Question about Frigidaire PLEB27T9DC Electric Double Oven
Cleaned then Dead
Used the self-clean on the upper oven; believe it completed the cycle but now the display is dead and can't get the door to unlock.
Check the house breakers.  Tried employing the door unlock command.  No luck.  Anyone else encounter this problem / have suggestions?
Thank you.
  • nextwave Jan 26, 2008
    Catriver,
    Thank you for the quick reply. Your answer sounds right to me, but I was having trouble locating that part # (found a similar number on one site for $300+). Because the unit was only 13 months old I elected to contact the manufacturer who, in turn, agreed to cover the parts and labor of a service call.
    Service technician from a reputable company comes to the house...can not find anyway to get the top door unlocked. Without getting the top door unlocked, the oven can not be removed from the wall. KNOW OF ANY WAY TO GET THE DOOR UNLOCKED WITHOUT PRYING IT OPENING?
  • Anonymous Apr 02, 2008
    I have a similar problem with a Frigidaire Double wall oven PLEB27T9FCB, The parts diagram shows two Thermal switches 318004900. I was having a problem tell from the wiring diagram if one or both of these would cause the entire control pannel to go dead or if they just break the current to the heating elements in each oven. Can anyone offer any advise on this?
    FYI, the oven went dead after using both ovens at high temps (rarely used them both before) Oven is only about 13 months old.
    President:
  • 878 Answers
Nextwave, looks like you have a safety thermostat (TCO) on the back of the oven. Should have a red and red/white stripe wire going to it. If this opens it will cut the power to the display, part number is 316003606. The hardest part of this gig is pulling the oven out to change the t-stat out. Catriver.
Posted on Jan 19, 2008
6ya staff
SOURCE:
Oven door is locked with food in it how to unlock asap
Hi , Anon !
My name is Ashlynn .
If your oven is locked , here's some ways you can unlock it :
  • 1 Look for a manual lever to unlock the oven. If there is one, it will probably swing back and forth horizontally, just below the upper edge of the oven door.
  • 2 Swing the locking lever, if one is present, all the way to the left. This should unlock the oven. If there is no manual lever to unlock the oven, it may be unlocked using push-button controls.
  • 3 Check to see if the oven is in a self-cleaning cycle, or has just completed a self-cleaning cycle. If so, the door will unlock automatically once the oven has finished the cleaning cycle and cooled completely, which may take several hours. You cannot unlock the oven before it has cooled.
  • 4 Unlock the "Clean/Off" button. Depending on the brand and model of your oven, the button may display both of these designations or just one. If your oven door is locked, but the oven is not warm and is not in a cleaning cycle, unlock it by pressing and holding the "Clean/Off" button.
    But it seems you have food inside so ,
    Press cancel on the cooking cycle , and let it cool to room temperature , and then try to open your oven .
  • Feb 25, 2015 | Maytag Ovens
    We a kitchen aid oven the door was accidentally lock. Can you find out how to open it? Whirlpool owns kitchen aid
  • Look for a manual lever to unlock the oven. If there is one, it will probably swing back and forth horizontally, just below the upper edge of the oven door
  • Swing the locking lever, if one is present, all the way to the left. This should unlock the oven. If there is no manual lever to unlock the oven, it may be unlocked using push-button controls.
  • 3
  • 4
  • Nov 18, 2012 | Ovens
    Cannot unlock oven door
  • Here it is!
  • Check to see if the oven is in a self-cleaning cycle, or has just completed a self-cleaning cycle. If so, the door will unlock automatically once the oven has finished the cleaning cycle and cooled completely, which may take several hours. You cannot unlock the oven before it has cooled.
  • Unlock the "Clean/Off" button. Depending on the brand and model of your oven, the button may display both of these designations or just one. If your oven door is locked, but the oven is not warm and is not in a cleaning cycle, unlock it by pressing and holding the "Clean/Off" button.
    Nov 10, 2011 | Maytag Ovens
    How do i unlock a de dietrich oven?
    In order to unlock the oven you need to perform the following:
    Jun 25, 2011 | De Dietrich Ovens
    Used the self cleaning cycle 24 hrs. ago, but the oven door will not unlock. We tried to run it through another clean cycle but we recieve an E1 error.
