Question about HTC XV6900 Cell Phone
It will not turn on...the phone shows a green charged light but when i try to turn it on the verizon symbol pops up and it will just restart itself instead of loading...
Mobile phone is a samsung galaxy s 111 mini just wanted to know if there are any light to indicate a message or charging
Yes .. Samsung ain't have a tiny light on top showing its charging however on screen it shows if its charging and for text messages thr is envelope kind symbol when a message is pending for reading in case someone closes pop up message that shows 'You got some unread messages'
Jan 27, 2015 | Samsung Cell Phones
I put my Droid Razr on charger but battery symbol comes on with ? mark. Won't charge or turn on.
1. Turn off your phone when it's not in use. If you're not using your Verizon Wireless Razr, then shut it off. Your battery will last much longer if you regularly do this.
2. Charge your phone less. If you charge your Razr nightly, then your cell phone battery won't last long. Try to charge your phone only a few times a week to extend the battery life.
3. Keep your Bluetooth turned off when you're not using it. Applications, like Bluetooth, are notorious for sucking the power from a cell phone battery.
4. Protect your Razr from extreme temperatures. Your cell phone battery lasts longer if kept at room temperature.
5. Discharge the Razr fully. Before you charge your phone, let it completely die. You can extend the life of the battery by regularly discharging and then fully charging it.
6. Leave the battery in the phone. Keep the Razr battery dry and free of dirt to prolong its life.
Aug 20, 2012 | Motorola Mobility Motorla MOTXT912 DROID...
Samsung brightside will not turn on.
If the phone lights up when you plug in the charger it is probably the ribbon cable that flexes every time you open the keyboard. About 25 bucks from cellphonerepairshop.com. Be sure to flip up the little latches on the flex cable ends before attempting to plug or unplug the cable ends.
May 26, 2012 | Samsung Verizon Brightside Sch-u380 Black...
Charging problem
I think the charging port is bad and this could be as a result of factory error since the fault is not from you. The phone restarts probably because the charging ports is bridging.
I will advice that you purchase a desktop charger that will enable you charge the battery seperately and when the battery gets full, you insert it into the phone. You could get another battery so that while you charge one, you use the other.
Or if you can look for a repairer, that will help you fix the fault of your phone.
Best wishes
Nov 16, 2009 | Motorola Mobility RAZR2 v9 Cell Phone
Our Pioneer Elite Pro-520HD turns off by itself.
These intermittent failures are hard to find. The "pop" noise you're earing might be cause by a coolant moisture near the high voltage connection, sometimes the coolant might leak onto the CRT causing the high voltage to arc creating a conductive pattern for the high voltage to discharge and that will also cause the TV to shutdown.
Let me know if you require further assistance.
Sep 29, 2009 | Pioneer PRO-520HD 53" Rear Projection...
When I turn on my phone Verizon Wireless logo pops up and stays
Try taking it to a Verizon Wireless store for troubleshooting. This problem appears to be more than just the battery, as fully charging it did not help.
Jun 30, 2009 | LG VENUS Cellular Phone
EnV stays on VERIZON LOGO then blinks and restarts
ok, here is something odd. I get a new phone, my daughter was going to take the env and have it fixed (verizon will replace it with a refurbished one for $50). I had not shut if off, so the battery was completely drained. She plugged it in and charged it, and now it works, of course, after I bought a new phone. Hopefully this will work for others.
Aug 20, 2008 | LG enV VX9900 Cellular Phone
Charging problems
have you tried your dads battery in your phone it sounds like the battery is dead if your charger works on your dads phone then you know it not the charger the chances are it is the battery it would only be the phone if it has been dropped or got wet if this hasnt happened then the problem is the battery if your dads battery is the same then try charging his batt through your phone that way you would know if it was phone or battery.
If you take the phone into any phone shop they will test the phone and battery for free for you they can try the battery and also try a new battery in your phone and they will tell you if it is phone or battery but from my experiance it is going to be the battery let me know how you get on ok
Nov 27, 2007 | Motorola Mobility MOTORIZR Z3 Cellular...
HTC XV6900 Cell Phone Logo
64 people viewed this question
Top HTC Cell Phones Experts
Charles Blake
Charles Blake
Level 1 Expert
D. E. Hev
ChuckyMo
Are you a HTC Cell Phone Expert? Answer questions, earn points and help others
