Question about Cell Phones
Is there any way to change screen colour on Vodafone 228, and/or its lettering.... being a blue background with etched lettering it is very hard to read and I would like a plain background?
Screen display on iPad 2 changed to blue background with slight flickering. This happened while using - it did not drop. Reset has not solved problem.
Turn it over on your lap or on something soft like couch or carpet. Karate it chop it on the apple logo. Start softly and keep using more force. Folks have even used a hammer to do this but I don't advise it. You can also drop it face down on carpeted floor. Your ipad is likely stunned and needs to be stunned again to return to normal.
Mar 19, 2014 | Apple iPad (16 GB) WiFi Tablet PC
Free unlock Australia Vodafone 228
my mum send me a vodafone 228 i cant insert other simcard to it please help me what to do tnx
Mar 15, 2010 | Vodafone Mobile Connect (055270) Wireless...
My sony grand wega gives a blue shade on the black background which is the problem
HI, Check the menu set up of the TV. There should be an alignment feature that aligns the blue, red, and green colour projectors. If the blue is out of alignment that is likely why you can see it on the dark backgrounds. The set up normally puts a white cross on the screen and you select each of these colours and then move the cross over the white on with the arrows on your remote. Once all are aligned correctly you shouldn't be able to distinguish between different colours and hopefully this should get rid of your blue shade.
Oct 25, 2009 | Sony Grand WEGA KDF-42WE655 42" Rear...
My comouter screen has changed colour and is barely readable, the startup when it says 'DELL is a white background and orange text anf then when i choose what user i want to go it almost like an...
If it is still under warranty call dell asap. Normally that is the LCD going bad or the video card, which is built in on the motherboard. Usually there is nothing a home user can do with this problem. LCD's are not too hard to change but the Motherboards can be a real bear.
Aug 09, 2009 | Dell Computers & Internet
Distorted screen
Go to control panel- Display settings- See if Colour mode is 32 bit & 256 colours. try to change the display settings.
Otherwise uninstall- reinstall or upgrade thee display drivers using the Drivers disc or from HP website.
Try system restore if happened recently
Feb 04, 2009 | HP Pavilion dv6000z Notebook
Monitor color changed
there may 2 problems
1 ) Problem with the Data Cable connector the Pins might be damaged try to arrange them if disturbed / bend . if Broken change the connector.
2) Open the monitor see the soldering carefully you can locate out the dry solders easily by seeing the flux colour around it . just put the solder over there..by soldering gun to all places where u can see the dry solder.
Sep 05, 2008 | Gateway FPD2275W LCD Monitor
Screen colour is distorted
hi there
you may want to check the cable that connects your tv and player as this may be faulty already and start to recieve interference. try to clean the lens as well as this also give effect to the screen.
hope this helps.
Feb 12, 2008 | JVC TH-V70 System
Cell Phones Logo
27 people viewed this question
Top Cell Phones Experts
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
