Question about Cuisinart DCG-12BC Electric Blades Grinder
Cusinart grind central DCG-12BC
Cuisinart removable bowl is stuck, rotates in the housing but does not come off.
  • 1 more comment
  • JCLA Aug 11, 2008
    I forgot to lock it before operating it, and the top is stuck too, how do I get it off? please anyone helps? thanks!
  • endofit77 Dec 26, 2008
    same thing happened to mine, anyone know how to remove the bowl without breaking anything?
  • Martha Samson Feb 04, 2012
    I had this same problem and called Cuisinart's Customer Care line at 1-800-726-0190. It was a bit of a wait but worth it. They are sending me a new grinder right away, and asked me to send back the defective one within 30 days with a $4 check to cover shipping.
  • 24 Answers
Unplug the unit from the AC outlet. Remove the six screws that hold the lower plastic cover on the motor base (four screws are hidden under the adhesive rubber footpads). This exposes the lower end of the motor shaft, which has a slot in it. By inserting a flat blade screwdriver into the slot and holding the cutting blades with a rag or a wad of paper towel to avoid cutting one's fingers, it is possible to twist the shaft back and forth about 90 degrees. You may need another person to help, because one needs to perform this twisting action while pulling the motor base away from the grinding cup and blade assembly.
Once you get the @&%$#! thing apart, reassemble the motor base. (With the slotted motor shaft, why didn't the designers simply put a hole in the plastic base so one could stick a screwdriver in without disassembling it?) Plug it into the wall outlet and use a small object like a toothpick or matchstick to activate the recessed motor switch so you can spin the motor without the grinding cup in place. Use the blunt edge of a small snap-blade utility knife as a scraper to gently scrape the plastic pin of the motor shaft as it spins, much as one would work a wood turning lathe. Periodically check the fit of the brass hub of the grinding cup on the plastic pin. Continue to shave the pin until the grinding cup slips onto and off the pin with no resistance. Take care to machine the pin uniformly from top to bottom; avoid making grooves.
Why this mechanism worked properly when my grinder was new about 18 months ago and suddenly decided to get stuck this week is a bit of a mystery. The unit in question has been used since it was purchased exclusively to grind flax seed, but the ill-fitting pin normally doesn't come into contact with foods, anyway. There was no obvious evidence of swelling of the plastic due to heat from the motor or oils from seeds. Since the blade and hub are free to travel up and down on the plastic motor shaft pin a bit, I suspect that on occasion the blade doesn't settle properly and the clutch doesn't engage, allowing the pin to spin in the brass bushing until it starts melting, and then the hub settles so that the clutch is fully engaged. This may happen in a matter of just a couple of seconds of operation. Once that happens, the pin conforms to the microscopic grooves inside the brass bushing, allowing it to still turn slightly relative to the motor shaft, but locking it on so that it can't come apart. If Cuisinart had made the pin more tapered and the hole in the brass bushing to match, much like a Jacobs taper on an industrial drill press spindle, this would be much less of a problem.
BOTTOM LINE: Before loading the grinding cup and starting the grinder, push the blade hub down with your finger to make sure the clutch is fully engaged.
Posted on Dec 09, 2009
    Problem Solver:
  • 5 Answers
This happened to mine this morning. I was so frustrated because the reason I bought this was because of the removeable bowl. My bf got it off but he broke off a piece of plastic (he is pretty sure the piece of plastic was on the bowl part).
I put it back on and it kind still worked- I think I will just need to get a replacement bowl now - but it was hard to get off again.
When I tried to get it off the second time, I moved it into the "unlocked" postion and then manipulated the the blade part while pulling and it came off - but of course mine was broken already.
There appears to be two areas where it locks - on the base and a part on the bowl. I think somehow they get out of synch.
The problem is not with the base I think but with the bowl.
Although, now that it is "sorta" broken - I can't remember what parts were supposed to be loose before and which ones were not. The blade part of the bowl is very loose now. My boyfriend is pretty sure the plastic broke off the bowl part so I am going to get another bowl. I hope that solves my problem!
Posted on May 28, 2008
My Cuisanart coffee grinder does not work (no power) after only a couple of months
you have to make sure the lid is securly in place for safety it will not power on if not correctly lined up and secure.
Oct 08, 2014 | Cuisinart DCG-12BC Grind Central Coffee...
I have Cuisinart Grind Central DCG-12BC.Yesterday it suddenly stopped working.I opened it,but I cannot find anything wrong in it.?
1) test the power cord for open or break with VOM
2) test the outlet box wall, put some another devices and see if working , if does the problem is the device
3) test the main switch for open or defective or loose wires, repair or replace
4) test for thermal fuse inside, for open and replace, see if your model hast c.breaker and reset it.
5) Try now.
6) Please read your owner manual, if you do not have download from www.retrevo.com and go the section troubleshooting
God bless you
Aug 01, 2012 | Cuisinart Grind Central DCG-12BC Blades...
My Cuisinart DCG-12BC coffee grinder, the bowl is stuck on the motor base. It works and turns, but it will not come apart to be able to clean it. Please advise.
.... mine stuck after "first" use ... solution ... took it back to the store, got a refund, bought a Mr. Coffee Model IDS77 which was $11. cheaper, has automatic grind settings and a superior bowl arrangement... Then I put Cuisinart on my list of DO NOT BUY ... anything can have problems, but something obviously this chronic should be handled better by the manufacturer ... it should have been taken off the market and fixed ...
Aug 27, 2011 | Cuisinart DCG-12BC Electric Blades Grinder
It was working fine grinding coffee beam Ns when it just stopped grinding. I can not get it to grind again.
This model grinder has a 12 to 16 month life expectancy.. I would advise you to buy a different brand such as a Braun which last for years
Feb 13, 2011 | Cuisinart Grind Central DCG-12BC Blades...
How to program to automatic brew
For most Grind and Brew's, you can press the PROG button or turn the dial to PROG, then press the HRS button to change the hour and minute to change the time. The led will display PM if it is set for PM, but will not display AM if it is set for AM. After you have finished programming, press the PROG button. Now activate the AUTO-ON button or slide the dial to the Auto-On position.
But, like the person said, we would need your exact model # to be more specific.
-Tha Mp3 Doctor
Dec 29, 2008 | Cuisinart DCG-12BC Electric Blades Grinder
Need help using my coffee maker
Thank you for note I went on Cusinart site and found a copy of the manual and got my coffeemaker to work.
Dec 25, 2008 | Cuisinart DCG-12BC Electric Blades Grinder
Cuisinart DCG-12BC Electric Blades Grinder Logo
1,344 people viewed this question
Top Cuisinart Coffee Makers & Espresso Machines Experts
Michael Galve
Michael Galve
Marvin
Marvin
Tom Howe
Tom Howe
Level 1 Expert
Are you a Cuisinart Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
