Question about Compaq CQ60-215DX Notebook
My laptop would not charge, after I held it up on one side, it began charging. What's going on?
    President:
  • 3,278 Answers
Hello.
Sounds like a power jack problem.
If you move/wiggle the power adapter at the point where it connects to the laptop, and the power goes off and on, the power jack is the problem.
The power jack is inside the laptop and either needs soldering or replacement.
Hope this helps.
Posted on Dec 10, 2009
    Novelist:
    Scholar:
  • 100 Answers
You power cord connection is probably getting ready to go TILT on you. Take it to a LAPTOP repair company near your residence and have then check the soldier connections on the POWER CORD CONNECTION RECEPTICAL where it is attached to the Mother Board. This could save you a ton of money and maybe even your computer if the mother-board was to break totally. Some pressure, more than likely, has been applied to the Power Cord Connection in the Laptop. BE VERY CAREFUL. It could go at any time.....
Kindly,
Jim
  • 484 Answers
Just a suggestion, but if you held it up on one side and it started to charge, I would remove and reinsert the battery, then unplug and put the plug back in, to ensure that all connections are in tight.
-a.
    Scholar:
  • 155 Answers
You have to check it with your provider since it has perhaps loose contact from the board to your battery or from your entrance power supply to your board. Or please check with Compaq expert near you.
Thank you. Blessings
SOURCE:
My Aspire 5520-5043 began showing trouble to start: no power ligh
thats mean the charging system is faulty and sometimes there are breakages at the edge of the power cable where the pin is.try another power cable if it shows the same signal then the fault is on the laptop board.
Aug 02, 2010 | Acer Computers & Internet
Acer Aspire 4520 laptop: Battery not charging
If your adapter /charger has low voltage it will not properly charge the battery, any battery. Go that route and try another adapter..
Sep 06, 2017 | Acer Aspire 4520-5582 Notebook
Orange light just began flashing on my Dell inspiron 5100...everything else is fine! What's happening?
The battery is less than 100% charged; if it were fully-charged, the lamp would be green.
If it is "flashing", it's probably less than 10% charged.
Recharge it.
Jan 13, 2010 | Dell Latitude D600 Notebook
My 3200 laptop wotn charge unless charger held weirdly
obviously there is a wire broken in the cable. It could be fixable but your best bet is maybe to get a new charger... not too expensive though
Jul 06, 2009 | Averatec 3200 Notebook
Toshiba Laptop not Taking Charge
ya the solder connection connecting the ac power input onto the transformer is probably weak. aside from taking the case apart and resoldering the connection, not much else you can do.
Jun 18, 2009 | Computers & Internet
Problem with b130 batteries?
it is very possible that your a/c adaptor/charger is not working well enough to charge or keep you computer runing.
with a new battery you should put it on charge for several hour and charge it to the maximum.
do you know for a fact that the battery is new you put in it?
if the battery is used it may be trash also.
sort out the facts then look for the most obvious.
most obvious at this point it that a/c charger.
May 24, 2009 | Dell Inspiron B130 Notebook
My 8GB opal mp3 player wont cut on or charge up at all. What is the problem?
i held down the power button for about 10 seconds in resoponse to another answer when I was having the same problem as you, and then mine began to charge, when it would say battery is full before, but not work because of low battery. hope this works for you.
Apr 03, 2009 | RCA M4208 MP3 Player
No electrics
test the charging system w/ a multimeter,to test the alternator and voltage regulator and wiring w/ connectors.
Feb 18, 2009 | 2005 Hyosung GT 650 R
HP zv6000 battery problem
try this...can you run them without batteries, just on power from the power pack? that will tell us if those are the culprits?
and in meantime, check your warranty status for FREE here
Mar 01, 2008 | HP Pavillion ZV6000 Athlon 64 3500+ 15.4in...
Compaq CQ60-215DX Notebook Logo
76 people viewed this question
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Thomas F. Schneider
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
