Question about Dometic Rooftop RV Air Conditioner
Batterys went dead in remote put in fresh
BATTERYS WENT DEAD IN DOMETIC FURNACE/AIR REMOTE WHILE FURNACE WAS WORKING CHANGED BATTERIES IN REMOTE NOW REMOTE WILL NOT RESET AND FURNACE WILL NOT TURN ON
    Problem Solver:
  • 18 Answers
You have to hit the rest botton on the furnace for the led to pick up the remote always you can go to your rv manu and it will help you out if not you can go to any rv lot and they will show you how to rest your systems
Posted on Dec 10, 2009
  • mspendlove32 Dec 10, 2009
Vizio remote XRT302 is not working after 3 weeks of use. Any ideas besides changing the batteries?
TRY FRESH HIT BATTERIES FIRST!
I WAS ABOUT TO ORDER A NEW REMOTE, then read this thread. I went back and messed around with the remote. I checked the batteries and the had power but wee in the low yellow reading. I put in fresh hot new ones BOOM it was working just fine.
Thanks for all y'allZ commits.
Sam B.
Apr 06, 2013 | Televison & Video
How do you know remote is working?
Fresh batteries in remote? Will AC turn on by manually at ceiling assembly? Little green or red light on at ceiling assy? Have you checked Carrier site for manual to download?
Feb 23, 2013 | Dometic Rooftop RV Air Conditioner
Our remote control will not work with our Dometic Model 57915 unit. It used to when you changed the temperature up or down you got a beep from the unit. When you push the on/off button, it used to beep...
The comfort control center requires 12 VDC . If a fuse blew that feeds 12 VDC to control box at ceiling for some reason in your panel when unplugged accidentally, that would cause the remote/wall and control box at ceiling not to communicate.
Jun 05, 2011 | Dometic Rooftop RV Air Conditioner
SO basically my furnace just stop kicking on the heat at some point last night. I have it set on an auto temp around 70. By the time I noticed it being cold in the house I went up to the thermostat and...
I want you to do a simple test to verify that this is a thermostat problem for me. Start by removing the thermostat from its' mounting, next locate the red and white wire terminals place a jumper between them. If the heater now runs it is the thermostat went bad on you, if it does not run please check all connections both to the thermostat and to the furnace making sure that your wires have tight connections and are not broken. I am really leaning towards the thermostat being bad here. Sorry for the bad news but really strong feeling. Good luck
Jan 12, 2011 | Goodman Heating & Cooling
Can't get my dometic a/c or the furnace to work fuses are good how do you trouble shoot a remote . It doesn't have an adjustable therastat. it's in the remote.
Hi, I am sure you have replaced the batteries 1st thing, but still nothing? Can or are you able to get to the unit fairly easy and check to see if you have power to this system? That's what you need to do first, or check down below at the fuse box to see if the is actual power going to the load side or unit side.I would think even though you have a remote to control this unit, it would also have a stat for manual control? If power is good but the remote is not working, you would have a fault from the remote to which ever part of the system the remote Links with. You would have to have this remote checked out unless you can look the unit over for voltage problems like I mentioned to you. Let me no what you find out. Best of luck,
Shastalaker7
Nov 22, 2009 | Dometic Rooftop RV Air Conditioner
Power went off while ac was running. Now ac will not run. Has a wall mounted controller with a hand remote.
if it is a mini split you have to set date and time on remote before unit will work remove batteries from remote and start over
Sep 29, 2009 | Dometic Rooftop RV Air Conditioner
REMOTE IS DEAD
Hi, try to change the battery's that can be the reason for it to not work.
Muzzi_123
Jul 08, 2009 | LG LS-K2430HL Heat Cool Mini Split Air...
Suburban RV Furnace
make sure fan is set auto its just seeing fan motor now
Jul 06, 2017 | Dometic Rooftop RV Air Conditioner
Dometic Rooftop RV Air Conditioner Logo
295 people viewed this question
Top Dometic Heating & Cooling Experts
Bill Long
Jay Finke
Jay Finke
Are you a Dometic Heating and Cooling Expert? Answer questions, earn points and help others
