Question about Garmin nuvi 200W GPS
Trying to reset my garmin nuvi 350 but per-boot mode is keeps coming up. i hold down the left corner and hold the power button i don't understand why i can't reset it. HELP im going nuts
  • Garmin Master
  • 2,130 Answers
G-Brand): Place your finger over the lower left-hand corner of the screen (upper left-hand corner for a 6xx series) and hold it there while pressing the on/off power button. Keep holding your finger there and a window should pop up asking if you want to go into maintenance mode. Select yes. There is an option called "clear user data". Select that option. It will not erase your favorites. It will however, erase any corrupted satellite data and will default you back to some factory settings and to a location of the manufacturer's headquarters in Kansas. This will also force your GPS to collect new satellite data. Your GPS should reboot and it will ask you a couple questions like, timezone, language. Please select the proper settings.
- Jim
SHARCNET-USA
Posted on Dec 10, 2009
My garmin nuvi will not shut down. The screen is white. Is there a reset button on the unit?
In some nuvi models there is a reset button.But in some nuvi models there is no reset button.you have mentioned only garmin nuvi but not mentioned the model of the garmin nuvi.But still i will mention the reset button location of some garmin nuvi models.Hope that helps you.
The reset button/procedure for garmin nuvi models
In order to reset Garmin device or enter into maintenance mode, perform one of the following procedures:
Power off Garmin unit. Press on continuously the upper top left corner of screen and then power on the unit by pressing once on the Power button. You should be prompted to clear all user data, or asked if do you really want to start up in maintenance mode. Press “Yes” to reset (warning: all data will be erased and lost, so backup before proceeding) or enter maintenance mode.
above works on Garmin Nuvi 660, 680 series.
Turn off Garmin device. Press down on bottom right corner of the touchscreen, and then power on the GPS unit. You should be prompted whether do you really want to erase all user data, or asked if do you really want to start up in maintenance mode. Press “Yes” to reset (warning: all data will be erased and lost, so backup before proceeding) or enter maintenance mode.
above works on Garmin nuvi 200, 250, 360 750, 760 series unit. Garmin Nuvi 360 on how to perform the hidden reset function.
Reset button on the bottom of the nuvi backside.
Click on the link below to get the exact location of the reset button.http://www8.garmin.com/manuals/1512_SetupandGo!.pdf also check out this link too http://www8.garmin.com/manuals/Nuvi350_OwnersManual.pdf Thanks. keep updated for any more query.you can rate this solutionand show your appreciation.
Jun 11, 2010 | Garmin GPS
(G-Brand): Place your finger over the lower left-hand corner of the screen (upper left-hand corner for a 6xx series) and hold it there while pressing the on/off power button. Keep holding your finger there and a window should pop up asking if you want to go into maintenance mode. Select yes. There is an option called "clear user data". Select that option. It will not erase your favorites. It will however, erase any corrupted satellite data and will default you back to some factory settings and to a location of the manufacturer's headquarters in Kansas. This will also force your GPS to collect new satellite data. Your GPS should reboot and it will ask you a couple questions like, timezone, language. Please select the proper settings.
- Jim
SHARCNET-USA
Dec 10, 2009 | Garmin Nuvi 350 Car GPS Receiver
New Nuvi 350-can't turn off or on
Try holding the power button down while it is plugged into a household power USB adapter..I don't think it was properly charged??
Jan 10, 2018 | Garmin Nuvi 350 Car GPS Receiver
Garmin Nuvi 350 can't see maps after update
Did you contact Garmin tech support? They are pretty good at it.
Mar 30, 2017 | Garmin Nuvi 350 Car GPS Receiver
Garmin Nuvi 350 Calibration Issue
Turn the unit off. Press and hold down the power button and keep holding it. You will see the screen light up and it will say "pre-boot mode". Keep holding down the power key. It will then say "booting". Keep holding the power button down. You'll then come to the calibation screen. Select the dots and you'll be back in business.
- Jim
Oct 20, 2008 | Garmin Nuvi 350 Car GPS Receiver
Nuvi 660 not locating satellites
Try this and see if it fixes your problem...first disable bluetooth then follow these steps.
1. Power off the unit.
2. HOLD down the power button and you will see "Pre Boot Mode" appear on the lower part of the display. KEEP HOLDING the power button down and the display will flicker, do this until the pre boot mode message disappears. This seems to take a long time (60 seconds at least).
3. Once the pre boot mode message disappears release the power button and your device will perform some activites to recover from the problem.
Dec 25, 2007 | Garmin 010-00358-00 GPS Receiver
Garmin nuvi 660 personal travel asistant
Are you running this unit while it is charging? Does the Nuvi 660 have a sufficient charge?
Try to do a hard reset on the unit.
Dec 13, 2007 | Garmin iQue 3600 GPS Receiver
Won't acquire satellite
There is currently an Update (Vers 5.10) available at Garmin.com Check only the Nuvi 350 click on it and the Nuvi 350 will appear. In the Upper Right Corner you will see a Category of Updates. Click on it and you will be advised that you need to Download UpDater. Do so, uncompress it, then attach your Nuvi to your computer and run Update. It's simple, just follow the instructions on the screen. However, it sometimes take a couple of tries before the Nuvi actually accepts and shows that it has been updated to Vers 5.10 I guess I was lucky. Mine accepted the new update with the 2nd install but it sometimes takes 4 or more. If you are uncomfortable with the foregoing or it doesn't work for you contact Technical support at Garmin. They are really helpful and you can e-mail them at techsupp@garmin.com
Dec 07, 2007 | Garmin nuvi 350 GPS Receiver
Garmin nuvi 200W GPS Logo
116 people viewed this question
Top Garmin GPS Experts
Marvin
Marvin
Steve
Will Halftowaite
Are you a Garmin GPS Expert? Answer questions, earn points and help others
