Question about Sharp AR-5316 Advanced Digital Imager Copier
Sharp reset developer on ar-122en
Sharp i need step-by-step help
thanks
    President:
  • Sharp Master
  • 1,447 Answers
I do not understand What is step by step help?
Focus me clearly.This machine setup code is: # interrupt C interrupt.
Posted on Dec 10, 2009
SOURCE:
Get a serial key for a sharp print ar 122en
serial numbers of all Sharp Copiers are located on the rear right-hand side of the copier , on a silver sticker
Feb 23, 2015 | Sharp Office Equipment & Supplies
Please help me, how to reset or clear off Sharp Copier/printer AR 5618s Service Maintenance and Developer Indicator.
try pressing *,#,0,#, 24,2,yes or 1 to reset developer light (circle of dots) Then 20, yes or 1 to reset the little man light.
Dec 19, 2014 | Sharp Office Equipment & Supplies
Sharp ar 5516 maintenance reset
sharp ar 5516 showing ( - - - ) what's the solution
Sep 02, 2012 | Sharp AR-5316 Advanced Digital Imager...
How to reset sharp ar 122en
Hi, to reset the problem signs or codes, key in the following in this order and a speed of a second per key press;
  • C Auto C Auto, display must go off or blank.
  • Enter desired code followed by Copy key press. Others have sub-codes and will require you to press Copy key again after that sub-code. For example H2,H3, U2 and H4 needs once Copy key press while developer or maintenance signs require pressing 20 then Copy key then 01 then Copy key.
Hope i have adequately answered you.
Jan 22, 2011 | Sharp AR-5316 Advanced Digital Imager...
SHARP AR 5012 developer reset
i have a sharp sf 1025 , and i want to reset developer conter? can u help me pls
Jun 25, 2009 | Sharp AR-5320 Black and White Copier
Sharp AR-275 Copier
Hello sir; there have no reset key for maintenence, whenevere PM light on you need to do PM service (such as replace drum developer, drum blade etc.)
May 19, 2009 | Sharp AR-275 Copier
Developer sign
The developer doesn't need to be reset on AR series machines. Toner and developer are in one cartridge. There is a drum reset. That is service code 24-07.
Did you replace the drum as well?
Aug 11, 2008 | Sharp AR-5316 Advanced Digital Imager...
Add developer in sharp AR-5316
That model uses a TD cartridge so when you replace the toner the developer is included. The crum chip on the TD cartridge will reset the counters and sets the developer.
Dec 30, 2007 | Sharp AR-5316 Advanced Digital Imager...
Sharp AR-5316 Advanced Digital Imager Copier Logo
762 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
Adorjani Laszlo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
