It needs a 27mhz crystal replacing 1h00 on the board in the middle if the led is flashing 5 times. This requires a rework station and is a professional job.
Rule out any loose contacts in power outlet, RC Jack, cables and connectors. The problem described by you calls for opening the back cover and further investigation, which should only be done by a qualified service technician.
IF YOUR IMAGE IS ALL WHITE YOUR LOGIC BOARD IS DEFECT BUT IM SAD TO SAY DO NOT REPLACE THE LOGIC IT WILL ONLY TEMPORARLY SOLVE THE PROBLEM THE PANEL IS OVERLOADING THE LOGIC BOARD PANEL IS BAD
helloFive blinks - AKB circuit (automatic kine bias), the
timer/standby indicator blinks for about 30 seconds then goes to the
self-diagnosis function. Something is wrong with the video. Check video
out, Q705, 732, 761 and other components on the C board, also check
Q218, 219, 220 on the A board. In addition, unit could be in IK
blanking, try turning up screen slightly.
tv works for about 2 minutes, then shuts itself off. the red standby light flashes 50 times, then the tv. comes back on for approximetly 2 minutes then goes off again, only to repeat again
If this is a flat panel LCD tv, this is a sure sign that the panel itself is bad. I have seen this before. Tv comes on works fine then within 5 minutes goes blank.
I'm not sure what TV model you have. But, thing I can tell you is the most common problem.
Most of the time with flat panel TVs, the power supply for the screen fails. And the TV normally turns itself off to protect other parts in the TV from being damaged. Basically " Protection Mode".
You can try leaving the TV unplugged for 30 minutes so the TV can reset itself; then try again turning it on. If it doesn't work after that, it's time for the TV repair shop.
Your TV has a power problem, it maybe high or low supply voltage that causes the TV to turn it self off because of an error. A technician from the manufacturer knows what error it has just by looking at the flashing standby light. Best is to take it to an authorize service center for repair... ^_^
