Question about Dyson DC17 Animal Bagless Upright Cyclonic Vacuum
Beater bar won't work. Have done all checks in manual. Bar is clean, belt seems to be connected properly and in good shape. Any ideas? John Rike jjnrike@yahoo.com
    President:
  • 1,515 Answers
Hi, I would have to say, that if the roller-brush Is clean and the belt is on and in good shape, that the problem will be in the vacs motor assembly itself. If the motor comes on, the beater bar will engage and pick up debris.If it is coming on and not rolling, it it damaged internally.If the unit will not come on at all, you can pull out the on/off switch and try to bypass to see if unit starts, and if so replace switch.If you have excess to a volt meter you can check for power at the switch.Touch one lead to one terminal and the other to ground, should be 120v.Same coming out. If motor doesn't come on at all, more then likely, it has died on you, open windings, shorted to ground and will need replaced.Not knowing the cost off hand of this machine, I would compare prices of a motor to a new one.I hate to give you this news, But If the switch is good, and the motor is off, it has failed on you.Try and do the checks and get back to me, so we can be for sure on it. Sincerely,
Shastalaker7
Posted on Dec 10, 2009
Brush roll won't turn only a few times
Shane:
Unplug the machine and lay it on it's back with the handle release in the release position (the vacuum head should be laying flat also). Remove the foot plate from the vacuum head. Manually turn the brush roll (called a beater bar). The beater bar should turn fairly easily and the belt should turn the motor armature shaft (now would be a good time to check the inside surface of the belt for grooves or damaged spots which would cause the armature shaft to slip on the belt). If the beater bar has too much resistance to your turning it, I would suspect that the bearings at each end of the beater bar are fouled with hair, carpet fibers and string. Remove the beater bar from the machine and manually spin the motor armature shaft (where the belt contacts the motor) to see that the motor armature shaft spins freely. Remove the bearings from the end of the beater bar (they won't come off easily so you may have to use a prying tool such as a screwdriver). Try to spin the bearings. If they are fouled, dribble some rubbing alcohol into the bearing (I use a spray bottle... it's much neater) and turn the bearings while keeping them soaked with alcohol until they spin freely without ratcheting. Drop some 30 weight engine oil into the bearings until they are saturated, then clean the outsides of the bearings with a clean rag (no alcohol) until the outsides of the bearings are completely dry and no oil drips out of them (don't want the oil to attract dirt). You'll probably need to replace the belt. Reassemble the machine and it should work for you.
Jun 07, 2013 | Oreck UPRO14T - Vacuum Upright Commercial...
Free instruction manual for bissell 4104
I've found step by step video demonstrations for cleaning, belt replacement, basically maintenance of different appliances on "YOUTUBE" you might want to check it out. Just type in Bissell 4104 beater bar replacement. Hopefully there will be a video showing you exactly how to replace it properly.
Jan 04, 2012 | Bissell 4104 Bagless Upright Cyclonic...
I have a Dyson Animal bagless vaccume and can not get the beater bar to work. I have cleaned it really good and seems that it doesn't switch from bare floor to carpet
Is this a new vacuum for you, or are you familiar with how it works? The beater bar button is on the front of the handle. It is a large half button with the picture of a beater bar on it. This button has to be pushed down for the bar to work.
If you already knew this and your vacuum is one you have had for awhile, it may have a worn or broken belt. The manual should tell you how to replace the belt, and you should be able to purchase one through the dyson website http://dyson.com under PARTS or at the store where you purchased the vacuum.
Please let me know if this works for you.
Jan 11, 2011 | Dyson DC07 Animal Bagless Upright Cyclonic...
When using my hoover wind tunnel the last few times it has emitted a burnt rubber smell so my husband checked the belt and is wasn't broken or off but now when I use the vacuum the beater bar doesn't seem...
i take it the belt was put back on !! i would say hubbi forgot the tension arm a little black striker that can go in two ways but put in back wards it will not tension the arm
Jan 03, 2011 | Hoover Self-Propelled WindTunnel Bagless...
How to change belt on sears vacuum cleaner
I believe you turn the vac over so the beater bar (brush) is facing up.
Depending on the age there maybe screws or tabs that hold the plate on to the bottom of the unit. Remove those and the plate. That should expose the bar, belt and motor pulley. If the beater bar doesn't pop out when the bottom plate is removed, pull it out and remove from belt. (Pay attention to how the bar was inserted. It may have a pentagonal shape and only fit properly when inserted a certain way.
Now is a good time to clean the beater bar.
Replace with correct size belt and reassemble in reverse order.
Hope this helps.
If so, please rate me.
