How to enter the service mode on IR2022 - Office Equipment & Supplies
  • 622 Answers
Additional function, 2 then 8 then additional function again...
I’m happy to assist further over the phone at https://www.6ya.com/expert/norman_d2fa496dce30c65d
Posted on Dec 10, 2009
  • farid_shahab
    farid_shahab Oct 15, 2012
    they it says WAITING.. and stucks like that, any idea pls?
How to set ip address in canon ir2022
You will need to log into the "Admin" section of the copier.
Then go to the network section.
You should have a manual with it for default user/pass and how to enter IP. Manual: http://software.canon-europe.com/products/0010473.asp
Jan 21, 2015 | Canon Office Equipment & Supplies
Error code 002-0000 for canon ir 2202
Hi
A website I have found gives the details of this error for the IR2016 and the IR2022 as the same.
Description Low temperature during temperature control.
The target temperature is not reached during temperature control. Remedy - Check the connector of the fixing film unit. - Replace the fixing film unit. - Replace the DC controller PCB. Amongst other codes you can find it here:
Error Codes Canon iR2022
Hope this is helpful, if so would you please register that with Fixya
Cheers
Nov 25, 2014 | Canon iR 2016i Black and White Copier
How can I fix an error code E007 on a canon IR2022 copier?
E007
0000-
An error in the rotation of the fixing film is detected.
The reading of the main thermistor is 100C or higher and, in addition, the
fixing film sensor does not detect the rotation of the film for 6 sec or more
while the fixing motor is driven.
Main cause-
The fixing film sensor (PS45) is faulty. The DC controller PCB is faulty.
Caution-
To clear the error, execute the following in service mode:
COPIER>FUNCTION>CLEAR>ERR.
Action
1. Wiring
Are the wring and the connectors connected securely?
DC controller PCB (J311) <-> relay connector <-> fixing film sensor
NO:Connect the wiring and the connectors.
2. Fixing film sensor
Check the fixing film rotation signal.When the fixing motor is rotating, is
the film rotation detection signal sent by the fixing film sensor to the
concoctor J311 of the DC controller PCB?
Film rotation detection signal:5V pulse signal between J311-A9
(FILM_ROT_D) and J311-A8 (GND); at intervals of 100 msec ON and 440 msec OFF
NO:If the fixing film is normal, replace the sensor.
3. Fixing film unit, DC controller PCB
Is there a fault in the fixing film edge rotation detection mechanism?
YES:Replace the fixing film unit.
NO:Replace the DC controller PCB.
Execute the following in service mode, and
turn off and then on the power switch to clear the memory: #7
PRINTER>#4 PRINTER RESET>YES=(*)
Try this - Enter the service mode by pressing "additional function" key, "2" and "8" keys in that order. SSSW will display. Press "OK" key.
Change Bit switch 1, bit 0 (might display as the first one on the left using number keys) status, (change 1 to 0 or 0 to 1).
Press "OK" than Press "Stop" or "Additional Function key" to end service mode or restart the machine.
Jul 16, 2014 | Canon iR 2022 Printer
Dear sir i has a copier Canon IR2022 when i copy a file it give message ( system error 007 or system Error 003) how can i resolve the problem. thank you much
Possible torn out fixing film. Or dirty reference white plate on your fixing film. To resolve the problem, try replacing the fixing film unit or call the nearest authorize service center.
Aug 14, 2013 | Canon iR 2022 Printer
Service manual canon ir 2022
hello friend, you can find the canon iR2022 service manual in below link:
Canon iR2022 service manual:
http://goo.gl/n2Rc95
thanks
Jun 15, 2013 | Canon imageRUNNER 2022 Grayscale Copier
Reset counter
You cannot reset the counter to zero on your own. :) Call your authorize service center to replace your counter PCB.
May 03, 2013 | Canon iR 2022 Printer
How i do scanner in canon ir2022
connect computer to network
install canon color network scangear, select printer ip in this software.
now you need scanning software.
I'm using freekapture.
place document in printer scanner. click scan button on printer.open freekapture and start scanning
Jul 06, 2012 | Canon iR 2022 Printer
I need service manual for canon Ir2022i
hello friend, you can find the canon iR2022i service manual in below link:
http://goo.gl/FDaoZk
thanks
Jun 04, 2012 | Canon iR 2022i Printer
Hello I have a canon ir2022 copier. I did a complete cleaning of all copier and when I recovered after having switched on a message error code e197. I controlled everything but I can not get from this...
Dear Mokhtar,Error code E197 indicates that laser scanner does not work properly. It's seems that you should try to replace this parts (Laser Scanner Assembly). Please download the following piece of IR2022 parts catalog to see detail of laser scanner assembly:Laser Scanner Assembly
I'm sorry for being late responding your problem and you don't have to pay for this :).
Regards,Xanda
Oct 03, 2011 | Canon iR 2022 Printer
Canon irt 2022 says "system error 007"
dear sir !
my canon ir2022 has one problem which is system error E007 how i can solve this above problem , i am wait for your answer .
Thanks & Regards.
Nayeel
Aug 13, 2009 | Canon iR 2022 Printer
214 people viewed this question
k24674
jasbo
jasbo
