Question about RIM BlackBerry? Tour 9630 Smartphone
I updated to the new OS system and now my tour turns off and I have to pull the battery to restart it. If I plug it in to a charger it will stay on. When I unplug it from the charger it turns off after a short time. Help!
I bought the Alcatel One Touch Fierce 2, about 1.5 months ago and the past few weeks it started showing a lot of erratic behavior. Programs keep popping up, or shutting down........mostly evident when
When you plug in charger, put the cord first in the phone then into wall. The opposite approach can break any android device due to improper electrical surge.
Dec 13, 2014 | Alcatel One Touch Fierce
I recently bought a dell latitude xt2. It kid currently running windows 7 professional. I installed the new BIOS for it (A13). It restarted and the opperating system screen came up. Shortly after the...
The BIOS flash was ok, or you never would have seen windows boot up.
This is not a driver problem.. Are the lights staying on when it's plugged in, if not it's a bad charger and the battery is to low or dead. Have you tried to boot into safe mode, tapping F8. There is a video connector, plug in a monitor, borrow one if you can, if it works and the OS boots and windows run's, the screen is bad.
Mar 30, 2013 | Computers & Internet
My Android 4 wont turn on
1.Check the device's battery level for at least two bars of strength.
2.If the battery level is low, charge the battery.
3.If the issue is not resolved, remove the back cover.
4.Remove the battery.
5.Wait 10 seconds.
6.Press and hold the W key.
7.While pressing down the W key, re-insert the battery.
•The device restarts and after approximately 15 seconds, the 'Recovery' screen appears
•Release the power button but *continue holding the home button*, for another 30 seconds.
Step
Thanks
Oct 07, 2012 | Cell Phones
It turn on and it stay on the main screen
Try these steps below to see if it will fix the problem on your ps3,
1. Turn off Playstation®3.
2. Hold the power button down; the system will turn on and turn off once again.
3. Once the System has been shutdown, re-press you finger until you hear 2 consecutive beeps
4. When you hear the 2 beeps take finger off power button.
5. You will be prompted to plug in your controller via USB and then hit the PS button
6. The Recovery menu will pop up.
The current Recovery Menu supports:
• Restart System: Restarts the PLAYSTATION®3 System.
• Restore Default Settings: Reset all system settings back to default.
• Restore File System: Checks for corrupt/missing system files.
• Rebuild Database: Rebuilds the OS for the PLAYSTATION®3.
• Restore PS3 System: Fresh restore; Deletes everything and starts from Scratch.
• System Update: Update the PLAYSTATION®3 System.
Take care.
Jul 03, 2010 | Sony Playstation 3 (PS3) Console
My ps3 wont turn on i tryed to turn it on but it just turns rite back off how do i gett it to stay on
It seems that your ps3 is experiencing the yellow light of doom:
Try this: 1. Turn off Playstation®3.
Jun 14, 2010 | Sony Playstation 3 (PS3) Console
HP pavillion battery icon says (plugged in, not charging) what makes this happen, i am a premium expert on here and have no clue on how to fix this! (NEW COMPUTER) LOL...
It means there is no output from your battery charger. This could be the charger itself is bad. The charger fuse is blown (if it has one) or the wall power outlet in the room is dead. First, check your charger output. You can do this test with a volt meter, another laptop, or a 12v globe and some wires. If that is ok, both charger and wall outlet are ok and the problem is either the battery or the laptop itself. Another possibilty is that it is in fact charging the battery, but the indicator says its not.
Mar 22, 2010 | HP Pavilion dv6000z Notebook
I have a pair of sp10 and having trouble charging them and the batteries are new and when i put them in the charger i have to turn them on for the chargeing light to come on is this normal or are the...
You do not mention if you are using a wall plug charger, or a drop-in charger. We will give troubleshooting tips for both. To answer your question: If the light comes on and stays on, on the charger your charger is good. You have a radio or battery problem.
Wall Charger:
The light on the HTN8232 wall charger should come on and stay on when plugged into the radio, with the radio turned off. The fact the light comes on when the radio is turned on indicates your batteries are either no good, too low to charge, or you have a battery contact problem.
Solutions: 1) Clean your battery contacts with a pencil eraser.
2) Be certain the batteries are installed correctly.
3) Check your battery date code (three digit number on back of battery above the stop sign. First number is year, next two numbers are the week of the year. Batteries last about 2 years.)
4) Check to see your new batteries are NiCd batteries. The wall charger method is not compatible with NiMH batteries.
5) Try a charged battery from another radio and see if the charger light comes on and stays on with a different battery.
Drop-In Charger:
If you are using a drop-in charger, you would be using the above listed HTN8232 wall plug charger plugged into the tray. Here are some possible solutions for the drop-in charger:
1) Clean the exterior battery contacts with a pencil eraser.
2) Check to see if the wall charger will work when plugged directly into the radio.
3) If the charge capability of the radio seems compromised, take the battery out of the radio and charge it alone in the drop-in charger.
NOTE: Do not use the PTT if you are turn on the radio when plugged into the charger. This will burn out components in your radio.
The SP10 radio is known to be a repairable radio. (Generally around $69 flat rate.)
Best regards.
Dec 05, 2009 | Motorola Walkie Talkie 2-Way Radio
Laptop power flickers on and off
Its probably the connector where the power supply plugs in. Pull out the battery and turn on the laptop with only the AC adapter plugged in. If it doesn't turn on, or doesn't stay on, its the connector.
Jun 29, 2009 | Gateway MT3705 Notebook
Dell inspirion 6000 battery/charging problem
Also, check to make sure that you have a good connection between the laptop and the charging cable at the power port on the rear of the laptop. We have an Inspirion 6000 with this problem and we've discovered if you pull the power cord out very slightly and lift it upwards, the charging icon appears in the system tray. Appears to be a fractured connection inside the laptop at the power port. Changing chargers does not make any difference.
Nov 18, 2007 | Dell Inspiron 6000 Notebook
RIM BlackBerry? Tour 9630 Smartphone Logo
Top RIM Cell Phones Experts
Longtime User
ismael castillo
Jason
Are you a RIM Cell Phone Expert? Answer questions, earn points and help others
