I had an overheating problem which caused me to take apart and clean my components and then re-load my XP-Home operating system. The computer has an Athlon XP 3000 processor and a 500 watt Ultra power supply. My problem is that after a normal shutdown by XP, the system will not re-boot. If you select the re-start option in XP, the system re-boots normally. If you turn the main power off(on the power supply) and then press the "on" button on the case- the system re-starts. Does this sound like a problem with the case switch(Ultra) or possibly the motherboard? Any solution?
Sounds like a power supply problem although I have seen the same thing with a motherboard that is beginning to fail. Try a differtent powersupply, that would either fix the problem or eliminate it.
Posted on Jan 26, 2008
Jul 16, 2014 | Chaintech Computers & Internet
Test your PSU or replace it if your power supply units fan is not working your PSU is faulty
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect/ boot up
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your motherboard to your hard drive make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty or just replace them they are probably old and faulty ?
hope this helps
Dec 26, 2010 | Chaintech CT-6OJV2 Motherboard
Nov 30, 2010 | Chaintech CT-7AJA Motherboard
Jan 31, 2010 | Foxconn 661FX7MI-RS (661FX7MIS)...
Oct 29, 2009 | Chaintech 7NJL4 AMD Motherboard
Jun 13, 2009 | Chaintech Slot 1 CT-6ATA2 Motherboard
Apr 03, 2009 | Chaintech AMD (7VIF4) Motherboard
Jan 27, 2009 | Chaintech Slot 1 CT-6ATA2 Motherboard
Apr 11, 2008 | Chaintech CT-9BJA Motherboard
Apr 29, 2007 | Chaintech Slot 1 CT-6BTM Motherboard
482 people viewed this question
