Question about Sewing Machines
Inserting bobbin haveing problem threading bobbin the book is not helping it is very confusing and not explain it well in manual help thanks
  • 6 more comments
  • gecko454 Jan 20, 2008
    model 464xc
    model 464xc
  • gecko454 Jan 21, 2008
    bobbin drops in the top
    can you please a photo
  • Anonymous Mar 29, 2008
    I have no idea how to insert the bobbin, to set it up for sewing. The manuel is pretty blank and doesn't give you any instruction .... from what I can see I am doing it all correctly but I still can't get it to work properly.
  • Anonymous Sep 16, 2008
    I can't even find the slot to put the thread through for the bobbin
  • Anonymous Sep 28, 2008
    What do I do after puttng thread to the back? The needle does not catch it in this position. It appears that something else must happen first.
  • dme1961 Oct 03, 2008
    I have a Riccar model 315FA and am confused on how to thread the bobbin. I know its an old machine. Also where can I find a manual for future problem solving.
    send info to [email protected]
Bobbin in your left hand with the thread leading off from the top, pop the bobbin in, put the thread in the slot on the bobbin case and pull to the back,
Posted on Jan 21, 2008
6ya staff
SOURCE:
Hand wheel doesn't turning, the bobbin case is blocked
You have what is called a thread lock. Turning hand wheel backwards and may release it if not remove bobbin case from shuttle, release shuttle arms, pull off race cover and remove thread then re assemble, problem should be solved. You may refer to you instruction book as it will explain the procedure.
Nov 30, 2013 | Singer Sewing Machines
Bobbin thread keeps breaking
Bobbin thread breaks
1. There is a right way & wrong way to insert the bobbin in the case --when you insert the bobbin in if it doesn't stitch correctly turn the bobbin over see if that helps or bobbin case is not inserted correctly
2. Lint has collected in the bobbin holder
3. The bobbin is damaged & doesn't turn smoothly
4. Lower thread tension is two tight
if you don't have a manual, here is a link for a free manual
http://www.singerco.com/uploads/download/1295_3270.pdf
Dec 21, 2012 | Singer 3343 Mechanical Sewing Machine
I have a faithful 730 Bernina and currently the bobbin thread keeps breaking. Please advise what may be causing this. Thanking you.
here's a free manual
http://www.bernina.com/getdoc/48e8d09f-98f7-40ab-8663-a23663df4fae/Bernette_715_730_740E_manual
Sep 17, 2012 | Bernina Sewing Machines
My mom has the 8050 and the bottom thread when she sews is knotting. She did the trouble shooting from the book and no change. She has only had the machine for four months. Wondering if you have any...
have you try using a different bobbin & thread. make sure the bobbin wound & is inserted correctly
check to make sure the top thread has not come off the thread take up lever
has a new needle been put in?
make sure there are no burrs on the needle plate or bobbin itself or bobbin case
let me know if any of these suggestions help machine work correctly or not
Aug 26, 2011 | Janome Sewing Machines
My bobbin tension thread is bunching up and not sewing right, top stitch is fine? I've moved the tension control number each way and this does not help at all. I've tried different bobbins also? Help!! ...
Recheck your bobbin and make sure it's in the bobbin case correctly.There may be arrow diagram on face plate or bobbin case. You can also check owner's manual to make sure bobbin is inserted the right way. If it isn't, the bobbin thread can "whiplash" causing the bunching you've describe. If you have smooth stitches on top, your top threading is all right. I hope this helps. If it does, please let Fixya know by rating my solution.
Nov 30, 2010 | Singer Stitch Sew Quick Sewing Machine
I have lost the manual and i dont remember how to thread a bobbin. Pleas help me and thank you!
Juki TL-98Q
Loading the bobbin into the bobbin case:
Snap in the bobbin case latch, and put the bobbin into the bobbin case so that the bobbin runs clockwise.
Passing the thread through the **** of the bobbin case, continue passing it under the thread tension spring, and pull out the thread open end about 10 cm from the bobbin case.
Insert the bobbin case fully into the hook, and close the bobbin case latch.
You can obtain a copy of the manual in pdf format for free at:
http://www.juki.co.jp/household_en/pism/img/tl98q/download/98qim.pdf
Jul 29, 2010 | Juki TL-98Q
Threading my machine
Don't have this machine, but I have web site for help.<merrilywequiltalong.com>
May 31, 2010 | Janome HF-107
Threading up a bobbin in a singer 560 sewing machine
I'm guessing it's probably the same as mine (8280). This is what the manual says: "Hold the bobbin case with one hand, insert the bobbin so that the thread runs in a clockwise direction. Pull the thread through the **** and under the finger. Hold the bobbin case by the hinged latch and insert into the shuttle." It's hard to describe, but if you've sewn before, it should come back quickly. To be more specific, hold the bobbin case in your left hand, insert the bobbin so the thread is coming up from underneath, pull thread through the **** and into the part where the hole is. If you slide the thread around, it will fit into the slot in there. Pull the latch out and insert it into the shuttle.
Hope this helps.
Mar 27, 2010 | Singer Sewing Machines
I have a Bernina 530 Record and i'm trying to but
You would be best to download an instruction manual for your machine as it explains clearly, with diagrams how to thread and insert the bobbin. You probably wont find the 530 manual however download a copy for Bernina 530-2 or 532-2 as they are almost identical to the 530.
Sep 25, 2009 | Bernina Sewing Machines
Kenmore by sears model 1581457180 need a manual or a how to thread the bobbin
hi there,
on my manual 1581 kenmore show figure on how you thread your bobbins and upper thread.
to thread bobbin insert the thread on one hole of winder holding thread and rotate thread on counter clockwise rotation several times, loop the thread on tension thread and insert bobbins winder on winder shaftat top of your sewing machine push the latch to lock bobbin winder
pull the handwheel to disengage the clutch and to move the winder free rotation.
press the foot pedal to run your winder and thread your bobbins be sure on counterclock wise rotation.
if winder is full of thread this will automatically disengage the shafting winder from clutch.
4843169.jpginsert winder as in fig. check the thread direction
5d74924.jpg 153629c.jpg on figure hold and insert bobbins on shuttle race assymble.
on figure show upper threading.
3cba620.jpg follow the red thread on figure.
you can also check your manual on internet
search box type www.kenmore 1581
have a nice day,rate my fix,thank's a lot
Jun 12, 2009 | Sewing Machines
Sewing Machines Logo
263 people viewed this question
Top Sewing Machines Experts
Chris Wetmore
Marvin
Marvin
Are you a Sewing Machine Expert? Answer questions, earn points and help others
