Question about Roper RT18DKXKQ / RT18DKXKT Top Freezer Refrigerator
After thanksgiving, and loading the fridge with cooked food, after a couple of days water started accumulating under & in the vege drawers. How to correct?looks like the hing in top center of refrigerator has frost on it. The freezer is keeping at 0 - 5 degrees F. and the refrig is between 30-40.
  • 4,070 Answers
Normal 0 MicrosoftInternetExplorer4 st1\:*{behavior:url(#ieooui) } /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman";} Your evaporator coils frost up in normal use and every eight hours or so the entire unit shuts down and the defrost heater comes on to melt the frost. This cycle last about 20 minutes. The melted frost drips into a drain pan and through a drain tube to the drain tray under the freezer/refrigerator where it's evaporated by the condenser fan.
Your drain tube may be stopped up with ice at the upper end because it drains too slow because it's stopped up at the lower end in the evaporator pan under the unit at the floor. It can get dust and mold in it. Once you get the ice out at the top a little pressure with a turkey baster will usually clear it out. Flushing it out with hot water and clorox may help.
Make sure it drains quick enough to prevent refreezing. . The drain should be located below the evaporator coils on the lower back of the freezer.
Posted on Dec 10, 2009
Hello I have a Panasonic NR-B32S fridge freezer the bottom of the freezer under the bottom drawer ices up every Couple of days ?
at that, when you have food stuck in and iced allready what you need to do is relocate it and bring in fresh food there. freezer only
May 29, 2017 | Panasonic Refrigerators
Refrigerator not cooling
The self defrosting mechanism is fubar. Check out the defrost timer and defrost element for proper operation. Chances are that the element is open.
Jun 25, 2016 | Samsung RF266ABRS Bottom Freezer...
The label on my frozen turkey says it is good till March of 2016 does this mean even if its thawed it will still be good till that date?
Hi Ronnie:
- If it has been sitting unfrozen in your fridge for more than 2 days I'd personally not be eating it.
- Likewise, if you cook it, it should be eaten right away.
- Re-freezing uncooked is not considered safe food protocol.
- Freezing cooked in serving size portions and only thawing when you're going to heat and eat is usually safe.
Hope this helps.
Nov 14, 2015 | Toys
I have never had a slow cooker in my life and found this one in a garage sale without the manual. How does it work?
Yes you can use any cheaper cuts of meat or chicken and yes less liquid is used in slow cookers. add hard veges n use green veges for end of cooking time. cook for 6 or 8 hrs on low. Yeilds ecellent results. Find slow cooker books for great meals n desserts. I use mine every week.
Apr 22, 2015 | Crock Pots & Slow Cookers
Water accumulating inside fridge bottom make GE Model #gta18pbnaww
That's normal especially if you tend to leave the door open alot. Moisture from the outside air condenses and drips to the bottom. Also, if the refrigerator is automatic self-defrosting it will melt ice collecting around the refrigerator and the resulting water will collect at the bottom. Check under the food drawers for a drain hole. If it is clogged, clean it out. If it doesn't exist, periodically sponge out the bottom under the drawers.
Jan 12, 2013 | Refrigerators
Fridge freezes up and then meltsw
I FOUND A PROBLEM WITH A COUPLE OF THESE THAT THE AIR FUNNEL ALONG THE BACK WALL WAS SEPERATED FROM THE FLOOR OF THE REFRIGERATOR REMOVE THE CRISPERS AND LOOK AT THE BACK WALL. IF THERE IS A GAP AT THE BOTTOM AIR DUCT APPLY SILICONE {FOOD GRADE ONLY} TO SEAL THE GAP
Jan 12, 2010 | LG LRBN20510WW Bottom Freezer Refrigerator
Unexplained water accumulation under the crisper/produce
OK, I am going to give you a lot of information on one page, so please read carefully and choose the parts that apply to you. PS, Please rate my solution and my thanks to all the Guru's that helped put the following page together. please click on link below, Thanks Sea Breeze
HOW TO FIX A DRAIN LEAK INSIDE REFRIGERATOR AND FREEZER PART 2
Aug 10, 2009 | Whirlpool Refrigerators
Water is accumulating in bottom of fridge under produce drawers
Possibly your defrost drain found inside the freezer back wall is blocked. If you could send me the model number I could help you better. Thanks, Sea Breeze
Look at following areas for the model number
  • Beneath Or Inside Food Compartment On Cabinet Frame
  • On Plate Lower Front Or Rear Of Cabinet
  • Beside Compressor Door On Right End
  • Near Rear Of Cabinet
  • Inside Liner At Top
Mar 28, 2009 | Refrigerators
Vegetable and fruit crisper drawers freezing foods
You have a defective thermistor and damper control in the fresh food or a bad control board.
Check the thermistor first.
Also, adjust the return air damper at the bottom left side of the fresh food sction to warmer.
Feb 21, 2009 | GE PSS25SGN Side by Side Refrigerator
My 7 1/2 year old Thermador CVS36RB Cook 'n' Vent won't retract
sears labor is 137 plus parts. that is something that would need to be looked at. it could be a few different things. if he is handy he can open it up to see if anything is misaligned or broken. the vent may even just be a little crooked and once straight may go up and down like normal
Nov 22, 2008 | Thermador UCV36A 36" Universal Cook 'n'...
Roper RT18DKXKQ / RT18DKXKT Top Freezer Refrigerator Logo
104 people viewed this question
Top Roper Refrigerators Experts
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
John Tripp
John Tripp
Are you a Roper Refrigerator Expert? Answer questions, earn points and help others
