Question about Intermatic Electrical Supplies
Can i order on and off trippers for Intermatic TN111
Www.intermaticstore.com
Part# 107TN221 & 107TN222 $.10 each + $7.00 Shipping
Posted on Oct 16, 2010
How to set intermatic model No. TN111?
http://waterheatertimer.org/How-to-set-timers.html
Step-by-step shown on link above
TN111 is reliable analog timer
Gene
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Feb 12, 2015 | Intermatic Hardware & Accessories
Intermatic troubleshooting
You need new 120V WG1570 clock motor
http://waterheatertimer.org/Intermatic-trippers-and-parts.html#T100
http://waterheatertimer.org/How-to-replace-Intermatic-clock-motor.html
Order extra trippers too... motors and trippers are replaceable so timer can last 25+ years
http://waterheatertimer.org/Buy-T100-series-timers.html
Gene
Aug 27, 2014 | Intermatic Hardware & Accessories
I need trippers for an Intermatic Raintight Outdoor Timer model HB11R
1) Intermatic trippers: Buy Amazon or Intermatic store
Copy following link to identify tripper
http://waterheatertimer.org/Intermatic-trippers-and-parts.html#trippers
2) Copy following link to identify Intermatic analog timers with replaceable trippers
http://waterheatertimer.org/Intermatic-timers-and-manuals.html#appliance
3) Add comment and describe timer in detail, and color of tripper
Dec 10, 2012 | Intermatic & Indoor/Outdoor Rain Tight...
Ti04 clock rotates and new trippers but doesn't turn on
You probably have T104 timer.
Clock rotates so power to timer motor is good. This means 240Volt breaker is good.
Use override lever and see if Load (light, fan, motor) turns on and off. If override does not turn Load on-off, then bypass timer and see if load works. Move wires from terminal 2 to terminal 1, and terminals 4 to terminal 3.
Did you order correct trippers?
Copy following links for Intermatic troubleshooting and Intermatic parts list.
http://waterheatertimer.org/How-to-troubleshoot-Intermatic-timers.html
Jun 28, 2012 | Intermatic T104 24h 208-277v Mechanical...
I have 3 brand new TN111 indoor timers and none will work. They turn off and on when I manually flip thep or use the overide button but will not turn with the time on their own. Tried on 3 different lamps...
You are having bad run on timers.
At least your car is working and the whole house fan motor-winding didn't overheat and stop working.
The problem with timers that don't work is that you have the timer and can fiddle with the settings.
The expert is just guessing at a possible causes, and at the end you still have a timer that doesn't work and might wish the expert can drive over and sort out problem > but that isn't going to happen.
The free answer is not interactive, so for best possible answer, re-post question and pay for interactive answer with expert who can suggest things, and then you try that and give feedback to expert, and then try next thing and give feedback, etc.
Before you pay for answer, let me make free guesses for your benefit
http://waterheatertimer.org/Woods-timers-and-manuals.html#troubleshoot
It seems you are experimenting with different loads and each load is causing same result, so that implies that timer is probably the problem.
You do not mention trippers, so maybe you don't have turquoise 107TN222 on-tripper and red 107TN221 off-tripper in place or pushed all the way down.
Maybe your timer did not come with trippers
You don't mention if your Load is turned on > for example turn on the light before plugging into timer. The timer does not reach up and operate the on-off switch on a lamp for example.
You can manually rotate timer dial clockwise and that will cycle through entire day. Manually rotating dial will let you test tripper and and switch settings.
Some timers are 'vacation timers.' TN111 is not vacation timer, but vacation timers are factory preset for on-off times and cannot be set by customer.
Maybe you do not have T111 timer: Open link to identify timer.
http://www.amazon.com/Intermatic-Lighted-Dial-Timer-settings/dp/B0044YLRNC
Maybe you got a bad batch of timers and they are defective. I test timers and 4-6% of in-wall and plug-in timers arrive defective. Intermatic makes a top-notch product.
Your yard light timers are probably not related, but open first link to see cross section of yard timers. Most timers come with 1 year limited warranty, so if all of them stopped working at same time, maybe a dust storm put particulate in the clock gears, or maybe a power spike fried the clock motor electronics.
Use cheap circuit analyzer from home center and check outlets for problems.
I suggest whole house surge protector which is more costly than timers, but will protect things that are on not on a surge protector, like water heater electronics, whole-house-fan, heat-AC, refrigerator, circuit breaker panel, etc. Surge protector will protect from lightning strike, and is replaced after each event.
http://waterheatertimer.org/Intermatic-trippers-and-parts.html#surge
Apr 29, 2011 | Intermatic TN111C - Heavy Duty Lamp and...
I have lost plastic pin{red} for my indoor light timer. Is there anything I can use to replace it,or can I buy a new one? If so where can I get them? It is an INTERMATIC TIME ALL Model No. TN111.
Open following link for Intermatic trippers and parts with identifying numbers and ordering information.
According to Intermatic information, TN series uses 107TN222 turquoise ON tripper, 107TN221 red OFF tripper.
Order from Intermatic:
http://store.nexternal.com/intermatic/categories.aspx?Keyword=107TN221+tripper&x=20&y=13
Add a comment with your experience so others with same-similar problem can benefit.
Also take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Apr 03, 2011 | Intermatic Hardware & Accessories
Where can i buy on and off trippers for tn111
Intermatic no longer makes TN111 timer:
http://www.intermatic.com/customer%20service/instruction%20manuals.aspx
There are plastic Intermatic trippers. You have to decide if trippers same as yours or if cost effective to have trippers shipped vrs buying plug-in timer at Home center, hardware, Target or Walmart
http://www.amazon.com/s/?ie=UTF8&keywords=intermatic+timer+trippers&tag=googhydr-20&index=aps&hvadid=5156211581&ref=pd_sl_1b2t69w1k6_b
GE makes tripper-timer sold at Home Depot for $10:
http://waterheatertimer.org/GE-timers-and-manuals.html#15004
Walmart sells a tripper-type too, but I forget model number and timer is not always in stock.
Lowes sells segment-type timer.
http://waterheatertimer.org/Woods-timers-and-manuals.html#59419
Add a comment for more free help.
For a price, expert works with you via e-mail while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Feb 16, 2011 | Heavy Duty Intermatic Timer
I have lost the little plastic pegs that turn the time on and off can you tell me where I can buy them.. Home Depot and Osh do not have them
According to Intermatic literature, ML series Power Pack uses 107SB189 ON tripper, and 107SB192 OFF tripper. I have not ordered these trippers and no image seems available.
Red On tripper available at IntermaticStore.com
Black Off tripper available at IntermaticStore.com
Tripper order form
For more information on power packs:
http://www.fixya.com/support/r8391011-power_pack_not_working
Jul 08, 2010 | Intermatic Malibu 300W Power Pack...
Electrical Supplies Logo
224 people viewed this question
Top Intermatic Electrical Supplies Experts
Gene Haynes
Craig Butler
Craig Butler
Jay Finke
Jay Finke
Are you an Intermatic Electrical Supply Expert? Answer questions, earn points and help others
