Question about Symantec WinFax Pro for PC
I have a Digital Solutions digital photo keychain. I connected it to the computer USB port). It is suppposed to pull up the software, but does not. Keychain screen display is "No photo..Please connect to PC...Update Pictures"
  • mlwooldridge Dec 11, 2009
    when i plug in the device (keychain), my computer does not show that the device is connected. The display at first reads "PC Conect", then after about a minute, it sohws "No photo..Please connect to PC...Update Pictures". I can put a flash drive in the same USB port and it connects. I exchanged the keychain and the 2nd one is doing the same thing.
  • mlwooldridge Dec 14, 2009
    Thanks, but too easy. I did that. I also tried connecting, disconnecting the keychain multiple time as well as turning off my computer and the keychain multiple times and starting over. For some reason my Windows XP cannot find the keychain...it never shows up on any drive. Seems like either a keychain software design or software quality problem.
Ok, I had the same problem of when you plug key chain into the computer, the display at first reads "PC Conect", then after about a minute, it sohws "No photo..Please connect to PC...Update Pictures.
Solution: I plugged it in to usb port and when it came up with "PC Connect", I pressed the 'M' button on the side. Then the display changed to read "PC Connecting", and the software came up on the computer monitor. Wha'la! Problem solved
Posted on Dec 12, 2009
  • 1 more comment
  • tumdj Jan 31, 2011
    Thank you so much! That's not what the instructions say to do (in that order). I was getting very frustrated... ready to take it back! : ) Glad I read your post!
  • jenellpina Apr 14, 2011
    OMG YOU JUST SAVED MY LIFE FROM AGGRAVATION!!! THANK YOU SOOOOO MUCH!!!
  • MELVIN987 Aug 09, 2011
    I PUSHED THE M BUTTON & STILL NOTHING ON COMP. SCREEN. ANY OTHER SUGGESTIONS?
If you are having problems getting the Digital Solutions digital photo keychain to connect to your computer, this fix is a simple one. After plugging the keychain into the computer USB port, wait a few seconds. Then insert a toothpick, or something similar, into the tiny hole located on the side just beneath the 3 buttons.
Inside the tiny hole is a reset switch. Use the toothpick to hold the switch down for 5 or 6 seconds, then release.
A few seconds after that the screen should show "Please connect to PC...Update Pictures." Now press the "M" button and the photo keychain should function as advertised.
However, because all computer operating systems are not the same, after pressing the "M" button, some may see a "PC Connecting" message. If so, this means you will have to go into your computer (open "My Computer" and look at the list of drives.) It is easy to locate the DPFMate application and start the photo keychain software manually.
Good luck to all and I hope this information is helpful. Dean Terry
Posted on Mar 17, 2010
  • baba swamy Sep 11, 2011
    Thanx a lot...this is the best suggestion...you saved my dat...thanx again :-)))
  • Carrie Grandy Jan 27, 2019
    I have the same digital camera viewer but I have I tablet...when I plug it in it just says updating...It's Been saying updating for two days ...as soon as I unplug it it dies and won't turn on.....I even hit reset button A LOT ANY SUGGESTIONS
I did what ksmid said to do but it only loaded the drivers. After that when I pressed the "M" it would say "PC connecting" and then nothing.
Solution: What I finally did was to go into windows explorer and found where it was connected (It said: "CD drive E:") I opened that up and found the "DPFMate" application opened that up and problem solved.
Posted on Dec 20, 2009
  • 187 Answers
Look for your device on start, my computer or on the task bar near the clock using the remove hardware wizard.
The "remove hardware safely" icon looks like a card with a green arrow above it. Look for connected devices that may be listed by generic names like removable disk.
If there is nothing on the usb port that looks like your device, uninstall all of the software and start over.
Uninstall the software. Restart after you uninstall. Turn off virus programs. Reinstall using the add new hardware device with Windows hardware wizard. Put the disk in when it asks.
Turn your virus program back on.
From the start bar, open "My Computer."
Double click the keychain; It may be listed under a generic name like removable disk F: then double click the ImageViewer icon.
With the software open, click on Load to view all
images.
If the screen is empty, no photos are stored in memory.
To add a new image into the Click Add Image
The device may also be available to use in control panel, printers and other hardware, and then click cameras and scanners.
Make sure that you put the keychain on a usb on the computer, don't use a router.
Posted on Dec 25, 2009
Its easy here's how: when you plug it in it will say pc connect simply press the (m) button [menu] and it will bring it up
Posted on Dec 30, 2009
Not a solution - more questions - so then with this particular keychaing does that start to charge the batteries then the first time? Mine is right now doing the same thing, so it says to charge for 6-8 hours before first use so do I push the "M" button to connect to my PC to charge it before I start to load pictures? I am tempted to go buy another brand of keychain. This also won't let you drag and drop pictures - have to do 1 at a time!!! Has anyone tried a different brand that is easier to use?
