Question about KitchenAid 24 in. KUDI01FLSS Stainless Steel Built-in Dishwasher
I've replaced the heating element and I am replacing the control panel that goes with it. How do I pop the old panel out?
Hi
turn the machine off ..
try to open the screws if one is there.
pull the panal towards u..it will be out..:)
Posted on Dec 10, 2009
My profusion mod eh4604b will not heat
Defective heating element or control
Mar 10, 2018 | Dryers
Tip
How to change the Heating Element in a Kenmore Elite Electric Dryer?
If the dryer is running but not heating,then the heating element needs to be replaced. The procedure is as follows:--- 1) First of all unplug the dryer from wall outlet.
2) Remove the front service panel of the dryer.
3) After the front service panel is removed. You will see the heating element wires and heat shield.
4) Remove the heat shield by plucking the wires out from the heat shield.
5) Also remove the screws holding the heating element.
6) The heating will have to be moved a bit to come out easily. Before removing the heating element out. Please note down the position of old heating element. So while placing the new heating element you don’t face any problem.
7) Replace the element with a new element.
8) Refit all the parts removed while removing the old heating element properly.
These will help. Thanks.
on Mar 20, 2010 | Dryers
Kenmore dishwasher clean button constantly flashing ,washer has been unplugged ???maybe reset itself did not work. 2 yrs old
please follow this steps and fix it. God bless you
Heating Element
If lights are flashing on the control panel, the heating element might have burned out. The heating element heats the water up to operating temperature. After a set amount of time if the temperature isn't reached a light on the control panel might start flashing. The heating element can be checked for continuity with an Ohm meter.
Enter your model number to see parts for your dishwasher.
Help me find my model number
Heating Element Assembly
If lights are flashing on the control panel, the heating element assembly might have burned out. The heating element assembly heats the water up to operating temperature. After a set amount of time if the temperature isn't reached a light on the control panel might start flashing. The heating element assembly can be checked for continuity with an Ohm meter.
Check Fault Codes
If the display lights are flashing and there is an error code in the display window, check the wiring diagram and tech sheet in the dishwasher that will provide information on the fault.
Drain Pump
If lights are flashing on the control panel, the drain pump might not be working properly. For two-wire drain pump motors check them for continuity using an Ohm meter. If it's defective You'll need to replace it. Drain pumps are not repairable.
Touchpad and Control Panel
If the lights are flashing on the display the entire touchpad and control panel assembly might be defective. If the display works but the dishwasher functions are all out of synch, or some of the buttons don't respond properly the entire touchpad and control panel might need to be replaced.
Touchpad
If the display lights are flickering for no reason, the touchpad might need to be replaced. Sometimes when the touchpad is defective the display lights are flashing randomly.
Jul 09, 2013 | Dishwashers
I have the model with three burners and the IR heating panel. Lately, as it is heating up, i hear a pop like the gas went off. i've had it for about 18 months and the heating element is the original...
Regardless of it's age, if it's somewhat dirty or hasn't been cleaned recently, that may be the popping noise you hear. However, if the gas is going out, it's probably the Thermocouple that needs replacing.
Contact your local BBQ's Galore Dealer for that part.
Hope this helps you troubleshoot and solve the problem. Please let me know. Thanks.
May 08, 2011 | Barbeques Galore Turbo STS 4-Burner with...
We just recieved our new kitchenaid heating element for the dishwasher, but it came with an electronic control or circuit board thing, and there is a note that both must be installed. We easily replaced...
The control goes in the door...it is easy to get to.
Just take the screws out of the inside panel of the door, they are around the outside edge of the interior of the door. The panel will then lift off and the control will be near the top on the inside.
Make sure the power is turned off to the dishwasher and then one by one remove the wires from the old board and place them on the new board. then remove the old board and fasten in the new one. replace the panel and then give it a trial run.
Everything should be working just fine but some of the timing will be a bit different.
heatman101
Apr 21, 2011 | KitchenAid Dishwashers
GE Profile PK916, Convc. elements stays on high
he is right in what he says the heating element is feed from the main control board
Oct 24, 2009 | GE Advantium 120 Convection/Microwave Oven
Push to start switch only works when held in.
Hi, THe control panel has an end cap that needs to be popped off. Just pull the end cap from the top and it should release. Then you will find a screw on each end that needs to be removed. Now the control panel will raise up and rest on the hinges.
This switch should not have an effect on heating.
Remove the front lower front panel and you can test the heating element. Check voltage to the element and you should get 240V. If there is now voltage, check each of the thermostats and the fuse for continuity. If the thermostats or fuse have no continuity, replace it.
I hope this helps you. Please let me know if I can assist you further.
Vic
May 28, 2009 | Kenmore 659 Electric Dryer
Heating element
The model number you provided suggests that the lint screen is on top of the dryer, right? If so, the heating element can be accessed from behind the dryer by removing the rear panel. Of course, you should know this already since you stated you've already replaced the thermostat and fuse. The heating element is located on the right-hand side as you are looking at the dryer from the rear. There are TWO components on the heater housing. One is the high limit thermostat, one is a thermal cut-out. Are these the components you mentioned replacing? BOTH should read a short (0 ohms) when measuring resistance with the dryer turned off. If you haven't replaced both of them, double check to see if they are both good. The high limit thermostat will be located closest to the ceramic heater connection. The thermal cut-out will be mounted to the heater box. Perform a resistance check of the heating element as well. Measure across the leads of the heating element at the ceramic terminal connection. It should read between 8 - 13 ohms if good. If your readings prove that the heater is bad, it can be removed by using a 5/16" hex drive. The heating element should slide out the bottom of the heater box housing. Sometimes removing the heater box, and then removing the heating element is easier.
Your dryer is also equipped with an electronic cycle control board under the control panel that goes bad from time to time. This also may affect the dryer heating circuits. Inspect the small circuit board for any obvious signs of burned components.
I hope this information is helpful to you. If I'm wrong about your dryer configuration, please post back with comments, so I can give you proper instructions.
CAUTION: Make sure you UNPLUG the dryer prior to making any resistance checks. Dangerous voltages are still present with the dryer turned off.
PS I hope I'm not insulting your intelligence, here. As a rule, I tell everyone this information because some are not as savvy as others.
Feb 23, 2008 | Kenmore 63942 Dryer
KitchenAid 24 in. KUDI01FLSS Stainless Steel Built-in Dishwasher Logo
70 people viewed this question
Top KitchenAid Dishwashers Experts
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
