Question about Lanier UNKNOWN
Lanier Colour printer
There is paper in tray 1 but it wont read it
Called out the tech, and it was a small sensor that had fallen off.
Posted on Dec 10, 2009
Cannot insert Tray 1 into the machine. it says to "Reset Tray 1 correctly". What are they saying.
It is not seeing tray in the machine. Might be a piece of paper stuck behind the tray stopping it from going in and stopping it from detecting the tray?
Apr 02, 2011 | Lanier 1205 Copier
When printing paper gets stuck. Not rolling thourh
LANIER COPIER PROBLEM SIMILAR TO RICOH COPIER PROBLEM AND IF THE PAPER GOT STUCK ,FIRST YOU MUST SEE AT WHICH
LEVEL/IS IT CRUMBLEB OR JUST MESHED THROUGH OR JUST UNABLE TO PASSED OUT FROM TRAY.
IF PASSED OUT FROM TRAY BUT STUCK AT DUPLEX AREA ,THAT MEANS YOUR FINGER AND MYLAR/RUBBER ROLLER MUST BENDED OR NO GRIP SO YOU HAVE TO REPLACED IT.
IF STUCK FROM THE TRAY, EITHER YOU DID NOT NOT " FAN" THE PAPER BEFORE USE AS NO AIR BETWEEN THE PAPAERSOR HAVE TO REPLACE THE PAD AND UPLIFT ROLLER RUBBER[1 PIECE ONLY PER TRAY]
IF STUCK AT FUSER AREA,JUST CHECK THE UPPER & LOWER ROLLER, THERE SHOULD BE THE ROLLERS NOT MEET TOGETHER. NEE MORE CLARIFICATION
Mar 31, 2010 | Lanier Office Equipment & Supplies
Tray 1 is not set correctly, yet everything is set right. Help
81/2 x 11 is not a custom paper size. Set tray 1 to 81/2 x11 plain paper and set your print driver the same way. the descriptions have to match or it will not print.
Jan 05, 2010 | Lanier UNKNOWN
I have a Lanier Ld045, tray 1 doesn't recognize that there is paper in the tray. It seems that after the tray is closed some sensor is trying to read whether or not there is paper in the tray but after a...
yes ther are paper sensors. i have never seen an arrow there. make sure in you user tools under paper settings they match the type and paper size for drawer one.
Dec 30, 2009 | Office Equipment & Supplies
I have a lanier 5265 keeps saying paper misfeed
Hello sir; The paper stuck in your paper tray ,I believe in first tray, pull out tray you will find out.
May 02, 2009 | Lanier 1205 Copier
Lanier 5613 copier paper sensor
If you are talking about the sensor in the paper tray tape the sensor so it is "actuated" and tuck it in the slot near by, the only problem you will have is the copier wont know when you are out of paper. The switch mounts break.
Mar 31, 2009 | Lanier 1205 Copier
Lanier 5645 cannot reset printer red button just keeps coming on
when you press the 'red' button, it probably says 'paper mismatch, or load "XXX" paper, and you can override it by selecting one of your paper trays manually? It is likely a "legal size document' and you don't have legal size paper loaded, or something along those lines. Try printing the document after manually selecting the paper size/tray (turning off auto paper select) in your printer preferences dialog box on your PC first.
Mar 02, 2009 | Lanier Office Equipment & Supplies
Lanier Printer LP131n
Don't be mad, but it never hurts to ask if you've checked the following...
  • Made sure that the printer has not been set to use legal or A4 paper in tray 1. You can set this through the options listed in the menu map on the printer display.
  • Have you checked that the Word document is not setup in the "normal.dot" or in the document itself to use A4 or legal as the default paper type.
  • Is the small paper resize lever in tray 1 pushed flush against the 8.5x11 paper in the feeder so that it detects properly.
Less obvious...
  • Did you make sure that the print properties are not setup with the wrong tray configuration...i.e. listing a duplexer when one is not present, additional trays, or a feeder?
If the answer is that you have done all of this and the issue has not been resolved, I would try looking for obstruction above the primary feeder tray, in the gear assemblies in and around the bottom of the printer and the tray, or around the paper sensor. (a small plastic lever in the front of the tray.
Jul 18, 2008 | Lanier Office Equipment & Supplies
The lanier printer in my office is saying -
there is a paper jam somewhere. sometimes two sensors are for the same area, open all doors remove paper trays look everywhere there is a green or blue handle
Dec 03, 2007 | Office Equipment & Supplies
Lanier UNKNOWN Logo
Top Lanier Televison & Video Experts
Alun Cox
quennie732
Are you a Lanier Televison and Video Expert? Answer questions, earn points and help others
