Question about Frigidaire ATF6000ES Front Load Washer
There is a knocking coming from the bottom of the wash machine i cant see what it is to get to the problem. How do i disasemble the wash machine to fix the problem
You need to prop up the machine with a 2 x 4 block. Then unscrew the bottom panel from the bottom. It is probably your shocks (just FYI) I just replaced mine.
Posted on Dec 11, 2009
A knocking noise during agitation wash cycle
could be a bad counter balance , u can remove the front panel and run a spin or wash cycle and listen to where its coming from so u don't have to replace all the balancers. on some models theres a heavy ceramic weight at bottom that at times goes bad and throws it off balance, just run it and look where noise is coming from
Jul 25, 2014 | Maytag Performa PAV2200
Zanussi washing machine
Open the door and grab the inside drum top and bottom, Wiggle back and forward, if it makes a knocking sound then either the bearings are worn or the drum has become detached from the bearing mount.
Mar 08, 2012 | Zanussi Washing Machines
F 2 is flashing
Check the drain pump filter for foreign objects. Video.
F-2 Long Drain
If the drain time exceeds eight minutes, the water valves are turned off
and "F/02" is flashed. Press PAUSE/CANCEL two times to clear the
Service manual
Each model Duet has its own set of errors and solutions in a jacket behind the service panel. Th service manual will help in disasembly. Use your tech sheet to do the diagnostics and party on.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Jul 06, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Hi, I have a Hotpoint Aquarius F545 washing machine, the door handle has snapped off, so I cant open it. Ive order my new one and its easy to fit, but I have no idea how to open the washer door without...
1. Remove the lower panel under the door by loosening the three screws under the bottom edge on the front of the washer. HINT: If you prop up the front feet of the washer with some small blocks of wood, this will make access to the screws much easier.
2. With the screws removed, the lower panel should drop down then come off. If the panel sticks, a light tap on either side will knock it loose.
3. Reach your hand up inside the washer behind the front casing on the right-hand side. This is where the door latch assembly is located.
4. At the bottom of the door latch assembly is a small pull tab. This is the manual release for the door. Pull the tab straight down and the door will come open.
Thanks for using FixYa
Mar 02, 2011 | Hotpoint Aquarius WF000 Front Load Washer
The drum inside our front loader washing machine is loose and makes a horrible knocking noise while in the spin cycles. How can this be fixed?
it could be fixed,,, but it sounds like drum bearings worn out thats not going to be cheep,,,or it could be the steady spring/s if one has fell off or just snaped the other is trying to hold all the weight of the drum and it cant do all the work so the drum swings around on the spin cycle battering the inside of the washer,,,this will pull off the water pipes and wiring to other parts like the motor,,,you could wip the top or back off and look inside you will see if the spring has come off,,it will be laying in the bottom
Jul 03, 2010 | Washing Machines
Loud knocking during finial spin cycle
replace the balance springs from the bottom of the tub to the frame there weak and letting the tub rock
Jan 18, 2010 | Washing Machines
Loud knocking sound when in wash cycle GEWDSR2080
After taking off the front cover, look up at the top of the tub just under the lid. there should be a thick rubber strap at each corner of the machine tying in the tub to the top. These are called dampening straps. One or more may be broken. I usually replace all four if I do one.
Nov 13, 2009 | GE WDSR2080D Top Load Washer
Kenmore HE2 Plus Front Washer knocks very loud on spin cycle and a belt or something has been coming out in pieces for the last few weeks
I just took the back off my older kenmore front loader and discovered that the concrete counter weight had come off the drum and fallen to the bottom of the machine. Reattached it and knocking has stopped, lucky it didn't trash the machine as it is normally attached to the top of the drum.
Oct 13, 2009 | Kenmore HE2 Plus Front Load Washer
Knocking
you can remove the lower acess panel (3 screws across the bottom of machine)i would then check to make sure all 4 of the suspension supports are still connected, if so perhaps you can run with panel off to get a better understanding as to where the knock is coming from.(topp panel can be removed (3 screws across the top back) toalso look from atop for source of noise.
Oct 28, 2008 | Kenmore Elite 45986 Front Load Washer
Frigidaire ATF6000ES Front Load Washer Logo
61 people viewed this question
Top Frigidaire Washing Machines Experts
Gerry Harvey
Gerry Harvey
Jason Harris
Jason Harris
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
