Question about Motorola Mobility RAZR V3
The directional buttons i.e. the buttons in the circle around the select button do not work and after a few bashes theyt have to be pressed RLY hard then they stop working again, i have to use the volume buttons inorder to scroll. -.- is there anyway to fix it without returning it?
    Sergeant:
    Champion:
  • 241 Answers
Your "d-pad" is most likely ripped underneath, and needs to be replaced - if you are lucky you just need the keypad portion - cost is about $20, if you are unlucky then you need a new keypad flex - about $45 - but i doubt that as the other buttons work fine.
http://horizonwirelessonline.com
Posted on Jan 20, 2008
How do I find the sleep timer on a ue32m5620
If you have the "Voice Command" feature activated, just say "sleep reservation in x minutes" (where x is 30 minutes for example). Otherwise, press the Home button and go to the Settings icon (the gear symbol at the left on the bottom of the screen) Then press Select (the center button inside the direction button circle). From here, go to General > System Manager > Time > Sleep Timer. Use the direction buttons and press Select for each sub-menu/item. You can set the maximum time to turn off the TV of 180 minutes.
I found this on page 79 (page 85 of the PDF below) of the E-manual available here: http://www.samsung.com/nl/support/model/UE32M5620AWXXN/ . The direct link to the manual (in English) is currently http://downloadcenter.samsung.com/content/UM/201703/20170320103749845/ENG-KTSDVBEUL-1.0.1-170306.1.pdf .
I hope this helps.
Dec 09, 2017 | Televison & Video
Where is the reset button on mytablet2 from argos
  • Make sure the tablet is charged up to 60%
  • Turn off the tablet completely .
  • Press Volume + button , while holding Volume + button , plug in charger.
  • Release the volume + button.
  • Press Volume + again and press Power button to boot the CnM Tablet.
  • When Android logo appear , release the volume + button.
  • Press Power Button again and press volume + button , Recovery Menu will be appear .
  • Press the volume down and select "wipe data/factory reset"
  • Power button to select it
  • You will see "Yes - delete all user data"
  • Select "Yes"press "Power" button to select it
  • Formating will start. it will delete all user data .
  • Few seconds later, you should see the recovery menu again. Select reboot.
  • It will take approximately 2 to 3 minutes to take you back to its factory (out-of-the-box) state .
you are done.
This Hard Reset method will work with all models of CnM touchpad tablets.
Dec 15, 2014 | Televison & Video
WHERE CAN I DOWNLOAD A COPY OF THE NASCAR 07 INSTUCTION MANUAL?
I couldn't find a downloadable copy but got a hand written one:
NASCAR 07
RACING CONTROLS
Directional Buttons Steering
X Button Share Draft
Triangle Button Reverse
Square Button Intimidator
Circle Button Change View
L2 Button Brake
L1 Button Shift Down
R2 Button Accelerate
R1 Button Shift Up
Start Button Pause
Select Button Toggle Mirror
Left analog stick (L3 Button when pressed down) Steering
Right analog stick (R3 Button when pressed down) Team Communicator
Jul 08, 2011 | Electronic Arts Nascar® 07 for PlayStation...
How do i connect wifi from my samsung mobile
Follow the steps :
Press the "Start" key on the front of the phone, located to the left of the "OK" button, and press down the circle around the "OK" button to scroll to "Settings." Press "OK" to select "Settings," and select "More."
Highlight "Connections" on the screen and press the "OK" button. Select "More" and highlight "Wi-Fi." Press the "OK" button to enter the Wi-Fi settings.
Press the "Menu" key, located on the right side of the "OK" button, and highlight and press "OK" over "Turn on Wi-Fi."
Select "Yes" to view the Network List, and press the "OK" button over the highlighted network you wish to connect to. Select "Connect" and the network type, and select "Next" to proceed.
5
Type in the network password, and press the "Next" key on your phone. Press "Finish" to complete the network setup. A Wi-Fi icon will appear at the top of your screen when you are connected to a wireless networ
Oct 26, 2010 | Computers & Internet
I bought a Sims 2 pet CD for PS2 and I need a manual to play.
