Question about Whirlpool LSB6200KQ Top Load Washer
My whirlpool top load New Model direct drive washer just recently started banging violently against the sides when spinning. The whole washer wobbles when spinning and it wasn't doing that before. I checked the coupler and Springs and they look good. Please suggest what must be broken to cause the banging?
    Scholar:
  • 68 Answers
Have you tried resetting the self leveling legs in the rear? you do so by tilting the machine forward, as you do you should a springy metallic sound, then let the machine back down and see if that helps. this should be done anytime the machine gets move to ensure a strong foot hold to the floor
Posted on Dec 10, 2009
The tub continues to go off balance in spin cycle. Starts out smooth then starts to wobble terribly til the UL shows and shuts down. Support rods are good
There is a little device inside the washer that allows the agitator to spin independent of the drum. If this gets stuck, the washer will try to spin the whole drum instead of just the agitator. This will cause the washer to think the load is too large or out of balance, causing the error code. On some Whirlpools this device is just a washer.
Jan 07, 2015 | Whirlpool WTW8800YC 4.6 cu. ft. Cabrio...
Drum is loose during Spin and Rinse cycle and banging against side of washer
If it is under warranty, call Whirlpool at 1-866-698-2538. If it is out of warranty, try running the washer with no clothes in it in spin cycle. If it runs fine empty, it may be that when you had clothes in it they were not balanced evenly in the tub. If it runs off balance when empty, then a spring may have broken or come off. Contact an appliance repairman.
Oct 31, 2013 | Whirlpool WTW4880AW 3.4 cu. ft. Top Load...
Whirlpool washer model wslp1100d after the rinse
Hi Derek.
There are several different problems that may result in basket wobbling and machine shaking heavily during the spin cycle. Sometimes the shaking can result in spin cycle not ending, like in your case.
To find out what the problem is the washer must be taken apart and the tub removed.
A common situation is given by a defective drive hub.
At the end of this comment there is a movie showing how to reach and replace the drive hub in whirlpool top load washers. In this washer you will find a more complicate device instead of the hub shown in the movie. There is a pulsator, the balancer and other parts that must be inspected. The two assemblies are indicated respectively as part 52 and 56 in diagram nr.1 below. Here the part list: http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5239648&diagram_id=26470626#d26470626
If you find a foreign object such as a cloth below the tub, then that can be cause for the shaking and wobbling.
If the parts below the tub are OK, then one of the suspensions may be broken. Suspension (damper) is indicated as part 36 in diagram 2. Here parts: http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5239648&diagram_id=26470625#d26470625
Here diagrams:
Diagram 1
Diagram 2
Here the video:
utube.png You-Tube video "aj-HSUOuBBA" placeholder (do not delete) utube.png
Regards.
Ginko
Nov 20, 2011 | Washing Machines
Spin vefy fast
A rapid spin cycle is actually a GOOD thing. This is an indication that the gearcase (transmission) and the drive motor are both running strong.
If the washer shudders during the spin cycle the first thing you need to do is check to ensure the washer is properly leveled. The following link explains:
http://www.fixya.com/support/r3868923-level_whirlpool_top_loading_washer
The model Whirlpool top loader you have, has an auto-leveler mechanism on the back two legs that can become unlevel periodicailly. You should check the washer level from time to time when it is empty. You need to also make sure the washer is level in ALL directions (front-to-back and side-to-side).
Accidental unbalance problems that can occur from washing blankets, comforters, or heavy loads of towels can also cause the washer to become unlevel and shake. This can also contribute to the level mechanism becoming unbalanced.
Overloading the washer can also cause unbalance problems. Washing blankets or conforters can cause the load weight to shift to one side of the tub. This will result in a tub that shakes violently and bangs against the cabinet. You may have to redistribute the load weight when washing heavy items. This can also occur when washing loads of towels. This is NORMAL as some heavy items do not distribute the weight evenly.
Another problem (which is less common) that can contribute to wash unbalance problems is a weak floor under the washer. If the floor flexes (even the slightest) during the spin cycle, it can cause the washer to bounce or shake. Mobile homes or laundry rooms on the second floor of a home are notorious for having weaker floor structures. This washer has a 35 gallon tub capacity. Coupled with the weight of a wet load and the spinning action, this can put a lot of centrifugal force on a floor.
If you have any questions or concerns, please post back and let me know. I hope this information is helpful to you.
Apr 25, 2010 | Whirlpool LSR5132PQ Top Load Washer
Washer won't agitate. New transmission...new timer.
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (###.######) and you'll see a list of major sub-components with diagrams and parts.
Top load, direct drive Whirlpool / Kenmore washers use a reversing motor.
It turns one way for agitating and reverses for draining and spinning.
It sounds as if either the motor is shot or one of the connectors is bad.
As a place to start, see the Whirlpool Service manuasl (with wiring diagrams) for their top load, direct drive washers.
WHIRLPOOL INST AND MAINTENANCE INCLUDING HOW TRANSMISSION WORKS
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
WHIRLPOOL TRANSMISSION DESCRIPTION AND SPRINGS
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/2550f737b3129b0c85256b0600504738/$FILE/787772%20%234.pdf
Feb 13, 2010 | Kenmore 24832 Top Load Washer
Washer shakes as if unbalanced during spin cycle I think that part of the suspension has failed, the result is the washer shakes violently during the spin cycle but otherwise seems to perform reasonably...
Whirlpool / Kenmore top load, direct drive washers use a number of springs between the main suspension plate and base assembly as well as friction pads that are designed to minimize shaking.
See the Whirlpool / Kenmore service manual for top load washers.
It's likely that one of the springs or pads has broken or come off.
See the following for how to remove the cabinet to get at these.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=137
Oct 24, 2009 | Washing Machines
Top loader series 80 Kenmore doesn't stop after the whole wash cycle, it goes directly to 2nd rinse, then spins again and stops?
Since it does everything else, the problem points to the timer.
See the following Whirlpool / Kenmore installation and service manual for top load, direct drive washers with an extensive troubleshooting section.
Oct 14, 2009 | Kenmore 24032\24036 Top Load Washer
Maytag Performa Washer spins out of balance
There was a recall on the washer base, which caused the unbalanced problem. Find Technical Buletin TDL-0050B-B issued by Matag.
Jul 05, 2009 | Maytag Performa PAV2200
Whirl pool washer bangs when in spin cycle
if new did you remove shipping strap in back..the unit cant lean more than 2 degrees..make sure clothes are even in tub..try to wash clothes alike..
Dec 25, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Washing Machine Suspension Problem?
smirkin, the question here is if the basket is listing against the tub or the whole tub and basket is listing. If the basket is listing and banging around it could be the drive block has worn or broken. I will attach a photo of one. If the whole tub is listing it could be a spring that broke. You can remove the front panel of the washer by pressing in on the two clips on each side of the washer top, The front panel should drop and pull out. You can see if any of the suspension sprins broke. The drive block is located under the basket. The agitator and basket have to be removed to change it out. Take a look at the attachments...Catriver..post back
Sep 07, 2006 | Whirlpool LTE6234D Top Load Stacked...
Whirlpool LSB6200KQ Top Load Washer Logo
134 people viewed this question
Dan Webster
Dan Webster
Sal De
