Question about HP Compaq Presario SR1503wm PC Desktop
Turns on and off
Well, I recently re-installed windows xp on this and I unplugged the hard drive to clean it up a little bit, but now when I turn it on it just turns itself on and off really fast and nothing comes up on the display (screen). It just does that a few times and turns off. I have no idea what to do to make it stop...
  • 81 Answers
Try removing the on board system battery for 10 minutes and replace, that should reset your bios possibly fixing the isue, if that doesnt work, u might hav broke a pin, or got the hdd wet
Posted on Dec 10, 2009
XPS-410 needs to have MCE 2005 Rollup two SP3 replaced by Windows 7 64 bit. Too many problems to list currently but will work limited programs
Not sure what you are trying to do. If you are trying to convert 32 bit to 64 bit Apps, try going to manufacturers website to look for drivers.
Win 7 will actually find the best drivers for your devices.
May 06, 2014 | Dell XPS 410 PC Desktop
I recently aquired an eMachine 566i2 with Windows ME. I upgraded to Windows XP Home Edition. The computer was running very slowly. I ran anti-malware and various utility programs, but there was no change....
The 566i2 has a Celeron 566MHz. That is very slow system compared to today's
standard. I'd suggest doing a fresh Windows XP Installation with the Hard Drive
formatted as NTFS. You need to be sure that the HD is completely wiped out
and clean. Also, download all the drivers necessary for Windows XP beforehand
and put them on a CD. That will save you lot of time after the installation.
Jul 19, 2011 | Microsoft Computers & Internet
Copy WIndows XP from one hard drive to another
Why are wanting to clone your hard drive to another on when all you need to do is install Windows 7 directly onto the new hard drive?
Are you wanting to save all your settings and data before you install Win 7 over the top of XP?
Jul 20, 2010 | Microsoft Windows XP Professional for PC
On my GT5220-(Athlon X2 64 3800,4G'S RAM)--I HAVE THE STOCK 250GB HDD/IDE THAT IS RUNNING XP-32 BIT,AND I AM TRYING TO ADD 500GB SATA HDD THAT HAS WINDOWS 7 ULTIMATE 32BIT UPGRADED FROM XP VER. EVRYTIME I...
ok get a windows 7 disk and turn of the computer and ad the hard drive switch on the computer and set it to boot from disk (seems windows is broken on the 500gb hdd) then boot from disk and install windows 7 to the 500 gb hard drive and set in the bios the boot select for the hard drive (if you use win xp more then make that boot primary) then go threw all the rigmarol of installing windows 7 to the 500 gb one and your done it will have bootable hard drives and will offer a choice when first switched on
May 15, 2010 | Gateway GT5220 PC Desktop
Windows XP won't start
for that you need winxp bootabler disk.
Tehn boot your computer with tht and go to recoverry console.
Then type in command prompt "chkdsk /r"
then press "y"
then it fixc error on harddisk.
Then after completing it restart your computer and boot with harddisk then it ok.
Jun 20, 2009 | Computers & Internet
My Hard Drive is 250 GB but I only see 137GB
Windows xp has a max Hard drive limit of 137GB, so what you see is totally right.
Windows XP did not support 48-bit LBA for ATAPI disk drives, which is what larger drives needs.
The service packs do address the problem but you need to have a copy of windows xp which includes at least service pack 1 on the installation.
The problem is when you install from your original disk, it doesn't include the service packs, so by the time you have got the system up and running the hard disk space has already been allocated.
Bios update wont help
controller card won't help either
Possible solutions:
If you can get hold of a new version of XP which includes at least service pack 1, you can re-install with this disk and it should find all your hard disk space
or
You can do what is called 'slipstreaming', this is when you burn the original XP disk and the service packs together on one disk, but it does take a bit of working out.
here are a few links which may help you more:
http://lifehacker.com/386526/slipstream-service-pack-3-into-your-windows-xp-installation-cd
http://support.microsoft.com/kb/303013
hope this al least sheds a little light on the problem
Bri
Feb 02, 2009 | PC Chips MB PCCHIPS M863G V5.1C w/XP2400+...
Hanging on detection of drive when installing Windows XP
Installing Windows XP on a SATA hard drive is not a straight-forward task as Windows XP does not recognize the SATA drive. In order to install operating systems such as Windows XP on SATA drives, the latest SATA drivers are required.Download SATA drivers for the motherboard from the website and integrate them with the XP installation CD using software such as nLite. SATA drivers can also be installed as third party drivers; you will be prompted during the installation process. Without proper SATA drivers, installing Windows XP on a SATA hard drive is not possible as SATA mode would have to be disabled in the BIOS to continue with the installation.
Installing Windows XP on a Serial ATA hard drive is not an easy task, because the system does not recognize SATA drivers at startup. Windows XP Pro SP2 fares a little better with SATA drivers, but here is what can be done in cases where the driver is not recognized.
Mar 31, 2017 | Excelstor Technology J880 Hard Drive
Boot up reformat hard drive etc
This could be an issue with the hard drive. Try formatting the hard drive, if the drive won't format, then it's bad. If it will, then you may have to create the D: drive partition. If you're running both operating systems out of one drive then you will not have to create the separate partition, but you will need to run the set up on both discs. If it will not allow you to create the partition or run the set up, then the disc may be corrupt or damaged. Let me know how this turns out.
Aug 08, 2008 | Computers & Internet
Windows operating systems
No, you cannot. You would have to do a clean install, which means wiping the old system off your hard drive (backing up everything you want to keep, of course).....nor can you go the other direction either...again, a clean install...
Here's the Microsoft page on it if you want to read it:
http://www.microsoft.com/windowsxp/using/64bit/russel_x64faq.mspx
Jun 05, 2008 | Microsoft Windows XP Professional
Windows xp pro
did u go into c moss and set your for it to boot off of the hard drive sounds like it tryn to boot off the cd hope this helps
Jan 05, 2008 | Microsoft Windows XP Professional for PC
HP Compaq Presario SR1503wm PC Desktop Logo
91 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
