Location of s/pdif out pins on a ASUS P5LP-LE in a HP pavilion Leonite-GL8E
  • 478 Answers
One of 2 places bottom rear of board or right in the middle of board in the back near the audio plugs
Posted on Dec 10, 2009
  • Keith Marks Dec 10, 2009
    one of 2 places bottom rear of board or right in the middle of board in the back near the audio plugs
Wiring diagraM for hp a6120n
product specs are here
http://h10025.www1.hp.com/ewfrf/wc/document?cc=uk&dlc=en&docname=c01048279&lc=en&jumpid=reg_r1002_uken_c-001_title_r0001
motherboard is
  • Motherboard Name: [Asus] P5LP-LE
  • HP/Compaq motherboard name: Leonite2-GL8E
    HP motherboards specs:
    http://h10025.www1.hp.com/ewfrf/wc/document?cc=uk&dlc=en&docname=c01080268&lc=en&jumpid=reg_r1002_uken_c-001_title_r0001
    You might try here
    http://www.ps2netdrivers.net/drivers/hp.p5lp-le/ for a manual which might tell you what you need to know.
    BUT this is the one. Apart from much other useful information it contains mainboard pin-out information for connection to the case (I think these are pretty standard anyway)
    http://www.ctechinfo.net/documentation/manuals/leonite_manual.pdf
    (The trouble is this is a motherboard made by Asus for HP. As such Asus do not provide any information about it whatsoever. HP information if you can find it is not sufficiently detailed)
    18.December.2014
  • Sep 26, 2014 | HP Pavilion A6120N PC Desktop
    Asus motherboard manual
    http://www.manualslib.com/manual/449087/Asus-Leonite-P5lp-Le.html
    Jun 06, 2014 | ASUS Computers & Internet
    What processor does the board support
    The Pavillion A6120N Desktop PC has a P5LP-LE (Leonite) motherboard, meaning that any of the following will work for you:
    Socket type: 775
    Motherboard supports the following processor upgrades:
    • Core 2 Duo E6x00
    • Core 2 Duo E4x00
    • Pentium D 9x0 Dual Core
    • Pentium D 8xx Dual Core
    • Pentium 4 6x1 series
    • Celeron D 3xx series
    Dec 22, 2013 | HP Pavilion A6120N PC Desktop
    I need the user guide for a P5LP-LE motherboard
    Jan 24, 2013 | HP Pavilion Computers & Internet
    I have a hp m7267c with the asus p5lp-le litium ul8e trying to do clean install but cannot find drivers help
    HP Pavilion M7267c,
    http://h10025.www1.hp.com/ewfrf/wc/product?cc=us&lc=en&dlc=en&product=1154490
    Mobo:
    http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00379616&tmp_task=prodinfoCategory&cc=us&dlc=en&lc=en&product=1154490
    Driver download page. Choose your Operating System,
    http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?cc=us&dlc=en&lc=en&product=1154490&
    Do Not forget.
    You have to download AND install the drivers.
    Need guidance post back in a Comment.
    [A lot of people download the drivers, but forget, or do not know, you have to go to the folder the drivers are downloaded to, and then install them ]
    Regards,
    joecoolvette
    Aug 04, 2012 | ASUS P5LP-LE Motherboard
    I am triying to locate S/PDIF out pin for Asus p5lp-le motherboard. Thanks Ghirmai
    Do you mean the solder point? The S/ PDIF connector / jack is wired directly to the motherboard and is orange in color. Not quite sure what you're asking. This is a coaxial connector and the solder pin connection would be easily found with a continuity checker, but again you're not too clear in what you're asking. Btw, if this helps, please don't forget to provide a rating. Here are the specs for your motherboard:
    http://h10025.www1.hp.com/ewfrf/wc/document?lc=en&dlc=en&cc=us&docname=c00379616
    Jan 13, 2011 | HP Computers & Internet
    Computer won't power up unless I jump pin 16 and 17 at the 24 pin connector at the motherboard. After I jump it, it runs till I shut it down. It will power up on a few more start ups but soon goes back to...
    a real answer. not bs above.
    you proved the PSU is ok, why go there?
    the why this works is the chip called South bridge.
    does all this (this is how (also) the windows start button and shut off works, called SOFT POWER OFF)
    the button on the front panel is a N.O SPST switch.
    normally open momentary and shorts a specific and non world standard pin on that mobo to ground, (adjacent pin)
    this sends a logic zero state (0v) to the South bridge
    then it turns on a transistor on that mobo and that grounds pin 16 to PSU, and PSU magcially turns on.,
    end theory101....
    the problem can be ; the switch is plugged in wrong. or bad.
