Question about Casio Exilim EX-S500 Digital Camera
When i use the video setting on High Speed, the background is dark unlike the normal setting where the background is normal
    Brigadier General:
  • 11,967 Answers
Think about it...when on high speed, the shutter isn't open as long as when on "normal", therefore, less light hits the sensor. You could try raising the ISO setting or raising the exposure compensation setting for more light.
Posted on Dec 10, 2009
I have a Nikon d200 and need to take sports photos in a basketball court The sport is very fast moving. What should I set the camera to. Lately the photos are dark and or blurry
You want the fastest shutter speed you can get and the largest aperture possible.
If you're close enough and it's allowed, use the flash. The flash will freeze the action. However, it's likely to give you a dark background instead of a blurry background.
If not, use the Aperture Priority mode. Open the lens to its maximum aperture (smallest f/number). This will give you the fastest shutter speed for the existing lighting conditions. The fast shutter speed will freeze the action and the large aperture will blur the background, though the amount of freezing may be limited if the lighting is relatively dark, as in a high school gym.
Be aware that if you're shooting indoors you're going up against the laws of physics. The human eye can adapt much better than any camera. A high school gym will appear light enough once you've been inside for a few minutes, but it is much, much darker than a bright day outdoors.
Apr 28, 2012 | Nikon D200 Digital Camera with 18-200mm...
I am running Windows 7 (32 bit) and am seeing ghosting behind the fonts as I scroll them with smooth-scrolling in Firefox and Thunderbird. It is especially visible when viewing on a dark background. I have...
Hello!
First things first!
Usually these problems, its related to monitor or monitor drivers, check the cable conection to the back of monitor, if is HDMI or analog, that is well conected!
other may be bad power cap, or damage, or high freq. static in lines.
hope these hints, helps
Carl
Jan 06, 2011 | HP GeForce 8400GS Graphics Card - nVIDIA...
Why dose my Lg KU990i high speed camera go very dark when im trying to rec video in high speed??
Probably because the frame exposure time is much shorter so it can''t expose the CCD as long.
Try processing the video with software to lighten after capture.
Dec 28, 2009 | LG KU990 Viewty
My webcam picture is so dark,how can I whiten it?
open the setting and change the background to white or to the high number.
Jun 02, 2009 | Logitech Webcam
Ultravision image dark
Good Day, tfarmer;
Since you have replaced the lamp, which is the normal cause for a dark picture. Have you checked your video settings?
The brightness level should be set at about 55 to 60%, the contrast should be set at about 90% and the video temp should be at normal or high.
If all these are set about this way, then I would think that the light engine might be going bad.
Good Luck, big IRISH.
Jul 29, 2008 | Hitachi UltraVision CineForm 55VG825 55"...
TV took a dump
Sounds like a problem with the Hyper Board.
Dec 13, 2007 | Toshiba 65H81 65" Rear Projection...
CANON Rebel RTI Outdoor pictures are dark
learning to use light metering correctly can have its challenge.
the manual will guide you on how to set up to read light from the subject. spot metering a dark area will cause general overexposure, or a washed out look. spot metering a bright area will cause a dark image. if you are on spot meter and shoot two people standing together against a bright lit background, your meter will see between them if they are centered, and read all that bright background, setting the camera to a less sensitive combination of aperture / shutter speed, resulting in a dark image. use field averaging meter setting and be sure you are metering the subject and not the background. try shooting a wall that is fairly clear of other colors and uniform it light hitting it, you should have a correctly exposed image. since it works in other modes (at least 1, anyway) then it is unlikely you have an exposure compensation issue. that is the only other non defect issue that would cause your problem.
once you confirm that you have these settings correct and still get a dark image, its time to have it serviced.
good luck
mark
Sep 01, 2007 | Canon EOS 400D / Rebel XTi Digital Camera...
Strange silhouetting and a vertical strip
If A vertical strip appears on the screen when recording a dark background or the subject is blooming or silhouetting, you need to adjust the BLC. * The contrast between the subject and the background is too great for the camcorder to operate normally. * Make the background brighter to reduce the contrast or use the BLC function while you are recording in a brighter environment. BLC (Back light Compensation) * BLC works in CAMERA/M.REC mode.B * Back lighting exists when the subject is darker than the background: 1. The subject is in front of a window. 2. The person to be recorded is wearing white or shiny clothes and is placed against a bright background; the person?s face is too dark to distinguish his/her features. 3. The subject is outdoors and the background is overcast. 4. The light sources are too bright. 5. The subject is against a snowy background. 1. Set the power switch to CAMERA mode. 2. Press the BLC button. Normal - BLC - Normal BLC enhances the subject. Notes: * When NITE PIX to set to ON, the BLC function does not work. * The BLC function will not operate in EASY mode.
Sep 07, 2005 | Samsung DouCam VP-D5000i Mini DV Digital...
Casio Exilim EX-S500 Digital Camera Logo
Top Casio Cameras Experts
mohamed salim shaikh
pontelemon
pontelemon
Are you a Casio Camera Expert? Answer questions, earn points and help others
