Question about Honeywell CT3200 5-2 Day Electronic Programmable Thermostat Heater
My honeywell theromstat is stuck on HOLD 62 degrees and when I not turn on or go higher no matter how higher i push the heat
    Problem Solver:
  • 18 Answers
The honeywell theromstat is life time so no matter what happens you can call any hvac company and ask them it does sound like your batters are going dies are also you need to get your line check now i dont know if you have it on two wire are all four just maybe it could be that you need to get that look at
Posted on Dec 10, 2009
SOURCE:
Our thermostat has "HOLD" on
Hi, Either push the program or resume program button... or on some you need to push the hold button again to take the hold off... Check the manual if all of this does not work... but the t-stat may be fried...
Here is a tip that tells you how to get a manual for most any Honeywell productonline...
Manual Honeywell How to Find Honeywell Manuals
heatman101
Jul 24, 2011 | Honeywell Electronic Programmable...
The temperature on my honeywell thermostat is set to 89 degrees and does not want to change no matter what. The model is RTH2300. Please help because the heat is really unbearable.
Just google RTH 2300 for the manual, check that the hold is not on, if it is push it to turn it off, if not read thru the manual. On most stats if the unoccupied set point are blocking the occupied set points run the unnocc. temp down and then set the occ. set points down. Good luck
Jun 30, 2011 | Heating & Cooling
My Honeywell thermostat does not heat the house to the selected temperature. It will come on but not long enough to heat the house to the temp I selected.
Verify that you have heat coming from the vents.
Also do you use a heat pump system with electric emergency heat?
It may be that if it is to cold outside that the heat pump can not handle the load due to the cold outside and you will need to turn on the emergency heat.
Keep me posted.
FlaTech.
Thank you for using FixYa!
I’m happy to help further over the phone at https://www.6ya.com/expert/michael_341f3f9dee622e54
Nov 17, 2009 | Honeywell Heating & Cooling
My Honeywell TH4210D1005 Thermostat will not respond
well with 62 outside temp and then maybe a little solar gain and body heat you very well could be 5 degrees warmer then outside
Apr 06, 2009 | Honeywell TH4210D1005 Heater
Honeywell T87f 3855 Doesn't Activate Heater
thats becaue you need more than this zone working like you said about the master/slave this zone is a slave.
Jan 25, 2009 | Heating & Cooling
Honeywell programable thermostat not recognizing nigh time settin
This is the problem you have when you rely on "modern electronics". Suggest you buy a manual 'stat and just turn down the temp at bedtime. Make it cold and use a blanket, that is what we did in the " good 'ole days".
Jan 12, 2009 | Honeywell Programmable Heat Pump...
Cannot set heat setting by using "hold" feature
make sure it is not telling you room temp, some of the Honeywells, will display room temp over desired temp. check that, if it wont let you switch temp than buy a new one, if you dont have a heat pump a new cheap stat is around 20.00.
Dec 31, 2008 | Honeywell Programmable Thermostat Heater
Heat will not turn off
Call 1-800-341-0110, Honeywell Residential tech service.
Nov 11, 2007 | Honeywell Programmable Thermostat Heater
Heating & Cooling Logo
1,212 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
