Question about Kitchen Ranges
The oven ignition system seeems to have stopped working. The oven fan is likewise, but note that the oven light is still ok. Also note that the oven burner still ignites if a taper is used together with the ignitor operating lever.
  • jcjb Dec 10, 2009
    Thanks VToolman for your prompt advice. Replacing the ignitor does sound doable, if I can get one.
    However, this appliance was made in Australia 17 years ago by Craig and Sealey, a company that's now part of the global Electrolux empire, and a local serviceman has told me the Empire's policy is not to support product beyond 10 years! So I'm not very hopeful that your Sears will be able to help.
    But anyway, the C & S operating guide tells me this cooker is an 094 Series, sales code GEDAFS, and the cooker itself is labelled: model 094C2F20WT, serial 2002 5746 71.
    Seasons greetings from Tasmania, Australia :)
  • Kitchen Ranges Master
  • 5,138 Answers
I dont know if this will help you are not but Call Encompass Parts tell them your Make and give them your model number if they have it in stock you can get new ignition 1-800-638-3328
Posted on Dec 10, 2009
    President:
  • 704 Answers
Hello JcJb, All signs point to the ignitor being faulty and in need of replacement. Without a working electric ignitor, the gas will not light and thus the oven will not work properly.
Unfortunately, without a brand and model number it will be difficult for anyone to provide you with the replacement part you'll need. However, here's a link to www.searspartsdirect.com that you can enter in the full model number of your range and get a complete parts listing and line drawing showing all the parts for your particular oven.
The key to replacing the ignitor is to disconnect the oven from the electrical outlet. Then with the oven racks removed, you should be able to remove the defective ignitor (held in place with one or two screws) and then you can remove the ignitor and disconnect the two wire leads from it. Some ovens have the ignitor held in place from the back side of the oven, so you'll have to check the line drawing to see which method your oven employs to secure the ignitor. Either way, it is relatively easy to change out yourself.
Simply connect the new ignitor to the wire leads and reinstall it into the oven. Plug the power cord in and give it a test.
Hope you find this Very Helpful and best regards!
  • Mark
    Mark Dec 10, 2009
    Hello again JcJb,
    Did some searching and it appears that there are some replacement parts available, but they aren't listed with a cross reference by model numbers of the stoves/ovens. However, they do have pictures, which should make it pretty easy to locate the correct replacement part.
    Some of the parts are universal, so you might have to adapt it for your particular oven.
    Here's some of the ignitors I found (on page 11 of the brochure, page 13 of the elecronic file)
    http://www.reece.com.au/new/pdf/products...
    Please note that the contact phone numbers for Reese gas spare parts are located on page 51 and 52 of the electronic document.
    Give the various ignitors a look and see if one of them is close to what you have. You can also give the folks at Reese a call, as they might have a more complete cross reference list with the Craig and Seeley model numbers, as most appliance manufacturers used third party components to build their models.
How to replace light
Is is a gas unit? Check the igniter if it turns red. Try on broil igniter.
Please remember you can not touch the surface.
Jun 29, 2015 | Ovens
Smeg SE290x-5 oven stopped working
Replace igniter if gas .or if elect replace element
Nov 09, 2011 | Smeg Ovens
Out on boat when starter motor on mercury 70hp 3cylinder stopped working.back on shore took it off and put it back on.when turning enine over starter seeems to spin in wrong direction and not spinning up...
Spin Backward? that's not good. Would check the battery connections. If backward- you may have other problems associated with backward battery connections and ignition systems. If it's just an optical illusion- you should try to bridge the starter solenoid with a jumper to the big terminals and see if the starter is really bad or just a low battery. If your battery is down, your charge system on the motor may be giving you trouble.
Your starter when sitting on the bench and directly hit with 12 volts should jump substantially with the torque. If it just spins like a fan motor- it's shot.
If jumping the solenoid makes it work, thats the problem. But clean or replace the cable ends on the bat and solenoid first.
Just a note: you should be able to pull start that motor by wrapping a noted rope round the pulley on top of the flywheel. If you ever get stuck again. Just watch where the knotted end of the rope goes.
May 03, 2011 | Mercury Mark 30 Hipo Outboard Motor...
Fan oven stopped heating
Is the fan working in the oven if not then check if the clock needs resetting.If the fan is working then it is more likely that the ring element around the fan has failed.Check also if the thermostat light comes on,this is an indication it may be ok.
Hope this helps.
May 25, 2010 | Ovens
Neff U1721 bottom oven not heating fan & light are ok
Yes it will need a new element, if the fan runs and temperature light comes on then the element is gone.
