Question about Microsoft Comfort Optical Mouse 3000 (1-Pack) (VVSC393731)
Mouse Problem- Not Working
My mouse was plugged into my USB port on my laptop, and was working fine, when all of a sudden it stopped working. I tried switching ports, but Windows told me the device had malfunctioned.
(Microsoft Comfort Optical Mouse 3000)
  • 733 Answers
I should reinstal his driver just to make sure is working properly,you can check in start-my computer-rightclick manage -device manager- usb then click on action button and Scan for hardware changes.
Posted on Dec 10, 2009
My mouse suddenly stopped working. I checked the batteries and they are fine. I turned it off and on and I checked the plugin to the USB port. Not sure what else to do
1.Are there any lights on the mouse when it is on?If yes,it is a connectivity problem.If no,the mouse i dead.
If it is a connectivity problem:
-check if there is sound when you connect mouse to pc,if not change usb port and check it with some other peripheral to see if the usb port works -Check for usb ports drivers and try again
Mar 18, 2017 | The Computers & Internet
My Genius Traveler 6000x wireless mouse suddenly stopped working
Double check the batteries, although the lights work and the computer sees it, the voltage could drop low enough to stop the sensors.
next, try another USB device in that plug. USB port can go bad.
If the port works, it could be the wireless USB connector starting to fail, if they are bumped to hard sideways it can cause loose connections internally.
then, you might just need to update drivers. Computer update s can conflict with drivers cause devices toss top working.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/chris_e1fb7ef6a5bdb086
May 20, 2014 | Genius "Wireless Mouse - Traveler 6000X,...
My Acer laptop ASPIRE 5738 does not recognise USB Mouse, previously it is working fine. But if I attach other USB device it is working. It is only problem with USB mouse.
Do you have another USB mouse around that you can test with? It sounds like the USB port on your laptop is fine but the mouse is the issue.
If you can find a spare around and test or alternatively you could try to bring the laptop to a friends house and borrow their USB mouse temporarily.
My guess is that the other mouse will work fine. How many USB ports does this computer have? You can also try changing which port you plug it in to.
May 12, 2011 | Acer Aspire One PC Notebook
My arc mouse suddenly stopped working on my Toshiba Satellite L650 yesterday though i tried it with 2 other laptops it only doesn't work on mine but the keyboard curser is working, What do I do to make my...
Try moving the arc mouse USB dongle to another USB port on your Toshiba Satellite L650. If the mouse works on the other port, then the first port is the problem. Use Control Panel's Device Manager to further diagnose the port problem.
Apr 06, 2011 | Microsoft Computers & Internet
Suddenly my mouse stopped working and the red light stop on it as well. What shall I do?
dear mario
it seems to be a problem with the mouse cable.
shutdown your computer and remove the mouse cable and replug the mouse again.
now start your computer and see is it working now
if no , then if you have a USB mouse try using it on another USB port
else you have to purchase a new mouse and plug it in.
thanks
Gagan
Mar 17, 2011 | Ideazon Reaper ZMS 1000 Mouse
Mouse suddenly stopped working
1: Make sure the battery or batteries in your mouse are good.
2: If there is a USB dongle plugged into a USB port on your computer, unplug it, wait 3 or 4 seconds and plug it back in.
3: If the above two steps don't work, shut down your computer completely and start it back up again.
Your problem should be solved:
USB dongle
Sep 21, 2017 | Gigabyte GMW9CRD Mouse
My mouse was just working and all of a sudden it stopped, I changed the batteries, reset the small button on the bottom and also pushed the button on the plug in portion. Help Allen
I have a miscrosoft wireless laser mouse 6000, and it also stopped working on my laptop. I changed the battery, still not working. I tested the battery in another device, and it was good. I moved the mouse to another computer, and it did not work. The light on the usb connector was lit. [No changes at all to my laptop.]. It seemed like there was no power to the mouse, and I looked at the contacts inside the mouse. The contact just inside the battery opening appeared to be bent down away from the contact on the battery tray. So, I pulled it up a little so it would connect when the battery drawer closed, and (after tweaking it a couple of times), it finally worked!
Dec 08, 2009 | Microsoft Wireless Laser Mouse 6000 v2.0
I cant get any mouse to work on my dell laptop.
see the very first thing is that what u can try is that try and connect the same mouse that u had and that had worked and if works then the prob is with the mouse that u have right now and if that also doesnt work then the usb port on the laptop has gone bad and u need to replace the motherboard of the computer but before replacing the motherboard try and connect some other usb device on the same usb port.........
Jan 25, 2009 | KEIO PS2 Optical Scroll Mouse
Usb not recognizing the mouse or flash drive
have you tryed the devices with out the cooling pad? USB ports have a limit on the amout of current they are able to source and it could be that the cooling pad is drawing to much current.
Regards
Nick
Oct 26, 2008 | Acer Aspire 9503EWSMi Notebook
Microsoft Comfort Optical Mouse 3000 (1-Pack) (VVSC393731) Logo
426 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Alun Cox
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
