Question about Samsung DLP HL-P5663W 56" TV
Model HLN567w xaa Samsung Picture is perfect until the TV has been on for around 45 min. The the pic. start flickering and I hear a cherping noise only while the pic is flickering. It flickers for around 5 seconds and then the colors change to purple and green. If I shut the TV off for 5-10 min. the picture is good again.
    Brigadier General:
  • 8,619 Answers
Hi
Thanksfor using FixYa. The chirping sound and the colors changing to purple &green indicates that the color wheel has gone bad. The only way to solve thisissue is to change the color wheel. A professional tech. will charge you around$450 including parts & labor, however if you have electrical expertise andwant to do it yourself then it can be done easily only if you have knowledge ofelectronics. Please check these links which will help you in DIY Job:
Samsung HLN567w xaa Color Wheel How to Replace Color Wheel Please doaccept the solution if the issue is resolved or else revert for furtherassistance.
Thanks
Rylee
Posted on Dec 10, 2009
TV lamp has been replaced, still won't come on, no picture. When turned on, I can see a blue, kind of sparking light and noise starts and does this about three times. TV powers down and does this again....
Samsung DLP TV Repair - No Picture - Replacing ...
? 2:41
https://www.youtube.com/watch?v=pBTgk_C5FVU
Jun 11, 2012 - Uploaded by ShopJimmy.com
DLP TV Repair No Picture Bad Lamp Bad Bulb TV Won't Turn On DIY Samsung DLP TV Repair How to replace Faulty LampTutorial Click Here to ... Rating is available when the video has been rented. ... is a replacement for the following DLP Rear Projection TV models: ... SAMSUNG HLR6167WX/XAA
Samsung DLP problems - Help! - ecoustics.com
www.ecoustics.com > ... > Home Video Forum > Projection TV Forum
Oct 26, 2009 - I have attached a picture of to show where the "Light Tunnel" is located. Upload ... So now I have a Samsung HLN5065W/XAA that I am willing to part out or sell as is. ... I replaced the ballast but the TV still won't turn on. .... The lamp has been sitting on a shelf until two weeks ago, when the TV went dark. Samsung DLP Light Ballast
Apr 10, 2009
Archive through October 26, 2009 - Samsung DLP problems ...
Apr 8, 2009
Samsung DLP Flashing Standby light
Jul 1, 2006
More results from www.ecoustics.com
Jan 19, 2016 | Samsung SELECT HLR6167WX/XAA Rear...
Samsung model HLP4663WX/XAA with loud buzzing noise, need to know which part to replace.
See attached photo: you have a bad color wheel----it turns at about 12,000 rpm and bearings in the tiny motor go bad.
High pitched or fan like sound is classic symptom.
The wheel is available on the internet and You Tube has video instructions by model number for replacing it---Google the model number for the part number for your set to locate the part and instructions.
This for most people is a do it yourself job---takes like 45 minutes start to finish.
If color wheel slows too much set will shut down as its speed is monitored and the wheel can even shatter causing shutdown of the set.
Steve
Feb 28, 2012 | Samsung DLP HL-P4663W 46" Rear Projection...
I have a samsung model hlr4667wx/xaa picture freezes
analog board can cause that symptom especially if the pic is freezing .
Jun 26, 2010 | Televison & Video
White dots on screen of 50 Samsung DLP
Random dots or pixels failing on a DLP TV will be a bad DMD chip. This is a technician replace item only. The chip runs around 160 dollars list price. The part number will depend on which version the set uses and will be determined by the technician.
Jul 23, 2009 | Samsung HLN567W 56" Rear Projection HDTV
Samsung lns4095dx/xaa after 30min the screen goes
The first place to start is with the Main bd. The second cause would be the T-con bd. Have a trained Samsung tech troubleshoot to find out and repair the set.
Jul 05, 2009 | Samsung LN32A550 32 in. LCD TV
Samsung HLN567W rear projection picture flickering
Your color wheel must be replaced. They are about $100 including shipping
Jan 23, 2009 | Samsung HLN567W 56" Rear Projection HDTV
Samsung hpr4252x perfect picture in
You have a burn in problem from watching widescreen movies.If you have access to a signal generator or tv setup disc run a perfectly white screen on the plasma for about 30 min.This should help even out the pixels on the display.
Mar 05, 2008 | Samsung HP-R4252 42 in. Plasma HDTV
My TV pictures turns black afetr a few hours but I still can hear sound perfectly!!!
It sounds like your rptv lamp is going out. If this is an older DLP this is most likely the cause. You can get a replacement at www.laptopsforless.com part number BP96-00224J for $151. If the tv is still under warranty, I would have them do it, otherwise replace it yourself. If so here is a link to give you step by step instruction. Please give me a good rating. ;-)
Dec 18, 2007 | Samsung HLN567W 56" Rear Projection HDTV
Samsung DLP HL-P5663W 56" TV Logo
90 people viewed this question
Jerry Greenberg
Jerry Greenberg