Posted on Dec 16, 2009
    Scholar:
  • 98 Answers
I had the same issue untill i realized that i had to press "m" several times then it beeped and my pc recgonized it.
Posted on Nov 28, 2010
How do i even put pictures on this thing i dont understand
Posted on Aug 18, 2011
Just got mine working. In the instructions that came with it it tells you to get rid of all of your drives except the CD/DVD drive for the keychain to function properly. Sounds mad, right? But its only temporary they are just disabled and can be be renabled after you restart your computer and you only need to do that if they don't restart by themselves when the coputer restarts. Here's how START> right click MY COMPUTER> HARDWARE>DEVICE MANAGER>DISK DRIVES> right click whatever drives are listed>uninstall>FLOPPY DISK DRIVES>disable. You will be asked if you want to restart, click YES. When your computer begins to restart plug in the Digital Solutions keychain the computer will recognize it now, then press the M button on the keychain and the software will come up on your screen. Hope this helps. Good luck.
Posted on Dec 10, 2010
SOURCE:
I change from microsoft to a MAC. Is there any way to load photos to the Sharper Image photo key fob
Yes, download the Mac software
Amazon.com: The Sharper Image Digital Photo Keychain, Black ...
https://www.amazon.com/Sharper-Image-Digital-Photo-Keychain/dp/B002KKBDQ8
Rating: 2.4 - ‎50 reviews
Buy The Sharper Image Digital Photo Keychain, Black: Handheld Digital Photo Viewers - Amazon.com ? FREE DELIVERY possible on eligible purchases. ... 60 color photos; Internal rechargeable battery; Easily select, edit, and download photos from your PC or MAC; Photos are automatically resized to fit the screen.
Amazon.com : Sharper Image USB 2.0 Digital Photo Keychain -- Store ...
https://www.amazon.com/Sharper-Image-Digital-Keychain-Display/.../B00L3NVQXI Rating: 2.5 - ‎7 reviews
Enter your model number to make sure this fits. AVAILABLE IN PINK, PURPLE, BLACK and RED - CONTACT SELLER; Store and display up to 60 photos; Large 1.5" color LCD Display; Rechargeable battery; USB 2.0 (cable included) for PC/Mac. 2 new from $15.00 5 used from $12.50 ...
How to Set Up Sharper Image Photo Keychain ' It Still Works ' Giving ...
https://itstillworks.com/12376892/how-to-set-up-sharper-image-photo-keychain Sep 28, 2017 - Digital photo keychains let you upload photos to view and share anywhere you go. With the use of a computer, selecting and loading the pictures on a Sharper Image Photo Keychain can be enjoyable and quite easy. The display menu allows you to view the photos as a slideshow, or you can manually ...
How to Download Pictures to the Sharper Image Photo Keychain ' It ...
https://itstillworks.com > Software The Sharper Image is known for its innovative gadgets and electronics, such as the digital photo keychain. This small device can hold up to 60 digital images and connects to your keys like any normal keychain. Of course, you must first download digital images to the device before you can enjoy it for its intended use. ...
The Sharper Image Digital Photo Album - Software Download ...
https://aaron-kelley.net/.../the-sharper-image-digital-photo-album-software-download-... Dec 24, 2007 - Here is a picture of the device for comparison with your device (to know if this is the software you need):. The Sharper Image digital photo keychain. Download version 2.3 of the software (1.92 MB, Windows and Mac OS X software included in the image). This is an ISO image of the CD that came with the ... sharper image photo key fob for mac Google Search
Mar 09, 2018 | Microsoft Computers & Internet
Not charge
i would make sure your plugging into a USB2.0 or higher port. and after looking at manual ,there is a reset button you can try ,dont forget to back up photos before you reset.i have had computers in the past that malfunctioned on certain USB ports,but i would try reset before i got to excited.
Mar 24, 2014 | Sharp The Sharper Image USB 2.0 Digital...
When i connect digital solution keychain to the usb port my computer doesnt recognize it. What can i do?
hi,
i am assume that you not yet installed your pc suite
Unlike other TAO keychains,your model requires a driver software to connect with pc.
you can download it from here.
your model is in the bottom left corner of this page.click on the link below your key chain image to download.
or
you can download it from direct download link
Jun 13, 2010 | Tao 1.5-inch Square Polished Silver Photo...