    Sorry to read about your problem, I hope this helps you out.
    you may have done a panel lock, so try the first solution.
    To Lock/Unlock Control: Before locking, make sure the ovens, Timer and Timed Cooking are off. Press and hold START/ENTER until a single tone sounds and "Loc," a picture of a lock and "START?" will appear on the oven display, about 5 seconds. Repeat to unlock and remove "Loc" from display.
    To Stop Self-Clean any time:
    Press UPPER OFF, LOWER OFF or OFF/CANCEL. If the oven temperature is too high, the door will remain locked. It will not unlock until the oven cools.
    I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question. take the time to rate us.Thanks and good luck
    Dec 25, 2010 | Whirlpool RBD245PDS Electric Double Oven
    I was able to clear the locked door message, and get over working following steps above, but cannot get the lock mechanism to release, and therefore cannot close the door
    Check out these steps at the following link... http://www.geappliances.com/search/fast/infobase/10004586.htm
    Range - "LOC DOOR" flashes in the display
    If "LOC DOOR" is flashing in the display of your range or oven, and the self-clean cycle has not been selected, follow the steps below to reset your control:
    Motorized Switch
      1. With the door open, locate the door jamb switch on the face of the oven. It will look like a small black post or dowel.
      2. Push it in until the oven cavity light goes off, indicating that the oven believes the door is closed.
      3. While you hold the door jamb switch in this position, complete the following steps.
      4. Press the Clean pad, wait 10 seconds.
      5. When the cycle initiates, press the clear/off or cancel pad immediately to cancel it.
      6. Wait 10 seconds for the display to clear.
      7. The door should unlock and there should not be a need for service.
    Manual Switch
      1. Press the Clean pad.
      2. Close the door.
      3. Slide the latch to lock the door.
      4. Hit the cancel button immediately.
      5. Unlock the door.
    Motorized Switch
    Manual Switch
      2. Close the door.
      5. Unlock the door.
    Nov 24, 2010 | GE Profile JTP18 Electric Single Oven
    Can I clean a TruTemp oven with soap and water without ruining it?
    Yes you could clean it.
    Check few details :-
    t the bottom of this post you will find the web address for your ranges manual and the self clean system is in side this manual.
    How to self clean
    If your model has a door latch, never force the latch handle. Forcing the handle will damage the door lock mechanism.
    The oven door must be closed and all controls set correctly for the cycle to work properly.
    Before a Clean Cycle
    For the first self-clean cycle, we recommend
    venting your kitchen with an open window
    or using a ventilation fan or hood.
    Remove any broiler pan, broiler grid, all
    cookware, probe and any aluminum foil
    from the oven—they cannot withstand the
    high cleaning temperatures.
    NOTE:
    If your oven is equipped with nickel oven
    shelves, remove them before you begin
    the self-clean cycle.
    If your oven is equipped with gray
    porcelain-coated oven shelves, they may
    be left in the oven during the self-clean
    cycle.
    Soil on the front frame of the range and
    outside the gasket on the door will need to
    be cleaned by hand. Clean these areas with
    hot water, soap-filled scouring pads or
    cleansers such as Soft Scrub®. Rinse well
    with clean water and dry.
    Do not clean the gasket. The fiberglass
    material of the oven door gasket cannot
    withstand abrasion. It is essential for the
    gasket to remain intact. If you notice it
    becoming worn or frayed, replace it.
    Wipe up any heavy spillovers on the oven
    bottom.
    Make sure the oven light bulb cover is in
    place and the oven light is off.
    IMPORTANT: The health of some birds
    is extremely sensitive to the fumes given
    off during the self-cleaning cycle of any
    range. Move birds to another well ventilated
    room.
    NOTE: Use caution when opening the upper
    oven after the self-clean cycle has ended.
    The oven may still be hot.
    How to Set the Upper Oven for Cleaning
    On models with Gas/Control Lockout,
    touch and hold the Gas/Control Lockout
    pad for 3 seconds to turn it off.
    NOTE: The surface burners must be turned
    off prior to the self-clean start time.
    If your model has a latch, latch the door.
    Touch the Self Clean pad.
    Using the number pads, enter the
    desired clean time, if a time other than
    4 hours is needed.
