Rank: Apprentice
Rating: 98%, 3 votes
FLASHING AMBER LIGHT FIX. This maybe in fact a motherboard issue, but actually its a bit more. You can and should replace the power supply with a more powerfull one as it will help overall, but the issue is Really the front USB ports and 2 issues concerning them, 1 some devices pluged into them have boot sequences of their own, (remember your boot seq goesfrom,USB,CD,ARRAY)etc.
So if the device isnt design with its own OS, the mis-boot will get stuck Hence the Flashing light. and 2. the front USB ports dont supply alot of power upon bootup. and the devices pluged into them will again cause a mis-boot. Simply unplug everything from the FRONT usb ports. You may have to shut the computer off and unplug the machine for about *15* minutes.
Enough to get the motherboard to downpower completely.
with the front usb ports clear, and the power cord unpluged, hold down the power button and plug in the machine. should boot no problem. So to sum things up. The motherboard is fine, it just not happy with so many usb ports (power wise). A larger power supply is a good idea but wont entirly fix the issue, Unplug front usb devices as they may have some form of bootup.
Comments:
Jan 24, 2008
- AND oh btw, Your power supply isnt actually dead, the whole computer has gone into some kinda sleep mode.
I went threw the same think, but now i know how to start it when it does it. And it will do it sometime worst than others.
Again, unplug items in the Front usb ports( hub,mp3,flashdrive,bluetooth etc) as these usually have some form of startup/boot aka plug and play. also they maybie *upon boot* sucking too much power. hence the need for a more powerfull powersupply.
