Question about Toshiba 32AV502R LCD TV
How to I permanently set the picture size on my toshiba 32AV502R? I choose pic size, but when I shut the tv or go to a different input.. it resets when I come back.
  • Toshiba Master
  • 8,457 Answers
Unplug,replug about an hour later should be back to normal reset to factory setting.It should work now because not in custom setting anymore.
Posted on Dec 10, 2009
TOSHIBA 32AV502 Wont Turn On
Ensure that the input device and the connections are ok. Try changing the input device to something that you know, works. Try controls on the panel of TV. Remove battery from remote, before you do that. Try connecting the TV to a different power outlet. If nothing works, this might require the attention of a qualified service technician.
Jul 30, 2012 | Toshiba 32AV502R LCD TV
Toshiba 32AV502R won't turn on even though green light goes on
Try changing the input device to something you are sure works. Switch off TV manually, switch off power, remove plug and retry after 48 hours. If problem persists, please refer it to a qualified service technician.
The picture size resets when the tv is turned off then on.
It also resets when you switch to a different Input... IF you have the Auto Aspect Ratio set to On! To set the Picture Size so that it won't change back each time, switch to the Input you wish to change (you'll have to do this for each Input separately), then go to- MENU > Picture > Theater Settings > Auto Aspect Ratio > and set it to Off. Once you've done this, your Picture Size setting will remain, even after powering off, or switching inputs ;)
Oct 23, 2010 | Toshiba 32E200U 32 in. TV
RE: Toshiba 32AV502R 32
NO,Ur tv have problems.The Main Tuner Signal is dead,have burn electronics componnents.Still under warrenty call for service.Not Tries websites Shopjimmy.com,Ebay.com to buy a refurbish Tuner signal board for the replacement.
Mar 17, 2010 | Toshiba 32AV502R LCD TV
No picture when tv powered on
When power on and input set to hdmi1, there is no image appears
Dec 31, 2009 | Toshiba 32AV502R LCD TV
With the Toshiba 32AV502R 32 in. HDTV LCD TV, can
how do you change your HD setting say 480i to 1080p...
Dec 07, 2009 | Toshiba 32AV502R LCD TV
I can't switch the picture size. When i hit the pic size button, it tells me it's not available. I tried changing the pic size with the tv/video input on our dvd, but it won't change it when its on out hd...
defective hd cable box is possible but each unit has its own picture size adjustment. use your cable box remote and change size there. use tv remote to adjust tv size to auto. dvd the same thing
Nov 10, 2009 | Toshiba 57H82 57" Rear Projection...
HDMI cable hooked up, now CLOSED CAPTIONING is stuck on!
It has got to be the box. I would try to contact Scientific Atlanta if any way possible. The TV doesn't choose what inputs it shows CC.In other words, it would show it on all Inputs if it was the TV. Good luck and Thanks
Oct 30, 2009 | Toshiba 32AV502R LCD TV
Toshiba 32AV502R LCD TV Logo
220 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
