Question about Dryers
Everything on my Crosley (Mod CEDX463MQ1) but it is not heating up
    Scholar:
  • 135 Answers
Here is a web site that I have used to fix my dryer.
http://www.repairclinic.com/Dryer-Troubleshooting
Hope this helps
Posted on Dec 10, 2009
Need voltage transformer for crosley mod. cr704c
Transformers are safety parts so you need to get only the one authorised by Crosley, so you need to contact them for a supplier of the part.
Jan 14, 2013 | Audio Players & Recorders
I have a Crosley CDE 7000 dryer that stopped heating
There can be a few reasons why an electric dryer does not heat...
Check out this tip that I wrote... it will help you find the thing that is causing your problem..
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Apr 06, 2010 | Crosley Dryers
Crosley dryer
check your breaker i think you losted a leg...this is a 220 dryer,,make sure you have true 220..keep me posted on the job...
Jan 26, 2009 | Crosley CDE6000 Electric Dryer
Heat will not work in dryer cleaned vent it was ok Crosley MOD BYCD3723W2 Serial MJ5202075 Type D433-NAT-1203003-FM22
I assume you have cleaned filter, look at rear of m/c and see if there is a red button, if there is, try pressing it. it may have overheated and cut out.
Other than that there are several possibilities for it not to heat, including faulty heater- faulty thermotat,-faulty timer.amongst others.
Hope this helps.
Dec 06, 2008 | Dryers
Crosley traveler turntable noise
Hello attaboy. You may need to check you ac cord if the noise is in turntable, radio, & cassettte mod. If it has a 3 prong plug than you are missing a GND connection, in the cord or inside the unit. If it has a 2 prong plug than take it back or open it up and replace filter capacitors or bridge rectifiers in units power supply.
Sep 19, 2008 | Crosley CR248 Turntable
Heating element in Crosley Clothes dryer
Before you replace the heating element, check the thermal fuse. All heaters have safety thermal fuse. This opens in case the thermostat fails. This is normally attached on or near the heating element, looks like diode. (When replacing, do not solder ! this will damage the fuse)
May 30, 2007 | Crosley CDE6000 Electric Dryer
Dryer won't heat
Jess, the model number comes up as a Crosley electric dryer. Start first at the terminal block where the cord attaches. Should read 120V from each end to center and 240V across the two outer. If this is ok, check the thermal cut out, this will be the top limit switch on the heater housing. Should read closed. Ohm out the element itself with the wires off, should show continuity. You should have 240V across the terminals on timed dry. If that checks good, go to the motor harness. One leg of power to the element goes through that switch. Check that all the wires are intact in the harness and reseat it. Check these things first...Catriver...post back.
Jan 25, 2007 | LG WD-14124RD Front Load Washer / Dryer
Dryers Logo
81 people viewed this question
Top Dryers Experts
Marvin
Marvin
