Question about Konica Minolta DiMAGE Z6 Digital Camera
Focus won't hold: initialy focuses on target then fluctuates
My kodak m1033 camera won't focus, it tries to, and I can hear like gears moving while it tries to focus, but nothing- still blurry
You don't say anything about light conditions, target color, definition, contrast, and the many other things that can cause this.
Is your camera at fault? Maybe.
Take a look in these sites and many others like.
Your camera won't focus?
Digital camera focus tips
Jun 28, 2011 | Kodak EasyShare M1033 - black Digital...
All of a sudden every picture I take with the 55-200 zoom lens is blurry and slightly out of focus. Pictures with the 18-55 lens are still sharp. I have been using that 55-200 lens for years for sports...
Simplest answer is that you may have accidentally flipped the focus switch (A/M) on the lens to M. This turns off autofocus for that lens (which you might need to do if autofocus just can't resolve the image). Try turning it back to A.
Another possibility is that you're using an autofocus target different from the one you're expecting. The problem would be apparent regardless of lens choice, by being in focus in a different part of the image. You can press the arrow keys (while holding shutter release down halfway) to change AF targets, or change a menu setting to simply choose the closest target.
The shooting modes have no effect on focusing ability.
The camera would likely detect other focus-related problems (like servo failure).
May 09, 2011 | Nikon D40x Digital Camera
My Panasonic PV-GS150 is having an autofocus problem. It will be focused on a target and then will go out of focus and then come back in to focus. It does this repeatably. It used to stay focused on the...
The solution is never buy a Panasonic DV camera. Tons of users complain of focus failure and Panasonic pretends the problem does not exist. Great cameras otherwise but out of focus does not cut it.
PV GS250 $1000 brick
Dec 08, 2009 | Panasonic Video Cameras
Bushnell Elite 1500 Rangefinder has lost focus
There is a ring below the eyepiece that is the focus......
Dont drop it and keep away from vibration. This will keep it in alignment. You will notice that if its been dropped it won't lock in on targets greater than 150 yards. A lot of players put the rangefinder in the compartment in the golf cart and the unit bounces around a lot. This practice just DECREASES the effective range. Alignment will be needed ($$)
mtg
May 17, 2009 | Bushnell Elite 20-5100 Rangefinder
Focus on a particular subject
Try the FOCUS LOCK feature. This feature allows you to focus on a subject roughly the same distance away from you, then re-compose your picture without losing that focus. Open the lens barrier fully. Look through the viewfinder at the AF Target Mark (the 4 lines in the center of the viewfinder). Position the AF Target Mark on a subject roughly the same distance away from you. Press the shutter button halfway until the green lamp lights. While keeping the shutter button pressed halfway, re-compose your picture, then press the shutter fully.
Sep 01, 2005 | Olympus ? Stylus 500 Digital Camera
Cannot focus on a particular subject
If the camera is having a difficult time auto-focusing, you can try the FOCUS LOCK feature. This feature allows you to focus on another subject roughly the same distance from you and then move the camera back to the intended subject and take the picture without losing focus. First, turn the camera on and locate the Autofocus Target Mark in the center of the LCD. The AF Target Mark resembles an open and close bracket [ ]. Position this AF Target Mark on a subject roughly the same distance away as the subject the camera is having trouble focusing on. Press the shutter button halfway enabling the lens to focus. While holding the shutter button halfway down, aim the camera at the original subject and press the shutter button all the way down.
Sep 01, 2005 | Olympus D-630 Zoom Digital Camera
Try the FOCUS LOCK feature. This feature allows you to focus on a subject roughly the same distance away from you, then re-compose your picture without losing that focus. Open the lens barrier fully. Look through the viewfinder at the AF Target Mark (the 4 lines in the center of the viewfinder). Position the AF Target Mark on a subject roughly the same distance away from you. Press the shutter button halfway until the green lamplights. While keeping the shutter button pressed halfway, re-compose your picture, then press the shutter fully.
Sep 01, 2005 | Olympus D-575 Zoom Digital Camera
Focus on a particular subject?
If the camera is having trouble doing an auto focus you can try the FOCUS LOCK feature. This feature allows you to focus on another subject roughly the same distance away from you, and then move the camera back to your original subject and take your picture without losing that focus. First turn the camera on and locate the AutoFocus Target Mark in the center of the LCD. The AF Target Mark resembles an open and close bracket [ ]. Position this AF Target Mark on a subject roughly the same distance away from you as the subject that the camera is having trouble focusing on. Press the shutter button halfway enabling the lens to focus. While keeping the shutter button pressed halfway, move the camera back to include the subject you originally wanted in the image, then press the shutter fully. (Please see page 42 in the D-535 Zoom Reference Manual in Section 3, under the heading titled “If Correct Focus Cannot Be Obtained”, for a more detailed explanation.)
Aug 31, 2005 | Olympus D-535 Zoom / C370 Zoom Digital...
Focus
If the camera is having a difficult time auto-focusing you can try the FOCUS LOCK feature. This feature allows you to focus on another subject roughly the same distance from you and then move the camera back to the intended subject and take the picture without losing focus. First, turn the camera on and locate the Autofocus Target Mark in the center of the LCD. The AF Target Mark resembles an open and close bracket [ ]. Position this AF Target Mark on a subject roughly the same distance away as the subject the camera is having trouble focusing on. Press the shutter button halfway enabling the lens to focus. While holding the shutter button halfway down, aim the camera at the original subject and press the shutter button all the way down.
Aug 31, 2005 | Olympus Camedia D-435 Digital Camera
If the camera is having trouble doing an auto focus you can try the FOCUS LOCK feature. This feature allows you to focus on another subject roughly the same distance away from you, and then move the camera back to your original subject and take your picture without losing that focus. First turn the camera on and locate the AutoFocus Target Mark in the center of the LCD. The AF Target Mark resembles an open and close bracket [ ]. Position this AF Target Mark on a subject roughly the same distance away from you as the subject that the camera is having trouble focusing on. Press the shutter button halfway enabling the lens to focus. While keeping the shutter button pressed halfway, move the camera back to include the subject you originally wanted in the image, then press the shutter fully. (Please see page 20 in the D-425 Advanced Manual in Section 2, under the heading titled “If Correct Focus Cannot Be Obtained”, for a more detailed explanation. This Advanced Manual is provided on a separate CD, in Adobe PDF format.)
Aug 31, 2005 | Olympus Camedia D-425 / C-170 Digital...
Konica Minolta DiMAGE Z6 Digital Camera Logo
18 people viewed this question
Top Konica Minolta Cameras Experts
Steven Wander
Steven Wander
Computer Links
comment
comment
Are you a Konica Minolta Camera Expert? Answer questions, earn points and help others
