Question about Frigidaire GLTR1670A Front Load Washer
My CRTR9300ASO Frigidaire Front Load Washer makes a loud thumping noise and moves slow spinning. Any ideas what might be wrong?
    Scholar:
  • 68 Answers
If you lucky, you have a broke shock absorber on the bottom. if your luck is not so good......well we will find out.
open the door on your washer. locate the big silver basket in the middle. put your hand in side and push up. now this will move but we are looking for it to feel very loose, not springy. if your luck is bad you will hear and feel it freely clunck around as if the inner basket is coming loose. if this is the case then you will be looking at a very expensive repair. like $350 and up
levi
Lebarchrigen Appliance Repair
www.lartoday.com
Posted on Dec 10, 2009
Frigidaire CRTR9300ASO won't spin replaced door latch switch and still does not work
Hi bitemejohne - Often when a unit does not spin, it is because the unit cannot properly drain and dispose of the water and detergent solution. Does the unit make a humming noise? If so, the drainage hose/pump may be clogged and needs to be cleaned. Since you have already replaced the door lock assembly then the washer may be experiencing other issues. It could possibly have a faulty pump, timer or control board not communicating correctly. Because it could be a number of any one of several underlying causes, I would recommend contacting a professional to properly diagnose and repair the unit.
Mar 09, 2013 | Frigidaire GLTF2940ES Front Load Washer
How to Troubleshoot a Frigidaire Front Load Washer That Doesn't Spin Read more: How to Troubleshoot a Frigidaire Front Load Washer That Doesn't Spin | eHow.com http://www.ehow.com/how_6496482
Hello - Does the unit make a humming noise? If so, either the drainage hose/pump is clogged and needs to be cleaned, or you have another issue with the door lock assembly or the timer and control board not communicating correctly. Contact a professional to move forward accurately.
Oct 21, 2012 | Frigidaire Affinity ATF7000E Front Load...
My washer mad three loud thumps and then would not spin at all. It will pump the water out but will not spin. Do you think it is the belt. Thanks helyn
The belt might have slipped off the pulley. But when you mention that you heard loud thumps before it stopped spinning is a sign that something else might have gone wrong with your machine. With the washer turned off, turn the wash drum by hand and listen for any noises. It should turn quietly without any kind of thumping noises. Also look how the drum turns. It should turn smoothly and not wobble as it turns. If it wobbles or makes thumpiing noises, it means that the support arms are broken.
Reparing the support arms is an expensive repair, unless it is still under warranty, it not worth fixing. Get a few estimates before deciding to repair or replace it.
Feb 08, 2011 | Frigidaire ATF6000ES Front Load Washer
Very noisy and loud vibrations on spin cycle of Frigidaire FTF2140FS front load washing machine
Is it just during the spin cycle that it machine is noisy or the noise is less during the wash cycle? Also is the noise a thumping type of noise or is it more of a whining or steady noise? If is a whining noise, it probally means that water has seeped past the seal and corroded the bearing of the washer. The noise is the failing bearing.
Jun 30, 2010 | Frigidaire GLTF2940ES Front Load Washer
Loud thumping noise during spin.......not related to unbalance....manually turning the tub makes a loud noise.
Bearings shot or counter weights have come loose
Take the top off and check the weights first
Jan 12, 2010 | Frigidaire GLTF2940ES Front Load Washer
My model #gltr1670aso makes loud noises during spin cycle
Usually this is due to either the drum support breaking or the back bearing being bad-neither easy to fix- or worth it. Try lifting the drum up and down, if it moves up and down they are bad. I see this a lot, and the price of repair isn't worth it. Craig
Aug 02, 2009 | Frigidaire ATF6000ES Front Load Washer
Frigidaire was tub makes loud thump noise during spin cycle....
Need more information to make an accurate diagnosis, try removing the front panel (two screws at bottom) and visually check first the belt (all the way around) and then the springs that hold the tub suspended.
I would bet on the belt.
Quentin
Jul 22, 2009 | Frigidaire FEX831CS Top Load Stacked...
Looks like the drum has droped
You will need to get the bearings replaced. Most noises from a washing machine occur during the spin cycle. If you hear loud thumping during the spin, the load of clothes may have become unbalanced. Stop the washer and redistribute the clothes, then re-start it. Repeat these steps if necessary.
Sep 18, 2008 | Frigidaire ATF6000ES Front Load Washer
Frigidaire front load washer will not spin
i was told when it won't spin, then the drain is plugged.  i opened mine up and found a sock stuck in the drain hose.  removed it and seems to be working well.
Sep 05, 2008 | Frigidaire ATF6000ES Front Load Washer
Drum makes loud noise when spinning
HI thanks for the question. Frigidaire has a life time warranty. on that part .call them. thanks the appliance doc. please rate my answer. thanks.
Apr 29, 2008 | Frigidaire ATF6000ES Front Load Washer
Frigidaire GLTR1670A Front Load Washer Logo
612 people viewed this question
Top Frigidaire Washing Machines Experts
Gerry Harvey
Gerry Harvey
Charles T Nevin
Charles T Nevin
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