    HP uses vast numbers of MOBO in PCs so have all different pinouts. and hard super hard to trace and learn that.!
    all mine are keyed, and the mobo is silk-screened painted, Front panel.
    the other possible is that the PSU is not putting out standby power
    on pin 9, with PSU plugged into the wall pin 9 must be at 5vdc.
    if not the South Bridge will be dead.
    as will the power switch it supports
    http://www.pcdied.com/power.html
    The South bridge runs power. managment.
    the 945P must have PSU standby power and the switch most reach its power on pin, or there will be no working switch ever.
    The PC can also force the PSU off if one of the onboard
    power regulators are reading wrong (say too high)
    The power management is complex, but not that one pin,.below.
    Power management,
    wake on LAN, sleep, hibernate. and more.
    but all we care is the power switch but if the above features work then the switch is bad, and why I mention that.
    my PC can even self turn on at 6am if I want, (a bios features) self power on...
    now the list of simple..tests,etc.
    1: PSU pin 9 must be 5vdc at all times, wall plug aC connected.
    and if read of PSU has a switch, set to logic 1 , (1/0 labled)
    means on.
    2: the correct working switch in front panel,
    2b< that switch must be on the correct jack on the mobo and not off one pin or some other ERROR. there.
    3:the PSU good ... some are not, (complex reasons) skip i will.
    4: the MOBO most be good, (and not overheated)
    Switch.
    will the PSU turn on if dvd/cd drive and HDD drive cables pulled.?
    even pull RAM. sticks? it will beep like mad but will turn on.
    and be dead but turns on. like that. well most do.
    5: jump the pin below, does that turn on the PC? as it must!
    A DT PC 12 years old now.
    m7480n this PC is now retired at HP means zero support.
    no service book but it lacked the power jack info in most cases
    DATA: (first know what is there, the mobo is clearly labeled. look?
    this is the best search I did for you,at HP real, yours
    • Manufacturer: Asus
    • Motherboard Name: P5LP-LE
    • HP/Compaq motherboard name: Emery-UL8E
    ive owned many P5 in my life, not now but am an ASUS guy.
    but this old board we can do research on it,
    I like HP and HP likes ASUS as do I. both.
    knowing this fact
    we see
    Asus Leonite P5LP-LE User Manual
    then we find the book on it next like this, (took me 1second )
    page 5 shows layout
    https://www.manualslib.com/download/449087/Asus-Leonite-P5lp-Le.html
    bottom right shows, (F_panel) Bingo, on jack.
    page 25 covers that jack
    so pull the jack there pull plug from jack
    then jump pin gnd /pwr pins with screw driver tip.
    if PC turns on the switch was bad or plugged in wrong,
    if not the PSU is dead, Standby power is dead, pin 9
    p25-0kaf4dlf4nbtfyx5ejcudwbi-5-0.jpg Asus books always show all this, but never HP for some odd reason. (details like this)
    good luck
    Nov 07, 2017 | HP Pavilion m7480n (882780389410) PC...
    I can't Install Windows 7, Indicate a Hardware problem, I don't know if this mother board is compactible with Windows 7 (HP Leonite2-GL8E). Is copmpatible or not?
    if you don't have a driver intended for windows 7, i suggest you to install windows xp you can download driver at internet web site.
    Aug 10, 2010 | ASUS P5LP-LE Motherboard
    Asus P5LP LE Emery motherboard MANUAL
    does your case have set pin slot sets your case manual should tell how to install your motherboard type hope this helps
    Jan 04, 2010 | ASUS Computers & Internet
    Computers & Internet Logo
    281 people viewed this question
    David Payne
    David Payne
