Question about Arris SURFboard SB4100 Modem
SB4100 stopped working suddenly
Had the modem connected for over a year without any issues and it suddenly stopped working. Modem is connected to wireless router. Ive already reset it, attempted to do a diagnostic on it, but nothing works. Config screen on modem shows 0.0.0.0 for HFC IP ADDRESS. Can't connect from XP machine, Vista or XBox.
  • 3940 Answers
SOURCE: My pc won't connect to the internet
It is the MAC address that needs to be scrubbed from the modem.
power off the desktop, power off the modem, unplug the data cable from the modem, unplug the POWER connection to the modem.
WAIT 3 MINUTES
Connect power to modem, let it reset
Connect data cable to Modem
power on computer
Modem should now connect & work with desktop.
Each time you switch between systems, you may have to do this. More than enough to make me buy a router. =)
Please rate the post. =)
Posted on Jul 15, 2008
  • 31 Answers
SOURCE: Wi-Fi isn't working
This could be a duplex issue. When you log into the belkin does is assign you an IP address? Have you used a ballpoint pen to reset the EMTA since you have connected the router?
Posted on Apr 09, 2009
  • 489 Answers
SOURCE: cant connect to xbox live need an ip address how do i get one
When the SurfBoard modem is powered up and connects to the internet on the WAN interface, it automatically gets an IP address from your ISP. When another machine is powered up and is connected to the modem via a USB cable, it is automatically using the WAN IP address to communicate with the world. If it is connected via the Ethernet connection, the modem automatically issues it its own IP address for use on the internal network via DHCP. The modem's internal Ethernet connection is 192.168.0.1. The next machine powered on will normally get an IP address of 192.168.0.2.
Posted on May 30, 2009
SOURCE: Recently I subscribed ATT DSL Service conflict IP Address
the motorola modem that att is using uses 192.168.1.x subnet. log onto your router and change it to 192.168.b.x where b is any number between 2 and 254 (just not 1). You should also log onto the modem and change the setting that allows it to share the external ip address with the router. You will need to do this if you plan on accessing your network from the internet.
Posted on Jun 13, 2009
SOURCE: i cant get my motorola sb5101 surf board cable
I have a similar problem. The common denominator seems to be the SB5101. I have a brand new Belkin Surf 300N, same issue. The modem will not give DHCP to the router. I can connect fine via ethernet to the modem directly.
This modem seems to be a dinosaur.
Posted on Aug 06, 2010
Can this be used as a 56k router? I need to have a temporary internet connection and it is only a basic connection because of the type of phone there is at the house. We tried to connect but I don't have...
The SB4100 is a digital modem that uses cable TV network to provide broadband Internet access, it can't work with an analog telephone line, for this type of Internet access (also called switched Internet connection), you need an analog internal or external 56K modem, and also you'll need a user name and password (an account) from the Internet provider service (ISP) ; for a temporary Internet connection maybe a prepaid cellular modem (GPRS, EDGE, 3G or 4G) USB type could help you better.
Feb 27, 2011 | Arris SURFboard SB4100 Modem
I have a sb4100 cable modem and the "online" LED keeps blinking and it resets itself and will never go online
The modem that you have is getting old and may be going bad but here are a couple of thing to help you out.
Often times this is premises related signal strength issue.
Items that you can check.
1. Is the coax line tight in the back of the modem and at the wall.
2. Are there any splitters where the cable comes out of the wall before it attaches to your modem. If so remove them and attach the cable directly to the wall from the back of the modem and power cycle the modem.
3. Do you have a coax cable line that goes directly from the outlet the modem is attached to the point that the cable service enters the household. Each time that you split your coax line it takes away part of the signal and the more times you split the more likely you are to not get a connection to the internet
If all of these items are in place and you still are having problems call your service provider and schedule a service call or try a new modem. Good luck.
Oct 31, 2009 | Arris SURFboard SB4100 Modem
When my isp lease time expires, I lose my internet connection for about 1/2 hour. Service will reconnect on its own after that time. It seems as though my ip address will not automatically renew. Is the...
Hi, The issue seems to be with the modem. It should reconnect you even if the lease expires and is renewed. you may try upgrading the firmware for the modem. You may also reset the modem and reconfigure it.
Rate it, if it helps.
Aug 24, 2009 | Arris SURFboard SB4100 Modem
I nwws to connect my surfboard moden SB4100 tom y
If you are using an ethernet connection then you should not need an installation disk. If you are connecting through USB then you can download the drivers from motorola's website.
Mar 30, 2009 | Arris SURFboard SB4100 Modem
Tryjng to unlock a Motorola Modem SB4100
hi just power light on sb4100 is there any help out there
Feb 28, 2009 | Arris SURFboard SB4100 Modem
Losing connection
I assume this is a cable modem? You need to call your cable company and have a trouble ticket created. I worked for the cable company installing cable for quite a while and I bet my paycheck the signal getting to the modem are below specs and that's why the modem gets dropping the internet connection.
Hope this helps.
Aug 13, 2008 | Arris SURFboard SB4100 Modem
Arris SURFboard SB4100 Modem Logo
116 people viewed this question
Top Arris Computers & Internet Experts
Greg Ulan
Robbie Goodwin
RS Technology...
RS Technology...
Are you an Arris Computer and Internet Expert? Answer questions, earn points and help others