No icon is coming up when the digital photo keychain is connected to the computer via the USB. the keychain is charged, the screen is displaying the generic photo already on it but, no icon and no transfer...
When the cam is connected to the computer no pics will show on the LCD. While charging through the USB the cam. will not be able to transferre pics at the same time.
The cam either charges or transferres.
Oct 02, 2009 | Cameras
Installing coby digital keychain software
Start from scratch, uninstall everything and pretend your installing for first time:
1. have keychian unconnected from usb
2. install software
3. DONT RUN SOFTWARE YET
4. connect keychain to usb
5. on keychain select: USB update
6. Run software
7. well-ah, intelligence > poorly organized device - enjoy everyone
Dec 14, 2008 | Coby DP-5588 5.6-Inch (4:3) Clock &...
go to their website... www.mscustomercare.com and they have the drivers and stuff there....The problem i have is that after ive charged it for 3 days it wont turn on! It works when its plugged into the USB but as soon as i unplug it....wont turn on!
Dec 22, 2007 | Tao 89811-PB1 Digital Picture Keychain
Make sure that the usb driver is the correct one for your operating system. I realized that Innovage packed an absolete win98se in my package. I needed winXP usb driver.
Dec 16, 2007 | Alera Technologies Digital Photo Copy...
Innovage photo keychain software problem
For the Innovage photo keychain software download,go to http://www.mscustomercare.com Download the software from there. You will get a .zip file. When you "unzip" it, a folder appears on your desktop. Inside that folder is a "package" icon. Double click that and now you have Picture Viewer on your desk top.
However, I am a Mac user, too, just bought this keychain yesterday, chose my photos, got them in the Picture Viewer, but I can't see them on the keychain.!!! I am going to call their tech support. What a bummer1
Dec 08, 2007 | Cameras
Innovage Digital Photo Album w Keychain driver
Summary of Solutions posted here and elsewhere:
I just received a Innovage Digital Photo Album Keychain as a gift and ran into some of the issues posted here. I am going to summarize the solutions I have come across in hopes they will help others.
Installing/obtaining the software:
The keychain requires you to use custom software to upload pictures. The keychain includes a mini-cd with the software. If you have a computer with a slot loading cd (i.e. laptop, imac, mac-mini, etc) do not try to put the CD into your computer, it may become stuck! Either call the service line and order a full size cd, or try downloading the software from either:
Coby DP-151 software
Digital Foci - Pocket Album software
(While these are different digital photo products, the transfer software appears to be same as the Innovate software)
The software should be installed before you plug in the keychain into your USB port.
Software Issues:
Some users have complained that they can't see the whole transfer window. You might have your screen resolution set too low (like 680x480 or 800x600) try increasing to 1024x768 or bigger.
Finding photos: The software is quite simple, it does not integrate with your photo software (e.g. iphoto) it simple reads image files. You will need to point the software to where your photos are stored on your computer. For most people this is either "My Pictures" or simply "Pictures" folder.
Transferring photos: There have been some recommendations to transfer the photos to the keychain in small batches (like 6-10) rather than queuing up 60 images to transfer all at once. Apparently the software has crashed on some peoples machines when transferring many images.
Device Issues:
Charging: The device has an internal battery, it must be charged via your computers USB port. In must be in the charge mode, it will not charge when it is in the update mode. When you first plug the device into your USB port a menu should come up on the screen. You can use the arrow buttons to change the selection, then press the power key to select your choice. For charging you should select "USB Charge". In this mode the keychain will display images and won't let you power off. The red light will supposedly turn green once the keychain is fully charged.
Transferring images:
The keychain must be in the "USB Update" mode before your software will talk with it. Try unplugging the keychain, plug it back in, wait for the menu, use the arrow keys to select "USB update", press the power button. Now try running your transfer software
Bad USB cables: Many people have reported that the supplied USB cable doesn't work. If you are having problems with charging or transferring images, first try another USB cable from a similar type device if you have one (many cameras have the same sized mini usb connectors)
Hope this helps someone!
Nov 30, 2007 | Baby Gear
Can run photoviewer program for photo keychain
Your computer will certainly have its own program for viewing photos. For example, if you are using Windows XP, you just right click on a photo file and choose "preview". It can be difficult to find the photos on your computer if you have been using one of the silly organizers that come with cameras. You can search for a photo if you know its filename or for *.jpg to find all the photos on your hard drive.
Sep 11, 2007 | Sony Cyber-shot DSC-W55 Digital Camera
Symantec WinFax Pro for PC Logo
8,450 people viewed this question
Top Symantec Computers & Internet Experts
Peter Dragonetti
Are you a Symantec Computer and Internet Expert? Answer questions, earn points and help others
