Question about Toshiba Satellite A25-S207 Notebook
Flickering screen How do I reseat the video cable?
  • 1 more comment
  • Codin5 Jan 19, 2008
    Starts at login and continues from there. Shows double images of everything. Fix the built in screen.
  • Codin5 Jan 20, 2008
    Will try, thank you.
  • Patrick  Haines
    Patrick Haines May 11, 2010
    When does the screen flicker? Are you using another monitor on this unit? Or are you just trying to fix the built in screen?
    Genius:
  • 1,067 Answers
Reaset cable fold screen all way down pop up that top panael were u powerr on at flat small screw head then uder there u can see cable to screen push it down all way maby bad screen get new one
Posted on Jan 20, 2008
Laptop monitor flickering
You could have a faulty ribbon video cable or a loose video connection to the motherboard. Reseat the video cable connection to the motherboard.
To get to this connector you most likely need to remove the keyboard to get access to this connector.
Mar 30, 2012 | Dell Inspiron N5030 Notebook PC
Laptop screen flickering CQ50-110US
unseat and reseat the LCD cable behind the LCD and also where it connects to the motherboard. If that doesn't solve it, then try another lcd cable. If that doesn't fix it then that means the LCD is bad and would need to be replaced.
Apr 19, 2010 | HP Compaq Presario CQ50-110US Laptop
Flickering of the screen
just open the system and reseat the display cable...
Sep 20, 2009 | Acer Extensa 5420-5687 Notebook
My ds lite images on the top screen flickering.
Open up the DS and then unseat and reseat the ribbon cable that goes to the screen.
Once you do that, turn on the DS and if the screen is still flickering then the screen will need to be replaced.
Here is a tutorial on how to open up the DS and what the ribbon cable looks like:
http://www.instructables.com/id/Replace-the-top-screen-of-a-Nintendo-DS-without-o/
Sep 02, 2009 | Nintendo DS Lite Console
MY IBM THINKPAD HAS A BLACK SCREEN.WHAT MIGHT BE THE PROBLEM AND SOLUTION?.
You could have a defective screen - a defective inverter or a CCFL lamp or simply the video cable needs reseating. After reseating the video cable and the problem is still there then :- To determine if you have a LCD screen or video card problem, read this and follow the instructions. Defective CCFL backlight, it may have the following symptom: Screen flashs on red/pink and off. Picture stays on in red and slowly be come normal. Picture flickering with dim display or appear black. Picture flickering on and off. All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp Connect an external monitor to your laptop and power it up, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight. Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case. The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills. Check out www.lcdparts.net for parts, repair service and DIY info.
Jun 16, 2009 | IBM ThinkPad T40 2373 Notebook
Screen goes off after every 2 secs. Pls help
Jun 12, 2009 | Sony VAIO VGN-N130G/W Notebook
LCD display is not working
Jun 08, 2009 | Compaq Armada M700 Notebook
Note book
You most likely have a defective screen - a defective inverter or a CCFL lamp or simply the video cable needs reseating. After reseating the video cable and the problem is still there then :- To determine if you have a LCD screen or video card problem, read this and follow the instructions. Defective CCFL backlight, it may have the following symptom: Screen flashs on red/pink and off. Picture stays on in red and slowly be come normal. Picture flickering with dim display or appear black. Picture flickering on and off. All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp Connect an external monitor to your laptop and power it up, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight. Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case. The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills. Check out www.lcdparts.net for parts, repair service and DIY info.
Jun 03, 2009 | HP Pavilion dv6000z Notebook
THE SCREEN WILL NOT WORK
  • Screen flashs on red/pink and off.
  • Picture stays on in red and slowly be come normal.
  • Picture flickering with dim display or appear black.
  • Picture flickering on and off.
May 15, 2009 | Toshiba Satellite 1805-S204 Notebook
Monitor screen shaking and flickering
Check to make sure the cables are connected tightly. Wiggle the cable, does it get better or worse? Might need a new cable. And reseat the video card inside the computer. If that doesn't fix it, then yes you will probably need a new monitor.
Jan 15, 2009 | Acer AL1917W LCD Monitor
Toshiba Satellite A25-S207 Notebook Logo
43 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
