Question about Dell Inspiron 1501 Notebook
My Dell inspiron 1501 went to a blue screen and gives me an error message when reading the Hard Drive upon boot up. I am told the disk is either malfuntioning on logic or may have crashed. How can I find out ! What is my solution
    Sniper:
  • 65 Answers
Fortunately dell has built in diagnostics that can assist you with identifying the problem. here is a link on how to run them. if the drive is bad then you would need to replace it and reinstall windows and drivers. if it is good then run memory diagnostics as well just to be safe. if both pass then you may have to do a destructive reinstall of windows because you most likely have a virus issue. copy and paste this link into your browser it will help you run the diagnostics.
http://www.cs.utexas.edu/~deke/laptopsupport/manuals/d600/diag.htm
hope this helps
Posted on Dec 10, 2009
  • 3,940 Answers
Turn on the system by pressing Fn+the power Button this will initiate the diagnostics.
If you are getting an Unmountable Boot Volume the diagnostics will likely fail and a new hard drive will be the resolution.
    Guru:
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 59 Answers
Troubleshooting With PSA Diagnostics on a Laptop Computer
Journal ID: 09343N9WWT Wizard ID: 345518 Date Published: 8/11/2008 Last Revised: 2/16/2009
STEP: Run the Preboot System Assessment (PSA)
Additional Information
  1. Ensure that the computer is powered off.
  2. Press and hold <Fn> and press the power button to power the computer on.
  3. Release both buttons. The PSA diagnostics sequence begins.
  4. Make note of any PSA beep codes or PSA error codes .
An error code in the form xxxx-x4xx is a code reported from Platform Advanced Integrated Diagnostics (PAID), that uses the PSA diagnostics as its user interface. These error codes and their meanings are explained on support.dell.com
  • 478 Answers
If the hard drive is around "3 years old" then more then likely your having a hard drive failure
SOURCE:
Boot error "Remove disks or other media"
Set the hard drive to boot first, I find this fixes most boot errors.
Jun 07, 2012 | Dell Inspiron N4010 Notebook
Error code OFOO:O75D error:OFOO:O244
Is this from a blue screen error ?
A "STOP" MESSAGE in white letters behind a blue background?
If it's a sata message (hard drive error message), this means that your harddrive is dead or about to die. Most likely its already dead, this error means also that the harddrive cant be read anymore.
Mar 05, 2010 | Dell Inspiron 1501 Notebook
My dell laptop inspiron 1501 not burning or reading cds
Please try with any bootable disk,if the system is not booting with the disk then the issue is with the ODD and it needs to be replaced(be sure that first boot device is cdrom in BIOS).
If booting then go to device manager and uninstall the cd/dvdROM drive and secondary IDE controllers and restart the system twice and check.
If fails then lens went bad and CD ROm drive needs to be replaced.
Dec 09, 2009 | Dell Inspiron 1501 Notebook
Dell Inspiron 1526 laptop won't boot up
The 2000-0147 error is normal as you had no disk in the optical drive to be read during the test. Boot to the Vista DVD and select the repair my computer option (you may have to run the repair process several times depending on the issues with the drive) See if that helps. If no go, then a reinstall of Vista is likely
Oct 03, 2009 | Dell Inspiron 1501 Notebook
Dell 1501 Inspiron w/Vista won't boot up -- virus?
Hi Erika,
have you tried pressing F8 when it starts booting (keep pressing it before dell bios screen fully loads)
you should get a black screen with options,
scroll up to with arrow keys>> "last known good configeration"
let me know if that works?
also have you installed any programs or hardware befor this happened?
Apr 13, 2009 | Dell Inspiron 1501 Notebook
Blue Screen of death.
You might try removing the Hard Drive from the machin and slaving it on your other machine. Then running a chkdsk in the command prompt or norton disk utilities. If either fails, backup your data on other machin and reinstall.
Jan 26, 2009 | Dell Inspiron 1501 Notebook
Laptop blue screens when trying to reinstall vista
The problem might be with the bad sectors on a hard drive. You should run Scan Disk on a partition where you were trying to install Windows Vista.
Jan 16, 2009 | Dell InspironTM 1501 Notebook
"Disc read error" Dell Inspiron 1501
This means your hard drive is bad. You need to replace the hard drive and then the operating system.
Thanks and please take a moment to rate as fixya.
Nov 26, 2008 | Dell Inspiron 1501 Notebook
I hav eDell Inspiron 1501 and upon boot I'm getting "disc read error" So Ipress ctrl+alt+del as screen asks, then itreboots againand again saying same thing. Please advise
Hi there robandviv,
IMHO
Unplug the cable that connects your hard disk drive to the motherboard and plug it again. Make sure that the cable is plugged properly. HTH
Nov 26, 2008 | Computers & Internet
Black screen
It seems your Operating system has corrupted, Its best to use Windows Installation CD to perform Recovery Installation. You can Use the DELL Disk. Before proceed Make sure you have your backup. If you need some advanced access to files you can use UBCD.
Good Luck
Jun 19, 2008 | Dell InspironTM 1501 Notebook
Dell Inspiron 1501 Notebook Logo
492 people viewed this question
Clive
Clive
Alun Cox
