Question about HP Compaq Presario V2000 Notebook
My compaq presario v2000 has a fuzzy screen and the colors on the backgrounds that are supposed to be white are like and aqua green color and i was just wondering how to fix it. Is there something i can download?
    Sniper:
  • 65 Answers
First thing you want to try is getting the laptop to display on an external monitor. If it doesn't replicate the same issues then you know it is either the screen or the inverter/backlight.
if it does then it is most likely a motherboard issue and sadly can not be fixed outside of replacing the board.
Posted on Dec 10, 2009
SOURCE:
My hitachi 53udx10b was supposedly just serviced but the picture is extremely blue. Have tried adjusting picture to no avail. Help.
I am going to tell you a simple thing to do to know what your problem may be.
With the set on turn the color all the way to zero. Go to a channel if you can that is in black and white. What color is the screen?
If the answer is that it is blue in the background whoever serviced the set did not and could have removed front speaker grill and inspection plate behind it; there is a black plastic block with three screen controls (red,green,blue) and 3 focus controls (do not touch the focus ones.)
I suspect if the blue screen is there a slight adjustment of the blue screen down will correct this.
The picture with the color at zero should be black and white or gray. If blue is background color it will also be with color.
This is called gray scale; picture with color off has to be gray or black and white.
Before you rate this solution if you have questions make a comment right here and I will advise you.
SD TECH
Jun 29, 2011 | Hitachi 53UDX10B 53" Rear Projection...
How to make folder in dos command how to rename the folder in dos command how to change the font color of the dos command
To make a folder type: mkdir FOLDER_NAME Where FOLDER_NAME is the name that you want to give your folder.
To rename a folder type: rename FOLDER_OLDNAME FOLDER_NEWNAME Where FOLDER_OLDNAME is the old name of the folder and FOLDER_NEWNAME is the new name of the folder.
To change your font colour, use the color command by typing: color XY Where X is a hex value representing the colour of the background of your window and Y is the colour of your.
The values that you can use for X and Y are:
0-black
1-blue
2-green
3-aqua
4-red
5-purple
6-yellow
7-white
8-grey
9-light blue
a-light green
blight aqua
c-light red
d-light purple
e-light yellow
f-bright white
Mar 25, 2011 | Computers & Internet
I have a brand new compaq presario laptop and all of a sudden upon start up the screen is fuzzy and scrambled and the colors are a very pink undertone. How do I fix this? I have checked the color...
Take it back to where you purchased it maybe they will fix it free of charge if its new because the display panel is bad or the video inverter is faulty.
Dec 27, 2010 | Compaq Presario Notebook
I installed an LCW1943TB on my Compaq Presario. When it turns on the background is yellow for my active screens. The desktop also has a yellow tint to it. What needs to me changed to make it white?
right click your desktop back round go2 properties, go2 desktop change your back round to any color or image you like, and go2 themes and select the color tone for windows its really simple.
Feb 23, 2010 | Computers & Internet
Presario v2000 won't show the color black
hi
well actually there are no such manuals available as they suppose this works belongs to engineers only.
but i cn suggest you to read this manual before u try fix it up.
http://support.ts.fujitsu.com/com/support/manuals.html
thnx
dun forget to rate me
Jul 01, 2009 | HP Compaq Presario V2000 Notebook
Display blinking and turn in to white color with black lines
no its not a driver you have a video chip getting ready to fail.on the v2000 it intergrated in to the mother board. soon you will be joining many other compaq v2000 and m2000 owners in the search for a mother board compaq has updated part numbers it a whole differant board for these units due to having a common failure rate of the original mother boards.Compaq know there was a over heating of the video chip that leads to failure but has not offered any assistance to there customers. john@johnslaptops.com
Feb 17, 2009 | HP Compaq Presario V2000 Notebook
Display Problem Black turns Red
sounds like you have a loose connection ....either into the screen or into the motherboard....the connection between board and screen runs through the hinge brackets and often comes loose after machine has been opened and closed a lot.....need to be comfortable opening up laptops to check the cables as it can be tricky to get to the back of the screen where the end of the ribbon cable is..
Dec 13, 2008 | HP Compaq Presario V2000 Notebook
Compaq Presario C500
hi
if your monitor has degauss button press it.your pro is solved.change your disply resolution and color format to 32bit.
make sure your display driver is ready
Mar 20, 2008 | Computers & Internet
No booting for compac presario
do you hear your power on self test beep? check your video card. the monitor has a light on it it should be green if its working. what color is it? check all of your video plugins. It sounds like its booting but without video who knows
I’m happy to assist further over the phone at https://www.6ya.com/expert/james_1cb31da1bc8c6102
Jan 02, 2008 | HP Compaq Presario V2000 Notebook
HP Compaq Presario V2000 Notebook Logo
194 people viewed this question
Top HP Computers & Internet Experts
Thomas F. Schneider
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