The Sims 2: Pets
GAMEPLAY CONTROLS
Directional Buttons Up = Motives. Down = Wants and Aspirations. Left = Quick Text. Wants of Nearest Pet. Right = Relationships.
X Button Select. Action.
Triangle Button Cancel. Close Menu.
Square Button Pan Camera (Hold)
Circle Button Snap Camera to Sim
L2 Button Sim Switcher Menu (Hold)
L1 Button Freeze. Fast-Forward.
R2 Button Toggle Walls On/Off
R1 Button Freeze. Fast-Forward.
Start Button Pause
Select Button Toggle Control Mode
Left analog stick (L3 Button when pressed down) Move
Right analog stick (R3 Button when pressed down) Zoom. Rotate Camera.
PLACEMENT MODE/GRAB MODE CONTROLS
X Button Place or Grab Object
Triangle Button Cancel. Back.
Square Button Remove Object and Put In Inventory
Circle Button Toggle Blueprint Mode
L2 Button Clone
L1 Button Rotate
R2 Button Undo/Redo
R1 Button Rotate
BUILD/REMOVE MODE CONTROLS
X Button Place/Remove Wall, Wallpaper, or Floor
L2 Button Clone Wallpaper or Floor
R2 Button Undo/Redo
Combo #1 L1 Button or R1 Button + X = Build or Fill Room
Combo #2 L1 Button or R1 Button + X = Remove or Uncover Room (In Remove Mode)
acquired from (Gamefly.com)
Jul 06, 2009 | EA - Electronic Arts The Sims 2 Pets for...
Blue circle around bottom menu buttons when pushed
haha, that is normal :) that happens when you press anything to show you what you have pressed :) and im sorry no, its how the phone was made.
Jun 28, 2009 | LG Vu CU920 Cellular Phone
Timex 1440 sports WR50M
Solution #2 by Guest, posted on May 13, 2008 solved my problem. OUTSTANDING solution #2!
1. Hold in the MODE button until the alarm time appears.
2. VERY IMPORTANT - release and TAP the MODE button AGAIN, and the time should appear with the seconds flashing.
3. Use StART/Stop to choose among seconds, hours, and minutes, and
4. Use ADJUST to increase the selected number
5. Press MODE to put the thing back in regular operational mode.
After several attempts with other directions over the last four months, these 5 steps WORKED.
Mar 30, 2008 | Timex 1440 Nylon watch
Operate an ipod
To get it unlocked: Find a black (or silver) oval switch on it. Move the switch to the left and orange will appear. Your ipod will be unlocked.
To scroll through things: Move your finger around the black circle.
To select something: Press the center black button.
To shut your ipod off: Hold down the pause button (button on bottom of scroll circle) for three seconds. Then switch the hold button to the right to lock it.
To pause something: Press the pause button (button on the bottom of the scroll circle).
I hope my solution was helpful. Please rate it.
Jan 17, 2008 | Apple iPod nano
Setting the camera timer
by the way in setting the timer for your camera here is what you are going to do...
-turn the camera on
-set the camera in recording
-press the Right Button beside the menu button (the incomplete circle)
-and then you will see that there will an icon showing in the left side part of the screen of the camera.
Selecting the self-timer
1. Rotate the MODE DIAL to select a RECORDING mode with the exception of VOICE RECORDING mode.
2. Press the SELF-TIMER button until the desired mode indicator displays on the LCD monitor.
A 10 second, 2 second or double self-timer icon appears on the LCD monitor. In Movie Clip mode, only the 10-second self-timer will work.
•2SEC self-timer (icon of incomplete circle with 2S)
: Pressing the shutter button will allow an interval of 2 seconds before the image is
taken.
•10SEC self-timer (incomplete circle)
: Pressing the shutter button will allow an interval of 10 seconds before the image is taken.
•Double self-timer (double incomplete circle)
: A picture will be taken after about 10 seconds and 2 seconds later a second picture will be taken. When using the flash, the 2-second self-timer may be delayed for longer than 2 seconds depending on the flash charge time.
3. When you press the SHUTTER button, the picture will be taken after the
specified time has elapsed.
Nov 26, 2007 | Samsung Digimax S730 Digital Camera
Motorola Mobility RAZR V3 Logo
49 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