Jun 08, 2009 | Neff U1721 Double circotherm Electric Oven
Microwave oven stopped working
This is most common in over the range microwaves. Cooking grease migrates into the door switches, resulting in the symptoms you list. Replace the door primary and secondary interlock switches and you should be cooking again. NOTE: be careful not to touch other wires! Even with the unit disconnected from power, if you happen to have a bad bleeder resister in the high voltage capacitor you can still get a nasty zap !
Aug 27, 2008 | Ovens
Stoves 900DFa dual fuel cooker
check to see if one of the oven elements are burned into if you have an oven cord on it turn the breaker off and check the cord where it connects to the oven
Mar 15, 2008 | Stoves 900DFa Dual Fuel (Electric and Gas)...
Whirlpool SF365pegq
The way the ignition system in most of today's ovens work is like this:
1. Set the oven or broiler temperature.
2. The igniter begins to glow.
3. Once the igniter reaches a certain current potential, the gas safety valve opens.
4. Gas is introduced into the manifold and you have ignition.
5. NOTE: It can take roughly 30 - 90 seconds from the time you set your oven temp to the time it takes for the gas to ignite.
NOTE: This is a designed safety feature of the oven to prevent free flowing gas from accumulating in your home without ignition. That's why you typically don't hear any gas flowing when you have an igniter problem. You might think you have a gas problem when actually you have an ignition problem.
TWO BASIC IGNITER TYPES:
Carborundum (Cylindrical in shape) - needs to produce 2.5 to 3.0 amps for the gas safety valve to work.
Norton (Rectangular in shape) - needs to produce 3.2 to 3.7 amps for the gas safety valve to work.
NOTE: There is a UNIVERSAL FLAT BAR igniter on the market as well, that can be used as a substitute if the igniter type that came with your range is not available.
An easy way to determine if you may have an igniter problem is to check BOTH your oven features. If the oven doesn't light, check the broiler and vice versa. Since both the BROIL manifold and BAKE manifold are fed from the same gas source, but have separate igniters, it's an easy assumption to make that the igniter may be bad, if one or the other doesn't light.
The igniter typically goes bad in one of two ways, the igniter either stops glowing completely, or becomes weak over time and doesn't produce enough current to open the gas safety valve (in this case the igniter will still glow but the oven still won't light). Longer ignition times can be another symptom of an igniter possibly going bad.
For this solution, however, we're going to assume you have a bad igniter and need to replace it. Follows these steps:
NOTE: The same method applies to both the broiler and bake manifold.
1. UNPLUG the range and turn the gas off if you have a local gas cut-out valve (it is recommended that you do).
2. Open oven door and remove (if possible). Refer to your owner's manual to see if there are instructions on how to remove the oven door. Some have spring-loaded locking hinges, while others just lift out. If you cannot figure out how to remove the oven door, use care not to lean on the door or put too much weight on it. A common complaint following any kind of oven maintenance is that the oven door doesn't shut correctly any longer. This is usually caused by bending the hinges or springs coming loose.
3. Remove the oven racks, and remove the oven pan. (There are usually two screws either in the back or front of the oven holding the pan in place).
4. Remove the Flame Spreader. This is a metal plate on top of the manifold.
5. The igniter will be mounted directly to the gas manifold. Follow the wires that lead to igniter. It will either be plugged into a connector, or be connected together with ceramic wire lugs. Your replacement igniter should come with extra ceramic wire lugs. In the event the plug does not match the one on your range, cut the wires and connect using the ceramic wire lugs. DO NOT use standard wire lugs, they are not heat resistant and will melt.
6. Unplug the old igniter and remove the mounting screw holding it to the gas manifold.
7. Install new igniter on gas manifold using care not to handle the element on the igniter with your hands. The oil from your hands can cause damage and/or premature failure. The igniter is also considered FRAGILE.
8. Reconnect the wires using the recommendations mentioned in Step 5.
9. Plug in the range, turn the gas valve back on and do a visual test by setting the oven temperature to the desired range. Allow 30 - 90 seconds for the igniter to light the gas. Turn oven off and allow sufficient time to cool. If the oven has only been lit for a minute or so, the cool down period will be brief.
10. Reinstall the flame spreader, oven pan, and racks. Reinstall door if necessary.
Most igniters cost around $50. Prices will vary with models.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Feb 22, 2008 | Whirlpool SF369 Gas Kitchen Range
Kitchen Ranges Logo
100 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