    Clean cycle time is normally 4 hours. You can
    change the clean time to any time between
    3 hours and 5 hours, depending on how dirty
    your oven is.
    Touch the Start pad.
    On models without a door latch, the door
    locks automatically. The display will show
    the clean time remaining. It will not be
    possible to open the oven door until the
    temperature drops below the lock
    temperature and the LOCKED DOOR
    light goes off.
    The oven shuts off automatically when the
    clean cycle is complete.
    When the LOCKED DOOR light is off,
    slide the latch handle to the left as far
    as it will go and open the door. If your
    range does not have a latch, the door
    will unlock automatically.
    The words LOCK DOOR will flash and
    the oven control will signal if you set
    the clean cycle and forget to close the
    oven door or forget to latch the door
    on models with a latch.
    To stop a clean cycle, touch the Clear/Off
    pad. When the LOCKED DOOR light goes
    off, indicating the oven has cooled below
    the locking temperature, unlatch the door
    (on models with a latch) and open the door
    How to Delay the Start of Cleaning
    Make sure the clock shows the correct time
    of day.
    the door.
    desired clean time.
    Touch the Delay Start pad. The earliest
    start time you can set will appear in the
    display.
    Using the number pads, enter the time
    of day you want the clean cycle
    to start.
    locks automatically. The display will show the
    start time. It will not be possible to open the
    oven door until the temperature drops below
    the lock temperature and the LOCKED DOOR
    light goes off.
    The words LOCK DOOR will flash and the
    oven control will signal if you set the clean
    cycle and forget to close the oven door or
    forget to latch the door on models with
    a latch.
    pad
    (on models with a latch) and open the door.
    After a Clean Cycle
    You may notice some white ash in the oven.
    Wipe it up with a damp cloth after the
    oven cools.
    If white spots remain, remove them with a
    soap-filled scouring pad and rinse thoroughly
    with a vinegar and water mixture.
    These deposits are usually a salt residue
    that cannot be removed by the clean cycle.
    If the oven is not clean after one clean cycle,
    repeat the cycle.
    You cannot set the oven for cooking until
    the oven is cool enough for the door to
    unlock.
    While the oven is self-cleaning, you can
    touch the Clock pad to display the time
    of day. To return to the clean countdown,
    touch the Cooking Time pad.
    If the shelves become hard to slide, apply a
    small amount of vegetable oil or cooking oil
    to a paper towel and wipe the edges of the
    oven shelves with the paper towel.
    Hope i helped you.
    Thanks for using ' Fixya ' and have a nice day!!
    Sep 05, 2009 | GE Profile JTP18 Electric Single Oven
    HOW TO UNLOCK THE OVEN DOOR FOR THE DIETRICH OVEN MODEL DOP440BE1
    Thank you for contacting Fixya.com
    Aug 07, 2009 | De Dietrich Ovens
    Dead Whirlpool Double Oven
    This happened to us the first time we used the self-cleaning feature. The repairman said we had to replace the whole electronic panel -- but when he put in the new panel it didn't work either. It turned out he just needed to replace the oven shutdown thermal fuse I believe. We finally got up enough courage to try the self-cleaning again and the exact thing happened. The door is locked and the electronic panel is dead again. So when we get it fixed we will never use the self-clean again.
    Nov 05, 2008 | Whirlpool RBD305PD Electric Double Oven
    Oven wont work after self clean
    I have a Whirlpool MOD. RBS275PDB17 single electric self-cleaning oven; although the manual is generic, it specifies, "When the cycle is completed and the oven cools, "End" will appear on the lower oven display and "LOCKED' will disappear" and "To Stop Self-Clean any time: Press UPPER/OFF, LOWER/OFF or OFF/CANCEL. If the oven temperature is too high, the door will remain locked. It will not unlock until the oven cools." Has your oven had time to cool?
    Jun 13, 2008 | Whirlpool RBS275PD Electric Single Oven
    Frigidaire PLEB27T9DC Electric Double Oven Logo
    114 people viewed this question
    Top Frigidaire Ovens Experts
    Marvin
    Marvin
    Bruce Denton
    Alan Chouinard
    Are you a Frigidaire Oven Expert? Answer questions, earn points and help others
