Question about T-Mobile Sidekick® 3 Cellular Phone
Sidekick 3 powers down
After about 30 min. my sidekick will shut down and not come on until I charge it again. It also takes some tricky effort to get the charger to work properly. The repair center said they could not fix it. Can it be fixed or am I stuck with a paper weight? What is the web page to contact the manufacturer?
  • 636ian Jan 20, 2008
    Thank you for the suggestion but I think it may be something else. The only reason I say that is because I have already bought a new battery and the phone will fully charge the battery that is in it. Is there something else that may be wrong with it? I might try the craddle charger anyways just in case.
    President:
  • 625 Answers
The Sidekick 3 has an issue with the charging port going bad. It sounds like your may be having this issue. That or your charger is going bad. You battery sounds like it may be an issue as well.
The charging port issue can be worked around by getting an cradel with a spare battery charger slot. An extra battery is a good idea as well. That way you can have one charging with the other one is in use. A new battery and a cradle charger go for about 30-40 dollars on ebay.
Check out Sidekick Battery Charger to see whats available.
Posted on Jan 20, 2008
The phone will not turn on
Sarah-
The previous poster has a good point, If you have a friend that has a sidekick 3 or sidkeick ID, swap batteries and see if they work.
THe sidekick 3 is notorious for the charging port going bad. It is tricky though, because the little orange light comes on but no power is actually getting to the battery.
In this situation, I recommend a external battery charger and a spare battery.
Check out the link below for those.
http://www.fixmysidekick.com/shop/repair-replacement-parts-for-sidekick-3/Sidekick-3-Spare-Battery-Charger
Mar 02, 2009 | T-Mobile Sidekick® 3 Cellular Phone
Sidekick won't turn on
If it is a sidekick 3, then the charging port has gone bad.
It runs about 80 dollars to get fix at cellulardr but can do a workaround for about 30.
You will need to get a charging cradle that has spare battery slot. See the link below:
Sidekick 3 Battery charger
I also recommemd a spare battery so you can have one charging.
Sidekick 3 Battery
Nov 27, 2008 | T-Mobile Sidekick® 3 Cellular Phone
Sidekick wont turn on
that happened to me before.
all u have to do is take ur sim and battery out and then wait for 5 minutes and re enter them into ur phone...!
Oct 21, 2008 | T-Mobile Sidekick® 3 Cellular Phone
Sidekick3
The sidekick 3 has an issue with thte charging port. If you have a friend with a sidekick 3 or sidekick ID, try one of their batteries. If your unit powers on, the charging port has gone bad.
the repair for a charginf port runs about 80-100 dollars. A cheaper work around is to get a charging cradle that has a spare battery charger slot. They run about 30 dollars on ebay and it will allow you to charge the bettery seperate from the phone.
Check out the following link for cradles.
http://repairmysidekick.org/SideKick-Repair-Parts/Sidekick-3-Spare-Battery-Charger
Mar 29, 2008 | T-Mobile Sidekick® 3 Cellular Phone
Busted Sidkick 3 Charger Port
Sorry to hear that. The Sidekick 3 is notorious for the charging port getting busted.
If you take it apart, you can see that it is soldered in 5 places to the motherboard. Maybe one of those solder joints came loose.
This link will show you how to take apart your sidekick.
Sidekick 3 Disassembly
Another option is to get a charging cradle that has a spare battery charging slot. They go for about 30 dollars shipped on ebay. This will allow you to charge your battery external from the phone or if you have an extra battery , have one charging at all times.
Check the followinf link to see availability.
Sidekick 3 Spare Battery Chargers
Feb 03, 2008 | T-Mobile Sidekick® 3 Cellular Phone
T mobile sidekick 3
Perhaps the battery is not in correctly, the phone was dropped in water, The phone is broken, or you're pressing the wrong button.
Nov 29, 2007 | T-Mobile Sidekick® 3 Cellular Phone
Chargingb the phone
If it is a single pin charger that just plugs into the phone it sounds like the pin inside the phone has broken from the board which is why you have to wriggle it or wrap it up to get it to work.
this can be repaired but costs are determined by your repairer.
Nov 03, 2007 | T-Mobile Sidekick® 3 Cellular Phone
SideKick Needs Repair
Change the flex cable the flex cable is the silver thing you see when you fold the screen half way
Oct 19, 2007 | T-Mobile Sidekick® 3 Cellular Phone
Wont charge
well i suggest you take it back to the shop where you got it from they will most likely send it off to the specialists free of charge , because it is a technical problem .
The most likely reason of this problem is maybe your putting the charger in to hard and its pushing it back so its not alowing it to charge? It is quite a bad phone in that aspect
Oct 06, 2007 | T-Mobile Sidekick® 3 Cellular Phone
Sidekick 3 keeps shutting off
Well it is quite a persistent problem for all owners of this phone and my suggestion is to take it back to the shop  because no1 really has a solution to fix it ( well at least i dont ! )
the only thing i can think of is the battery , it tends to break when the battery goes low and then it just shuts down! hope i helped bye .
Sep 29, 2007 | T-Mobile Sidekick® 3 Cellular Phone
T-Mobile Sidekick® 3 Cellular Phone Logo
Top T-Mobile Cell Phones Experts
Starnley Johnwells
Starnley Johnwells
Computer Repairing
Computer Repairing
ismael castillo
Are you a T-Mobile Cell Phone Expert? Answer questions, earn points and help others
