis Boxerman
Charles T Nevin
Charles T Nevin
kfinlay1969
Level 1 Expert
Are you a Danby Freezer Expert? Answer questions, earn points and help others
