Question about Cell Phones
Just want to make a connection from sony ericsson c903 mobile to a telephone jack so I can use an old nokia cigarette lighter cradle to charge unit
C903 sony ericsson can i unlock for free
Hi, Free unlocking is not possible for your phone model. but you can get the accurate unlock code for a Sony Ericsson C903 from www.classicunlocking.com/sony-ericsson-c903/rs16wp9/ at low cost.
UNLOCKING STEPS FOR SONY ERICSSON C903
1 - Switch ON your Sony Ericsson C903 without any SIM Card,
2 - Press the left arrow key/button once,
3 - Press the button * twice,
4 - Press the left arrow key/button once,
5 - The message "Personalize with MNC2" will appear, (or you will have displayed an unlock menu, select the lock you want to unlock)
6 - Enter the Unlock Code.
If your Sony Ericsson C903 does not have a left arrow button/key(e.g. Sony Ericsson W950i) and on a few phones(not all) that have a "JOGDIAL" you must press the "down arrow" key/button instead of the "left arrow" key/button for step 2 & 4. We mean by "Down Arrow" to direct the Jogdial down! In the Sony Ericsson W950i and some other models, the down arrow button/key would be located on the side of the phone.
Nov 02, 2012 | Cell Phones
What is the unlock net code for sony ericson c903
To get the Unlock code for SOny Ericsson C903 visit the site
Mobile-unlocker.com/sony-ericsson-c903/rs2wp9/ buy unlock code at reasonable cost and unlock it easily.
Aug 19, 2012 | Cell Phones
What's the unlock code for sony ericsson c903?
Get the unlock code for your sony ericsson c903 model mobile from this site Prounlocking.com , it gives you a easy instructions and methods for getting the unlock code for your mobile from the network lock........
Nov 15, 2011 | Sony Cell Phones
My C903 phone stoppped orking and wouldn't turn on
possible software fault, try using sony ericsson update which you will find on sony ericsson website
Apr 01, 2010 | Sony Ericsson C903 Facebook - black Menu...
How to charge battery?
In most cases you use your cigarette lighter that came with your unit to charge the battery. I myself have a home ac to dc converter to charge mine with.
Dec 04, 2009 | Garmin StreetPilot C330 GPS Receiver
The cradle no longer charges the garmin in my vehicle. It's not charging anymore. Nuvi 750
Sometimes, if the Garmin GPS battery is allowed to fully discharge, it would require charging directly via USB cable connected to a PC or Mac before it would accept a charge for the cigarette lighter again. Try connecting this way for 4 - 8 hours or more before going forward.
Check the cigarette lighter plug in another "known good" lighter socket / vehicle to help rule out a defective socket. A socket without power indicates anything from needing to change a "simple to replace" fuse - or a bigger problem - damaged wiring in the vehicle (if the socket is used to light cigars & cigarettes - vacuum the socket out to remove ash and tobacco that may collect inside). Trying the GPS elsewhere helps eliminate possible problems with the socket. If it doesn't work elsewhere, depending on the plug that goes into the socket, it too may have a built-in fuse. Check the plug for an exposed fuse - or see if the tip unscrews to provide access to a fuse inside. If unsure, the tech Support people at Garmin are a great source for free help.
Lastly, dirt or grime on the "cradle to GPS" connection or "cable to cradle" connection could be causing the failed connection. In short - carefully inspect all points of connection and remove any deposits found.
Sep 16, 2009 | Garmin GPS
Charging the battery in Nuvi 760
1) Check the cigarette lighter is working by plugging in the lighter unit and see if it gets hot. If it doesn't then it is possible the fuse has blown.
2) You can plug the unit into a PC using the USB cable and if there is a fault you will get a message on the screen about 'USB over-current' but it shouldn't damage the computer.
If it runs/charges using the PC and (1) is OK then you may have a problem with the cigarette lighter - cradle cable or a problem with the cradle itself.
HTH
Peter
Jan 24, 2009 | Garmin Nuvi 760 Handheld GPS Receiver
Charging unit with AC adapter
I have a 100v A/C power / charger unit for my garmin C340 GPS that I use to charge my Garmin's battery every day. I can use thj adapter to run the GPS, or just turn it off and let it charge the GPS. But it connects dirctly to the Garmin GPS unit, not to the cradle like the Cigarrette lighter unit does. .
Mar 18, 2008 | Garmin StreetPilot c340 GPS Receiver
Cell Phones Logo
20 people viewed this question
Top Cell Phones Experts
Marvin
Marvin
Are you a Cell Phone Expert? Answer questions, earn points and help others
