Question about Sony Grand WEGA KDP-65WS550 65" Rear Projection HDTV
Tv pic has redbluegreen images pic distorted
Picture images distorated looks like 3d image w red blue green in color words on tv hard to read pic clears up for a little while but contiunes to show colors
  • 4,234 Answers
This is a convergence problem that can be as simple as poor solder connections at the convergence ICs or defective ICs. If you feel that you want to attempt the repair yourself, please update this with that indication and additional details and instructions will follow. The parts for this repair will run about $40-$60.
Dan
Posted on Dec 10, 2009
  • Sony Master
  • 8,457 Answers
Ur convergence it dead.U know how to solders?Buy a convergence kit.These websites have it Tv repair World.com,Tv repair kits.
I have a 63' projection TV. The picture is off. All of the lights are working, but the images are fuzzy, and you see the image tripled. The three images overlap each other in red, green, then blue. ...
Please do us a favor and rate this solution after reading.
Projection TV sets have two very common problems. One is convergence ( 3D/Warped video) the other is CRT fluid ( Dull Video). Here are more details and solutions for both. Repair kits with instructions are also avail from www.TvRepairKits.com
Common Problem #1) Convergence has gone out
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some pics of convergence problems.
69189a5.pngSOLUTION #1
For more more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Common Problem #2) CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
69189a5.pngSOLUTION
You can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
May 09, 2011 | Philips 55PP9363 55" Rear Projection...
When you turn the TV on, you have sound but no picture. However, in hte upper right hand corner you see the number station and wording in the color green over red, what is the Problem?
All projection TV sets have two very common problems. One is convergence ( 3D/Warped video or dead set) the other is CRT fluid ( Dull Video). Here are more details and solutions for both.
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. In some cases the TV will also not show any video. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
  • Screen looks 3D
69189a5.pngSOLUTION
You can get the correct parts, step by step photo instruction guides, and support from www.TvRepairKits.com or click here
May 07, 2011 | Mitsubishi WS-55511 55" Rear Projection...
There is an arcing bow across the screen and image, text doubling in red and green, images look like an old 3D comic print.
  • Screen looks 3D
69189a5.pngSOLUTION
Feb 06, 2011 | Sony KP-46WT510 46" Rear Projection HDTV
Picture is distorted, kind of looks like a 3D image without the 3D glasses.
  • Screen looks 3D
69189a5.pngSOLUTION
Jan 31, 2011 | Mitsubishi WS-65809 65" Rear Projection...
Yellow highlights on the picture around images.
projection TV sets have two very common problems. One is convergence ( 3D/Warped video) the other is CRT fluid ( Dull Video). Here are more details and solutions for both.
  • Screen looks 3D
69189a5.pngSOLUTION
Jan 18, 2011 | Zenith R57W46 57" Rear Projection...
Rca hd52w59 tv has red, blue and green lines at the top and the images are doubled. What is wrong?
  • Screen looks 3D
69189a5.pngSOLUTION
Jan 18, 2011 | RCA HD52W59 HDTV Projection Television
51 inch projection- can't read words clearly,
ll projection TV sets have two very common problems. One is convergence ( 3D/Warped video) the other is CRT fluid ( Dull Video). Here are more details and solutions for both.
  • Screen looks 3D
69189a5.pngSOLUTION
Jan 14, 2011 | Hitachi 51F500 51" Rear Projection...
My screen showes triple image with green and red siloettes like it should be 3D but it is not this just came on overnight What might be my problem
  • Screen looks 3D
69189a5.pngSOLUTION
Jan 13, 2011 | RCA R52WH76 Television
Words ars doubled and arching, green and purple across parts of the screen, picture blurred
  • Screen looks 3D
69189a5.pngSOLUTION
Dec 26, 2010 | Toshiba 53HX71 53" Rear Projection...
The picture is showing a double image and is distored.
The problem you are refering to is more than likely a convergence problem. The convergence circuit in your tv is controlled by an IC (integrated circuit) stk392-110 and it makes the 3 colors (red, blue, green) line up/converge together to create a clear picture. You'll know when this part needs to be replaced because the picture you see is 3d looking and possibly bowed on the top or bottom or on the sides in any or all 3 colors.
Jan 24, 2010 | Mitsubishi WS-55511 55" Rear Projection...
Sony Grand WEGA KDP-65WS550 65" Rear Projection HDTV Logo
450 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
