Question about Champion International Champion& Small Engine Spark Plug 8 Pack
Snowblower only runs with the choke in the closed position. as ssoon as i put it in the open position it kills. already cleaned the fuel filter
    President:
  • 986 Answers
Your diafram needs to be replaced, Its easy to do
Posted on Dec 10, 2009
SOURCE:
How to determine the on position for the choke on snowblower
if the choke is pushed in the butterfly should be all the way open. when the choke is pulled then it will close the butterfly to choke it making it run on less air and more gas till it starts.
Dec 11, 2016 | Garden
I just took my new snowblower model # 247.883940 out of the shipping crate today. When I choke the engine to start it will start but when i open the choke at what position should be in engine warm
read your user manual for choke settings
full closed for start then 1/2 closed when started and the full open after a few minutes of running
But read the manual
Oct 16, 2016 | Cars & Trucks
Toro 418ZR runs uneven with choke off
ethanol gas has gummed up your carburetor. take it off and clean it.
Dec 01, 2015 | Toro Power Clear Snowblower 418ZR - 38272
I have a 24" snowblower that surges after 1 minute of running, after 3-4 minutes stops and will not restart until several hours later, does the same thing over and over
This sounds like a choke issue. Do you have a choke on that engine?
The purpose of a choke is to allow for a varying air:fuel ratio depending on how hot the engine is. A cool engine needs a more rich mixture of fuel to air. Once the engine warms up, it runs best with more air. The Choke is a mechanism that allows the operator to manually adjust this mixture. Generally, the choke is closed to start a cold engine, then is opened in 2 or 3 stages as the engine warms up. As the operator, as the engine starts to run smoothly, you would actuate the choke to the next notch, changing the fuel:air ratio so more air is mixed in with the fuel. It's probably best to give the engine a few minutes to warm up while you progress through the choke stages until it's fully open providing the best mixture for operation prior to beginning to clear the snow.
If you follow that process and the engine stalls when the choke is opened, then you need to clean your carburetor.
Oct 18, 2012 | Garden
Motorcycle starts on full choke but will not run even given more fuel even if the choke is turned off after warm up
Hi, Edward and the usual suspects are:
1. Fuel cap or fuel tank is not venting properly.
2. Fuel filter clogged.
3. Fuel line pinched or kinked.
4. Float needle and seat sticking.
5. Float level too low.
6. Carburetor bowl vent line clogged/blocked/pinched.
7. Idle adjusting screw set too low.
8. Air/fuel mixture screw set too lean.
9. Idle port, transfer ports, slow air jet clogged.
10. Slow fuel jet clogged.
11. Faulty fuel pump.
For more information about your issue and valuable "Free" downloads that you will need please Click on the links below. Good luck and have a nice day.
Bike won Run without Choke
Yamaha XV535 runs only on idle choke
Yamaha XV 535 DX Virago Service Manual
OEM parts for Yamaha
http://www.starmotorcycles.com/assets/service/manuals/2005/LIT-11626-18-21_1000.pdf
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
Nov 13, 2011 | 1994 Yamaha XV 535 Virago DX
Our HMSK 80-110 electric start snowblower starts up right away, but the idling is very rough. It runs very smoothly when it is engaged in snow throwing.
The Tecumseh snow motors are notorious for idling rough. Especially the last few years of production. Most service techs just say "live with it" But there are a couple of things you can do to help.
It is not a carb adjustment issue. It's usually a fuel, clean carb issue.
First, use a premium grade fuel without ethanol and a fuel stabilizer. This will give you the best fuel mix.
Second, Remove the carburetor shield and clean the inside and outside of the carb with carb cleaner. Even though you can't see the carb usually, they do get varnish build up and cleaning it will help some.
Third, Put the recommended amount of fuel system cleaner in the gas. I use Sea Foam brand. Over a tank full or two you will notice a difference in how the engine idles.
Fourth, Use a high quality spark plug and use a new one every year. Make sure the gap is correct.
Good Luck! Feel free to as any other questions you may have. Don't forget to rate this answer!
Jan 14, 2011 | Tecumseh Horizontal Tiller Engine 8 Hp, 1"...
My McCullough mac 3200 series chainsaw has sat in the yard for about 3 years now, yesterday, i brought it inside for some TLC to turn it into a go kart engine....... i cleaned the casings, replaced the...
Is the fuel mix less than 1.5 months old?
Are the fuel lines routed like this?
http://www.fixya.com/support/r3706813-2_cycle_fuel_system_repair
Test the ignition system. Inspect the plug; is it wet (99.5 % of 2-cycle start problems are flooded)? If you have not already install a new plug.
Ignition Coil Test by SmallEng.com
http://www.youtube.com/watch?v=L7WNBDRG4C4
You may need to use a jumper wire between the threaded part of the plug and the cooling fins. You do not have to bend up the electrode.
If the plug was not wet and you have spark; remove, clean, and reinstall the muffler and spark arrestor. I will give you that you already cleaned the air filter, remove it turn off the choke, put a teaspoon of fuel into the carburetor throat, and reinstall the air filter.
Use this start procedure - Read Cold 3, read it again. At the first hint it fired OPEN the choke.
Start Procedure
Cold:
  1. Ignition on/off to on
  2. Set compression release – optional step even if saw is equipped with a compression release
  3. Pull (close) choke, set fast idle (done when choke closed on some saws); pull starter and listen for an attempt to start. once heard (usually two pulls; no more than 4)
  4. Set compression release – optional step even if saw is equipped with a compression release
  5. Push (open) choke pull starter until it starts. (usually first pull)
Warm:
  3. Pull (close) choke, set fast idle (done when choke closed on some saws) – Do not pull with choke closed.
  4. Push (open) choke, pull starter until it starts. (usually first pull)
I am going to close this. I am still here and more than willing to help or answer questions. just continue as you have already. I think there is still old fuel in lines and and dark corners of the carb. it will clear once we get it to run for a few minutes. Remember I cannot see what you are doing or have done, brevity helps neither of us. Post back with the results from above, hopefully she runs. Good Luck
Lou
Feb 17, 2010 | McCulloch Garden
Must run almost fully choked
sometinge in fuel lines or filter or carb is pluged try gun out
Jul 25, 2009 | Garden
If my VT110 doesn't have some choke on, it will cut out.
If you mean it dies when you take the choke off,You need to have the jets on the carb cleaned.
May 20, 2009 | 1992 Honda VT 1100 C Shadow
Champion International Champion& Small Engine Spark Plug 8 Pack  Logo
910 people viewed this question
Top Champion International Garden Experts
Dave
ShedThoughts
Marc Stern
Marc Stern
Are you a Champion International Garden Expert? Answer questions, earn points and help others
