Question about Cell Phones
I plug it into the charger but it doesn't power up...Is there a reset button? It is only a month old.
  • ivan georgiev
    ivan georgiev May 11, 2010
    what is model of your phone?
  • David May 11, 2010
    What is the make and model of your phone?
3 Suggested Answers
  • 1680 Answers
SOURCE: What can I do to fix a Digiland 7 tablet 7 months old that suddenly will not turn on, even when plugged into the charger?
there are a few options
How do factory reset my digiland tablet
Posted on Aug 03, 2016
florin_decad
  • 203 Answers
SOURCE: why will my Digiland tablet Model DL718M not turn on, even when plugged into the charger
Check the cable charger, if is ok plug in your tablet in to laptop computer could be the software issue and has to be ,,reflashed" new software on
My three month old Galaxy J3(6) has gone blank, dead, after working until this afternoon. I had charge in the battery but plugged in the charger again. It still will not switch on?
Try pressing and holding the Volume Up button and the Power button for 15 seconds. If that doesn't work, you need to check that the charger is passing current by plugging in another device to it. If that checks out, you need it repairing or replacing.
Mar 22, 2018 | Galaxy Cell Phones
Why will my Digiland tablet Model DL718M not turn on, even when plugged into the charger
Aug 03, 2016 | Tablets & eReaders
Why won;t my irulu 10.1.1 tablet turn on. i push the button and nothing happens, when charger is plugged in it gets warm both tablet and plug
It sounds like you've done most of the things you would reasonably be expected to do to make it function; since it is only 2 months old I would strongly urge you to go back to the retailer and make them replace it or refund you, as your rights in most countries/states allow.
If you're set against doing this, try holding down the power and volume down key for at least ten seconds to see if this boots it into hard reset mode. If this doesn't do anything, try again holding down power with each of the other buttons to see if you can activate any other developer/reset modes.
However, I have read reports that this particular tablet has up to a 40% failure rate in its first six months.
If you can possibly get it refunded, do that and buy something else.
Jan 02, 2015 | Irulu 10.1 inch Android 4.0 Touchscreen...
My TomTom,VIA 280 has suddenly stopped working. It is barely 2 years old. It will not power up
let it sit on the charger over night, check the charger on another device too.
Dec 08, 2014 | Tomtom GPS
My m9300 will not start up only one week old need help
Please make sure the tablet is charged for at least 4-6 hours. Also, make sure the correct button is being used, oftentimes we hear the back or home button has been used in error. If the issue persists, you can try performing a power reset. There should a power reset button near the charging port. It looks like a tiny hole. While plugged into the charger, use a paperclip to push the button inside this hole for 3-5 seconds. If it turns on, please allow it to charge for 4-6 hours before using it. If you leave it on the charger for longer than the allocated time, you will go back to having the same problem as before. If the power does not come on, please leave it plugged up for 4-6 hours then disconnect it from the power and turn it on.
If your tablet does not have the reset button: With the tablet plugged into the charger, hold the power button for 10 seconds then click the volume up once. If it turns on, please allow it to charge for 4-6 hours before using it. If you leave it on the charger for longer than the allocated time, you will go back to having the same problem as before. If the power does not come on, please leave it plugged up for 4-6 hours then disconnect it from the power and turn it on. Support Troubleshooting Guide
Feb 27, 2014 | Kocaso Tablets & eReaders
My tablet is totally dead! I tried charging it twice now, both times for about 12 hours, both times at outlets that are functional. It is just two months old, so I can't see what could be wrong with it....
You could try doing a hard reset by holding down the power button and the volume down button at the same time for 20-30 seconds and then see if the device comes on.
Make sure you have it plugged in or that there is enough battery to power on the device before performing the hard reset.
Hope that helps!
Oct 25, 2013 | Google Nexus 7
Wont start
Are you sure your USB charger is working properly? Have you tried replacing the battery? You might try this trick: Make sure that your Notebook is plugged into the charger and that it is plugged into the power outlet, press the power button and hold it down for 20 seconds, then release the button and wait about one minute, now press the power button again and hold it down for 20 seconds again. Hopefully, this will reset your system.
Jun 27, 2012 | ASUS Eee PC 1000H Laptop
Gateway M-6862 laptop will not turn on; battery light flashing re
Seems to be a problem of not enough power.
First check the voltage output of the charger(adapter) and match it with its specs.
Also try to reset the hardware using the following steps:
1 Disconnect battery and the charger
2 Let it sit for 1-2 minutes.
3 Press and hold down the power button for 30 seconds.
4 Reconnect battery and charger and try to start by pressing the power button.
Mar 07, 2010 | Gateway Computers & Internet
Cell Phones Logo
15 people viewed this question
Top Cell Phones Experts
Marvin
Marvin
Are you a Cell Phone Expert? Answer questions, earn points and help others
