Question about Whirlpool Inglis IP8200 Dryer
My Inglis dryer has condensation on the inside of
My brand new Inglis dryer has condensation on the inside of it
    Scholar:
  • 49 Answers
Normally condensation on the inside of a dryer is due to a pinched or plugged vent hose i have had this happen also when the dryer vent is very short and goes outside where the temperater outside is cold and moisture will condense on inside of dryer
if you live in a colder location there is a vent system
that you can install that will allow you to keep heat inside not reccomended for gas dryer the vent cap on the outside could also be missing the flap that stop air from going back into dryer hope one of these suggestions i a solution to your problem
Posted on Dec 10, 2009
My whirlpool inglis ele dryer will not come on ???
1_2_2012_1_10_24_pm.jpgThe door swtch is a known weak point in the Whirlpool Inglis.
Jan 02, 2012 | Whirlpool Inglis IP8200 Dryer
We are having to run the dryer several times for med. load to day and I just noticed a slight burning smell. Can this be repaired and at wht possibl cost?
i would guess it is lint that is trapped inside the dryer, you will need to take the cabinet off and clean with a brush and a vacuum:
http://www.partselect.com/dryer+new-whirlpool-open-cabinet+repair.htm
Jan 09, 2011 | Whirlpool Inglis IP8200 Dryer
Brand new vented dryer causing condensation in
Hello, I would recheck the exhaust hose connections, as it sounds as if you've either got some holes in the vent hose/line or the connections are not fully around the dryer exhaust vent, etc.
You might also want to look at the dryer to see if the internal exhaust pipe came loose during transport and installation. It might be possible that the exhaust vent pipe inside the dryer is loose or off the fitting. An easy way to check this is to remove the exhaust pipe from the back of the dryer and (with the dryer unplugged from the electric outlet!) check by looking into the back vent on the dryer. You can also feel inside to see if it's loose, etc. Just be carefull as the metal pipe could have sharp edges, so wear some gloves to be safe.
As this is also a new dryer, you might also contact the place where you purchased it, as there might be an quality issue that they've received a service bulletin on and could provide you with further assistance.
I hope you find this Very Helpful and best regards!
Dec 14, 2009 | Tricity Bendix Dryers
I have a brand new dishwasher. it doesn't seem to
The reason that the dishwasher is not drying completely is that newer model dishwashers do not have as powerful a heating element to dry the dishes. This is for several reasons mainly due to the manufacturer attempting to reduce power consumption by the machine. The condensation is caused by the same thing. Not much you can do to fix the problem other than towel them off by hand if you dont want to put them away wet.
Nov 25, 2009 | Maytag Atlantis MDE7400AY Electric Dryer
Heat cycle stops/goes off
  1. Changing from 3 to 4 wire hookup on a electric dryer
  2. Door switch replacement help for a common door switch
  3. Dryer basics - Venting problems and power supply
  4. Dryer basics - timers and how they work
  5. Dryer basics - power cord problems
  6. Dryer basics - dead dryer
  7. Dryer *general* repair flow chart....Click here
  8. Gas dryer smell
  9. How do dryer thermostats work?
  10. How long can my dryer vent be in length?
  11. How to change a common rear drum seal
  12. How the belt is suppose to look at the motor and idler pulley
  13. Help on replacing dryer motor and some wiring tips for the 279827 motor
  14. Help on replacing dryer motor and some wiring tips for the 279787 motor new25.gif
  15. Help for storing an appliance
  16. Important Disclaimer
  17. I dropped something down the lint filter area....help!
  18. Inglis, Whirlpool and Kenmore most common style dryer - how to take apart ( lint filter on top )
  19. Inglis, Whirlpool and Kenmore most common style dryer - how to take apartslide show( lint filter on top )
  20. Whirlpool or Sears dryer with heater on the floor and four rollers for drum style - take apart helps ( lint filter in the door )
  21. Inglis, Whirlpool and Kenmore electric style dryers - no heat problems
  22. Inglis, Whirlpool and Kenmore electric element changing procedures
  23. Inglis, Whirlpool and Kenmore dryers - air flow
  24. Inglis, Whirlpool and Kenmore style dryers - noise problems....drum rollers and idler pulley information....
  25. Inglis, Whirlpool and Kenmore style dryers - belt change
  26. Inglis, Whirlpool and Kenmore dryer general motor problems
  27. Inglis, Whirlpool and Kenmore gas style dryers - no heat problems
  28. Inglis, Whirlpool and Kenmore dryers - where are my thermostats
  29. If your drum belt looks like either of these....change it!!
  30. Idler pulley slide troubles with newer Whirlpool build Roper dryer
  32. Newer style Whirlpool - Inglis - ( some ) Kenmore dryer front drum support ring install help
  33. Pilot flame help
  34. Sample wiring diagrams
  35. Test for ohm meter checking on electric dryers with no heat
  36. Taking apart an Duet or HE3 dryer for a belt change
  37. Taking apart a Whirlpool Thin twin washer/dryer to replace the belt
  38. Timers and some common Auto dry troubles and solutions
  39. What is a grounded element?
  40. Whirlpool - Kenmore dryer motor problems in the dryer with Even HeatControl....info on this is here + new25.gifExpanded repair helps for a common "Even Heat" dryer
May 15, 2009 | Whirlpool GGQ8831L Gas Dryer
Whirlpool gas dryer turns on drum spins exhaust is clear and blows air but it wont ignite
  8. Gas dryer smell
  19. Inglis, Whirlpool and Kenmore most common style dryer - how to take apartslide show ( lint filter on top )
Mar 30, 2009 | Whirlpool LGR8648L Gas Dryer
Inglis Dryer
You really need a volt / ohm meter to check for Continuity & Volts
Its well worth the investment... $15.00 bucks give or take a few
I would check to see if you have 220v to back of dryer where the cord mounts to dryer,
If dryer is getting only 1 leg 110 volts instead of the 220 will it not heat.
Check themostates & heater for Continuity... Most models, Now have a.. Hi-limit fuses that need to be checked for Continuity
Oct 13, 2007 | Kenmore 63942 Dryer
Whirlpool Inglis IP8200 Dryer Logo
220 people viewed this question
Top Whirlpool Dryers Experts
Sal De
Craig Butler
Craig Butler
Marvin
Marvin
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
