Question about Miele CVA615 Espresso Machine
Miele grind cycle not working on miele coffee maching
  • 177 Answers
if you move the grinder level across to the left in one action it can jam up the grinder and even damage the grinder. if adjusted is required you should move it one mark, make a coffee and then move it another mark and make a coffee.
if you can't hear the grinder operating when you make a coffee then it sounds like it could be damaged.
Posted on Aug 03, 2010
Our Miele coffee machine is not grinding the coffee and only delivering water. I have cleaned the brew unit but still no coffee. Any suggestions?
Sounds as if the grinder and or the coffee chute is plugged with grounds, this can happen when using a very fine grind and /or a very oily bean. Sometimes the grinder can be cleared when taken all apart and cleaned with a tooth brush - but this would require a service tech for the most part - have to take quite a bit apart to do this
Oct 30, 2017 | Miele Coffee Makers & Espresso Machines
I have Miele coffee system CVA 4062 the grinder is not working properly? I have cleaned everything, Descaled all that good stuff.
Its likely to be the brushes in the Grinder motor. These are replaceable but Miele does not sell them as a spare part. You may be able top fabricate your own if your technically minded and experienced and can disassemble the machine. Otherwise grinder needs to be replaced. Regards
Jan 18, 2017 | Miele Coffee Makers & Espresso Machines
How to unclog coffee spouts?
I have a different machine, but it came with a needle like cleaner for those tiny holes in the cup that holds grinds. Also, if I grind the coffee too fine, there isn't enough pressure to push coffee out of both holes. Make a coarser grind to see if that solves the problem.
May 01, 2016 | Miele CVA4066 Built-In Whole Bean Coffee...
Miele cva4070 coffee maker showing fault76
Fault 76 is caused by there being too much coffee to compress . Assuming there is not a fault with brew unit or brew unit drive, then try to use less coffee (see menu settings) or grind the coffee to a finer level (see manual). regards
Jun 16, 2014 | Miele CVA4070 Coffee Maker
The grinder is not working
Likely causes are grinder has burnt out or temperature cut-out for Grinder has blown. Either can be replaced as a spare from Miele.
May 13, 2014 | Miele CVA4070 Coffee Maker
The grinder is not working. Only water is coming out.
Basically coffee is not being ground. Likely causes are grinder is faulty or temperature cut-out for Grinder has blown. Either can be replaced as a spare from Miele. Note: A possible cause for Grinder not working is that the carbon brushes are worn away preventing electrical contact. Unfortunately Miele does not sell brushes as a spare part.
Hi. I have a miele cva4060. The grinder is working but it does not seem to be getting any beans through it and I am only getting water dispensed instead of a coffee shot! It was working fine a few days...
Hi
If you hear its 'grinding' then that's good - problem is where is the ground coffee going or supposed to go??
Check there is no build up of damp/dried coffee grinds in the pathway between grinder and brew unit - this can happen if the machine is not properly cleaned say every 3 mths or more often depending on usage - coffee 'dust' can build up.
Also suggest remove all beans from grinder, vacumn last ones out. clean all around grinder opening. Add a dozen or so beans to the grinder, turn on and try again. If the beans disappear, its grinding properly. If they don't end up in the brew unit, then the hold up is as I said in that pathway - grinder to brew unit. If you cant see an obvious blockage/build up, suggest you have a tech look at it.
Cheers
Mike
Dec 10, 2017 | Miele Coffee System
Miele CVA 4070 coffee system
I called Miele hot line & here is the solution to fixed the problem... 800-999-1360.
http://www.miele.com/
Whenyou start the cleaning cycle, Don't stop the process by pulling the plug! Turnthe unit off from inside wait 5+ seconds & turn back on and thecleaning cycle should restart... If you do not use a cleaning TAB..Open& shut the LOOSE coffee Door under the drawer (Top Left) and thecycle will continue.
Aug 25, 2008 | Miele CVA4070 Coffee Maker
Miele CVA615 Espresso Machine Logo
658 people viewed this question
Top Miele Coffee Makers & Espresso Machines Experts
just-ice
Michael Galve
Michael Galve
Colin Stickland
Colin Stickland
Are you a Miele Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
