I bent the hinge on the ovendoor the oven door does not close properly. How do i replace the hinges
  • 478 Answers
Take side panels off
Posted on Dec 10, 2009
OvenDoor came partly off hinges. One side only.
Most oven doors are made to be removed and on most, the hinges have locking clips which hold the hinge so you can remove the door. Have a close look at the hinge which is still in the door and see if the hinge that came out is the same. You may have to get someone to hold the hinge in place while you refit the door.
Jan 28, 2018 | Ovens
How to set up ovendoor
Check to see if you can adjust the hinges, it sounds like you also may not have the door completely set on the hinges
May 30, 2014 | Fisher Paykel Fisher & Paykel OB24SDPX1...
Why is door still open at top after replacing door hinges on Whirlpool WFE510S0AW0
Well, I assume you have the door hinge clips in the right position,
and the door is seated properly with that 2mm slot that sits on the hinge receivers. If hinges are replaced, then it must be hinge receivers.If the door is crooked, moving the hinge receiver will align the door. Besides hinge receivers should be replaced first, before the hinges, that in my experience rarely break
I dont like the bent twisted story. I bet the little plastic U-roller in the hinge receiver is worn down or cracked. Fix is to replace the hinge receiver (a secondhand one is in plentiful supply) - or find a look alike roller and fit it. Cord pully's at the local hardware store may fit, window slider tracks, or even coins with a small 1 inch by 4mm bolt as an axle will do the trick.
Still not sure. Remove the dorr using instructions, and set aside.
Remove hinge receivers from each side. Are the little wheels in there good, or wobly, worn of missing?
Problem Fixed
May 22, 2014 | Whirlpool RF378LXKS Electric Kitchen Range
Oven door won't quite close tightly. I can push it about another 1/4 inch to close it completely.
You need to replace the hinges in the door. Go online to a spares website and enter make and model and order new hinges. You can replace them by unhooking the door, just takes a little effort, you might need to flick back latch on hinge and lift out. Remove inner door panel, usually 4 screws and remove. then change hinges. The 2 big pieces are the hinges.
  • images?q=tbn:and9gcsg1plmaxnucdapg-xpimmjauz_p4kgblmyf6iotcmgyh-hv4v3
Mar 09, 2011 | Ovens
GE Oven door lock 'engaged' while door was open and door will not close - how do I release the lock?
If your oven door has gotten bent or warped (maybe you rested something heavy on it...), you need to remove the door, disassemble it, and straighten it. You can lift most oven doors off of their hinges by opening the door several inches to its first "stop," and lifting the entire door straight up. If the hinges have become worn, damaged, or bent, you probably need to replace them. We recommend replacing both hinges at the same time, to prevent uneven wear of the undamaged hinge.
Dec 06, 2010 | GE JTP27 Electric Double Oven
Eog 6330 oven door does not fully close ie small gap at top unless you hold door closed are hinges damaged or bent?
you will have to replace both left & right hinges / this should correct problem .. mm
Jul 12, 2010 | Electrolux Ovens
Oven door not closing properly
If it is a drop down door with hinges on the bootom of the oven door, then it is likely to be weak door hinge springs, the usual solution is to replace both hinges.
If it is a swing open door, then the problem is related to a worn or broken door catch, or worn striker pin.
Apr 13, 2010 | Ovens
We have a 30 in prostyle electric double wall oven - the oven takes forever to preheat and the doors do not seal tightly when they are closed.
Hello- Many ovens use spring-loaded hinges to carry the weight of the door. Over time, these springs weaken or the hinge gets bent just enough to not fully close door. The door gasket can also become flat and stiff, compounding problem. Any small gap releases heated air, and oven will not heat up properly. Replacing the door springs should solve problem.- Thanks -Ed
Mar 14, 2010 | Jenn-Air 30 in. Pro-Style Electric Single...
Ovendoor not closing for tight seal...
You should feel the door pull closed when you as you lift it and get near the closed position.
There is some spring linkage associated with the hinge pins at the bottom sides of the oven.
I cannot find the oven you indicated, but I did find exploded views and parts list of the topic post oven on the SearsPartsDirect website.
Jan 28, 2009 | Kenmore 99123 Electric Kitchen Range
14 people viewed this question
k24674
Marvin
Marvin
