Question about Dell Dimension 4700 PC Desktop
D drive will not read cd i/o error - Dell Dimension 4700 PC Desktop
  • Brad Brown May 11, 2010
    What version of windows?
  • 478 Answers
Replace cdrom drive and try again
Posted on Dec 10, 2009
Dcz625 has error 6
Q3 ERROR CODES - WHAT DO THEY MEAN? A3 Error 1.Battery inside CD Changer needs to be replaced.
Error 2.CD error message. Mechanism has as eject problem or takes a long time to select CD.
Error 3.CD error message. The pick-up is out of focus during play mode due to scratches on the disc or contamination.
Error 4.Connection problem. Reconnect the data cable.
Error 5.CD error message. Could not read correct data due to CD ROM.
Error 6.CD error message. Could not read data from disc because it is upside-down.
Error 8.Tape Drive system defective. Eating tape or something wrong with the drive system.
Error 9.Weak RF. Try alternate frequency
NO CD.CD error message. No CD is magazine or no magazine in CD Changer.
Clarion DCZ625 Owner Manual
Good luck.
Semper Fi,
Z
Feb 20, 2018 | Office Equipment & Supplies
I receive error when CD is put in computer:
It is very common for dust, dirt, or other material on a CD or CD-ROM drive to cause the CD to be improperly read or generate errors because data cannot be read from the CD. If you are running Windows it or its related drivers may be corrupt and is causing the CD-ROM drive to not be properly read.
For additional information click the following link: https://www.fixtoolbox.com/cdfreefix.html
(CD Fix Toolbox Free)
Jan 19, 2016 | Audio Players & Recorders
My HD SAMSUNG HM500JI not work any more bad sector that cany be fix...!!!
Well.. I'm SAD to inform you..your drive has encountered a serious error.
There's a couple of options..none of which you will like.
Drives (SMART) report errors, but sadly don't fix anything. Once a bad-sector has been encountered, its usually an indication of major failure (google/39% of all drives w/bad sectors major failure..etc)
Your options.. Is your data super important--if so, STOP using the drive, send it to a DRC (Data recovery Center), expect to spend $600-1k for the data.
If you've backedup, good news-- drives are cheap.. buy another, plus your drive into tthe 2nd slot, copy off what you can..
the drive itself is having a major failure (meaning it cannot relocate the bad sectors any longer, hence the smart failure)-- meaning-- drives "TRY" to relocate (when they detect failures, they'll move the data else where, mark the bad area, and use a new spot)... Your drive has probably done that.. ALOT. And now... it's gone critical.
BEST solution for you, to save $$ and time.. but a drive ($80-150 bucks)... install your os... put the other drive on the other cable, copy off what you can..and call it a day.
A DRC won't do much more to be honest... if its SUPER critical, contact www.deepspar.com and see if they will recommend you to a DRC locally to you, or do it them selves...again $$$
Oct 16, 2012 | Samsung HM500JI 500 GB SATA Hard Drive
Computer does not recognize it as a CD RW drive
When you try to write data to an optical disc, you may experience any of the following symptoms:
* You receive various disc write error messages.
* You experience issues with the drive and the built-in recording feature of Windows XP.
* You experience issues with third-party programs that you use to write data to the disc.
* You cannot read the disc in all versions of Windows.
* You cannot read the disc, or some files on the disk, by using an MP3 player.
* When you add files or folders to a disc that already contains data, some files are lost.
* Recording files to the disc is inconsistent.
* The disc recording operation is consistently unsuccessful.
TROUBLESHOOTING
Troubleshooting specific errors
If you experience one of the following errors, follow the appropriate steps to resolve the error.
* There is no disc in the drive. Please insert a writable CD into drive.
This error can occur if the CD-R drive or CD-RW drive is not recognized as a recordable device. This error can also occur if the device driver has been corrupted. To resolve this issue, see Method 3 in the "General troubleshooting" section and Method 1 in the "Advanced troubleshooting" section.
* Drive not accessible, incorrect function
This error message typically occurs when you try to write to a CD-R or a CD-RW, and the Windows XP built-in disc recording feature does not recognize the CD drive as a recordable drive. This error message may also occur if specific third-party programs are installed. For more information about how to troubleshoot this error,
when you access the CD-ROM drive, the DVD-ROM drive, or the CD-RW drive
* Error Deleting File or Folder.
Cannot delete file name. Files on this CD-ROM drive are read-only. You cannot copy or move files over to this CD-ROM drive.
This error message can occur because individual files cannot be deleted from the CD-RW. You cannot use the CD disc recording feature of Windows XP for random-access storage while you are writing to disc.
To set the service to Automatic, follow these steps:
1. Click Start, click Run, type services.msc /s, and then click OK.
2. Double-click IMAPI CD-Burning COM Service.
3. Under Service Status, click Start.
4. Try to write data to a CD.
Jan 28, 2010 | Samsung (SH-M522C/BEBN) CD-RW/DVD-ROM...
CD drive not working can not read the cd.error showing Window can not read from disk or it coulsd be using format that is not compatiable with windows Model TECRA
well try reinstalling the drivers for the cd drive.also you can try using a cd-drive lens cleaner cd to clean the lebs of cd-drive.
Oct 09, 2009 | Toshiba Computers & Internet
When i install cd it says error 6 on my clarion dxz465mp
Clarion Audio error codes:
Error Codes:
Error 1 Battery inside CD Changer needs to be replaced.
Error 2 CD error message. Mechanism has as eject problem or takes a long time to select CD.
Error 3 CD error message. The pick-up is out of focus during play mode due to scratches on the disc or contamination.
Error 4 Connection problem. Reconnect the data cable.
Error 5 CD error message. Could not read correct data due to CD ROM.
Error 6 CD error message. Could not read data from disc because it is upside-down.
Error 8 Tape Drive system defective. Eating tape or something wrong with the drive system.
Error 9 Weak RF. Try alternate frequency
Even though it says error 6 is an upside down cd, it just means the disc cant be read. usualy means the laser is dirty, out of adjustment, or not working.
Aug 19, 2009 | Clarion DXZ465MP CD Player
My Toshiba SD-C2612 8X Slim DVD will not read cds. I just updated the firmware in my laptop for this drive and it still wont read cd's. get can not read d: error. I reinstalled it and everything.
Try a lens cleaner, probably wont solve the problem, the drive's optics for the cd side are failing dvd's still work, if you must read cd's replace the drive or use a external cd drive.
May 01, 2009 | Computers & Internet
Cd roms wont read it says i/o device error
Your error is usually indicates that the drive can't read the CD. I ask everyone these two: check to make sure the CD is right-side up (label facing up or to the right on a vertical oriented drive) and did you insert a DVD into a CD drive? Can you use Windows Explorer and right-click on the CD drive letter and select eject and it works? If not, a driver could be missing. Lastly, if you inserted a blank CD (that can be written to) into a CD drive that can only read CD's, you'll get that error.
Dec 26, 2008 | Computers & Internet
Dell Dimension 4700 PC Desktop Logo
Clive
Clive
Alun Cox