Thanks,
Matt
Sep 14, 2009 | Kenmore Vacuums
The brushes will not turn. It appears that the
Hi, W/D here. Easy fix!
Flip the machine over, beater bar side up. The base plate has to come off; it is held on with either screws or clips or a combination of both. Once the base plate is off, you'll need to carefully remove the beater bar, paying close attention as to how the end pieces come out with the beater bar from the vacuum frame. They have to mate back up in the same way they come out. Also note where the belt will ride on the beater bar. While you have it torn down this far, clean the suction cavity as vacuums usually plug up in this area, and remove any hair, ribbons, thread and the like that has gotten wound around the beater bar. Slip your belt over the motor shaft and then slip the beater bar into the belt. It'll feel like you need another pair of hands, but it can be done. Slip the beater bar and sockets back into the vacuum frame, and look again to make sure that the ends are seated properly. Test your work by revolving the belt a bit by hand, feeling for the resistance of the belt and smooth operation. Reinstall the base plate. That ought'a 'bout do it!
Best regards, --W/D--
Aug 05, 2009 | Kirby Vacuums
Low suction
Hi, You can take care of both things at once. Here's how:
Unplug and flip your vacuum over, beater bar side up. Remove the cover base plate that surrounds your beater bar. It's held on with either clips or screws, and usually "hinges" toward the front of the vacuum to release when the clips/screws are undone. Remove the base plate. The beater bar sits in sockets where it fits into the vacuum. Pay particular attention to how it comes out as you remove the beater bar, so it will be much easier to put it back together. If your belt is good, it will want to come off with the beater bar, but will remain attached to the motor. If necessary, slip the belt off of the beater bar. Behind the beater bar, you'll see a cavity. This is where the vacuum pulls the dirt from the beater bar. Look up into the cavity; stuff almost always hangs up in there. Remove any debris that you can find. While you have your beater bar out, look at the ends, where it fits into the sockets. Hair and other material catches on the beater bar and winds around it. If it is in and around the sockets, it causes the vacuum to have to work harder to clean. Remove any debris that you find on either end. Get your new belt and place it on the motor shaft. Slip the beater bar into the belt, and install the beater bar and sockets back into the vacuum frame. It takes patience so don't worry if it takes a few tries to get it right. Once in, test your work by revolving the beater bar a bit with your hand. You should be able to feel the tension of the belt as it turns the bar and the motor shaft. Take one more look at the sockets, just to be sure that they are in the proper place, and that the beater bar is level in the frame. Reinstall the base plate. This should have you finished at this end.
Best regards, --W/D-- please feel free to rate this solution! Thanx!
Aug 01, 2009 | Eureka 2961AVZ Bagless Upright Vacuum
The agitator on my kenmore progressive vacuum won't keep going. It keeps stopping while vacuuming.
This sounds like the belt that drives the beater bar on the vacuum. The beater bar bearings and brushes could be plugged with debris and/or the belt is simply worn out and needs to be replaced. Unplug the vacuum, turn it over and look for clogging.
If you can't see any, then you may need to remove the bottom plate of the vacuum and clean out and/or replace the drive belt and clean the area. These belts and other components are usually available at Sears Hardware or main stores. Make sure you get the correct belt for your vacuum.
If the beater bar brushes are substantially worn, it would also be a good idea to replace the beater bar as well. These parts wear out after a few years. Try to work on the unit in a location that is well ventilated and the debris doesn't make a mess inside your house.
Apr 27, 2009 | Vacuums
Beater bar belt too loose
You need a new belt, they stretch after awhile and will slip.
Apr 07, 2008 | Vacuums
How to change belt on this model?
Changing the belt on this nifty little machine only seems difficult until you find all eight of the screws that hold the entire assembly together, and the nice thing is you get to totally ignore the torx style screws altogether.
There are two screws in the bottom of the unit just forward and to either side of the beater brush, remove 'em.
Flip the vacuum over and remove the two screws holding the top in place. One is located under the removable suction hose near the right rear wheel, the other is in plain sight over the left rear wheel.
After you pop the top off you'll see the dark clear plastic housing that covers the beater brush and belt assembly. It is held in place by four more screws, three on the back side of the beater and one on the front side in the center of the machine.
Change your belt, clean your brush and tell your kids to get back to work while you take something out for dinner and open a cold one.
Gregory Glaser
Fixer of broken things
Nov 08, 2007 | Hoover U5262-900 / U5260-900 / U5266-900 /...
Dyson DC17 Animal Bagless Upright Cyclonic Vacuum Logo
146 people viewed this question
Top Dyson Vacuums Experts
AskDyson
AskDyson
Samyfam
Samyfam
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
